2012 Alignment Results with 2" leveling Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JRod4928, Oct 13, 2012.
  1. Oct 13, 2012 at 7:14 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    What do you guys think about these results?
  2. Oct 13, 2012 at 7:15 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    2012 4x4 SR5
  3. Oct 13, 2012 at 7:33 AM
    Steve33fish
    Steve33fish Well-Known Member
    Yorba Linda
    13 Tacoma 4x4 LB
    What shop does alignments in 130 am?
  4. Oct 13, 2012 at 7:35 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    a very dedicated one... or one that forgets to set the time on their machine
  5. Oct 13, 2012 at 2:42 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    alright guys. you think I'll have tire wear issues? Anyone have any input?
  6. Oct 13, 2012 at 5:40 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Camber looks way jacked up on the right. Generally, anything over .5 is going to cause uneven wear. Caster looks weird to me, too, considering your have LR UCA's. Just seems like they should be able to get better numbers with aftermarket UCA's but who knows, I'm no expert. Check this thread: http://www.tacomaworld.com/forum/suspension/201871-alignment-tech-help-thread.html
    My previous tires, Destination AT's, were worn on the outside edges at .7+ camber when I had mine at 2.5 front/1.5 rear lift. I have not gotten UCA's as of yet but they were able to get my camber to .4+/.5+ and there has been no more wear.
  7. Oct 13, 2012 at 8:14 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I hope that rotating tires every oil change will prevent uneven wear. all camber is at about the middle of the recommended ranges so they can't be too bad, right? I have stock UCA by the way
  8. Oct 13, 2012 at 8:16 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I agree caster could be better but it feels fine at high speeds. actually at lower speeds the steering wheel is jerked around a bit by ruts/rocks, but that's stock UCAs for you. More pos. caster would help that too but it's acceptable right now IMO
  9. Oct 13, 2012 at 8:17 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    another question, how bad was the uneven wear and did you rotate often?
  10. Oct 14, 2012 at 5:07 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Basically, I lifted my truck in April and the tires had over 50K on them and I planned on replacing them which I did in July so I never bothered to rotate them, just didn't care. They were worn smooth by the time they were replaced but they also didn't have a heck of a lot of tread left on them. Now with the new tires, GY Duratracs, they are wearing evenly thus far. I ended up lowering to 1.75" until I get the UCA's.
  11. Oct 14, 2012 at 5:09 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    OK, for some reason I was thinking you had aftermarket UCA's. I can really only go by my experience but check out that suspension thread and maybe even post in there too. You will definitely get some answers because there are a bunch of folks subscribed to it.
  12. Oct 15, 2012 at 6:16 PM
    JTRD12
    JTRD12 Well-Known Member
    AL
    08 TACOMA TRD DC
    BBS Wheels, bull bar, toolbox, vent visors, and that's bout it for now.
    I'm in the process of lifting the front 2" and rear 1" on my yota. I have the same tires in 275/70r17. What size did you get and how do you like them? I'm worried about alignment so i'm watching this thread closely
  13. Oct 16, 2012 at 4:15 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Your alignment should be fine with 2" - see the first post in this thread for my alignment results with a 2" leveling kit. I didn't lift the rear at all and it sits perfectly level.
    Your tires are actually 32", mine are 31.5". Mine rubbed the little front mud flap that attaches to the front bumper (this mud flap is only on the 2012, I believe) because I got aftermarket rims with less backspacing, so the tires stick out from the fender about 1.25" farther from stock with 265 tires. Less backspacing means that when the wheel is turned it isnt fully within the wheel well, so it can rub stuff. Generally speaking, when people say you can run 33" tires with a 3" lift, they're right, only if you're using stock rims, or rims with the same offset. Once you mess with backspacing, all bets are off.
    Since your tires are 32", and 275 width (1/2" wider than 265), I'd be willing to bet that you'll have a little trimming to do when you have the wheel turned or when youre in reverse. You won't know until after you get it aligned though.
