2012+ aftermarket headlights
Discussion in 'Lighting' started by firetaco18, May 6, 2013.
  1. May 6, 2013 at 3:22 PM
    firetaco18
    firetaco18 [OP] Well-Known Member
    Anyone find aftermarket headlights for the '12+. All I can find is retrofit. I want to throw in some projector lights with BHLM but dont want to drop $800+. Any suggestions? Thanks!
  2. May 6, 2013 at 3:25 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Check Ebay. I saw some on there that arent retros.
  3. May 6, 2013 at 3:36 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The correct way to "throw in some projector lights" is by doing or buying a true retrofit.
    The spyder and other ebay crap (even if they do offer 2012's now) have terrible scatter and a cutoff line that helen keller could tell you is a joke. they also have always had worse halogen output than stock, and throwing hids in them is just gunna blind others, and not net u the quality of lighting u think ur paying for......also, they leak 90% of the time.
    Save ur money and do a retrofit, or pay someone.......in the end u will be much happier
  4. May 6, 2013 at 3:37 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Good info.
  5. May 6, 2013 at 5:22 PM
    firetaco18
    ok that is what I figured, may just pay to do it right.
  6. May 6, 2013 at 5:24 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    D2S from TRS is pretty simple I've been told
  7. May 6, 2013 at 5:26 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    in the end, u will save money.
    good luck, and dont go cheap......do it right the 1st time, and u wont have to "fix" anything later.
    I speak from experience with retrofits, and reading many issues right here on TW about the ebay/spyder projectors.
    Moose has done some extensive work to "fix" and majorly improve on the design of a set of spyders......Ill look for a link
  8. May 6, 2013 at 5:26 PM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    If you know what you're doing. And nothing wrong with aftermarket. Just change the projector and you're set.
  9. May 6, 2013 at 5:28 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  10. May 6, 2013 at 5:29 PM
    HIst8ofMIND
    PJ
    Maui
    I saved money by getting replicas and throwing in TRS projectors.
  11. May 6, 2013 at 5:31 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    so u retrofitted quality projectors into a housing that had inferior projectors.
    same as moose
    good job :cheers:
  12. May 6, 2013 at 5:38 PM
    HIst8ofMIND
    PJ
    Maui
    Yup. Because legit JDM projectors are costly. And you still need to find LHD projectors. Unless you get ahold of EDM projectors which cost more than JDM.
  13. May 6, 2013 at 5:43 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    good stinkin man
