2012 Access Cab Lift
Discussion in 'Suspension' started by Tulot Tech, Sep 25, 2011.
  1. Sep 25, 2011 at 11:53 AM
    Tulot Tech
    Tulot Tech [OP] Well-Known Member
    Justin
    Trumann, AR
    2017 TRDOR DCSB, 4x4 6 Speed Manual
    Is plasti-dip a mod?
    Been doing some research...trying to come up a lift/leveling solution for my new truck. Would like to keep the whole project under 5 or 6 hundred so I can afford some slightly beefier/bigger tires for now. Not seeing any solutions on the sites...I'm a total Tacoma newb (2 days in my driveway) and I'm not sure of the difference between a 2011 and a 2012. Any advice will be appreciated.
  2. Sep 27, 2011 at 7:54 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Eibachs w/ 5100's set at 0, Rear TSB, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, 265/75/16 Hankook Dynapro ATM Tires, Elusive Elements Mesh Grill
    pretty sure there is no difference between 2012 and 2005-2011 Tacomas when it comes to suspension. so whatever you read that's for 2nd gen Tacomas should work for you.
  3. Sep 27, 2011 at 7:57 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    other than the grill and headlights and front bumper, that kinda stuff, its the same as the 2005-2011
  4. Feb 16, 2012 at 10:38 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    i had a 2011 and now a 2012 (right price :) ) only difference is facelift stuff, front end, cd player, gauges, etc...
    as far as a lift for under 5 or 6 youll probably have to go with what everyone else does, 5100s and an aal
    i was sold on the OME route for my old truck but ended up doing 5100s and wheelers progressive aal since ill be on the highway more than in the country now :( i moved from SD to linconln, ne. lame. . . but yeah, thats my input on a level/lift for cheaper
