2012 Bed liner bin lock install *with pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nevenelestate, Dec 20, 2011.
  1. Dec 20, 2011 at 4:16 AM
    nevenelestate
    nevenelestate [OP] Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    I bought two lock sets from the local hardware store, making sure that the numbers on the keys, matched in both sets, allowing me to use one key to open both bins.
    Lock set
    Start by removing the 6x T30 torx head screws to remove the bin
    **NOTE: All measurements will be dependent on the specific lock you get, however I suggest drilling the hole lower than I did to accommodate the locking arm better, the first bin got a larger hole than necessary due to lack of foresight**
    Drill a hole the size of the lock shaft, I used blue painters tape to make it easier to mark the spot to drill and attempt to protect the plastic while drilling
    the ribbing on the back needs to be cut where the red marks are and remove the walls inside that area to accommodate the spring clip that hold lock into place(completed in second pic)
    lock installed from front side, you’re half way there! (well a quarter of the way if you include both bins)
    Next you need to measure out, again varies by lock and arm used, and cut a slot in the bin(top side) for the locking arm to slide into. This took some guestimation on the first bin and lessons learned made the second easier, good news is that this hole will be in the ceiling of the box and not really vissible
    Now reinstall the 6 screws and the bin is back in the liner and you can store items, cargo straps for me, in there without worrying if they will be there when needed
    Also by using the same key sets for both locks you will now have plenty of spare keys
  2. Dec 20, 2011 at 5:44 AM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Nice job
  3. Dec 20, 2011 at 6:04 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Been done before, also a combination lock version as well.
  4. Dec 20, 2011 at 6:16 AM
    nevenelestate
    Andrew
    Southern MD
    Stock
    cool, just thought i would share
  5. Dec 20, 2011 at 7:59 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Nicely done, but I'd just use a torx screwdriver instead of a key... and take the whole box if I really wanted it.
  6. Dec 20, 2011 at 8:58 AM
    nevenelestate
    Andrew
    Southern MD
    Stock
    true, but if they are gonna do that much work to get some cargo straps oh well haha
  7. Dec 20, 2011 at 9:03 AM
    eewoz
    eewoz Member
    Ed
    Buffalo, NY
    2011 4x4
    Nice job. Thanks for sharing.
  8. Dec 20, 2011 at 11:30 AM
    ZachMX
    Yours is slightly different, sorry, was at work and grumpy for some reason. Nice write up.
