2012 BHLM and Retros
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Commanderwiggin, Dec 22, 2011.
  1. Dec 23, 2011 at 5:02 AM
    booboy
    booboy Well-Known Member
    PaCiFiC nOrThWeSt
    2010 TrD SpOrT 4x4
    I like! Looks good, brotha!
  2. Dec 23, 2011 at 7:29 AM
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    IMO, take off the alignment ring and adjust the horizontal yourself with a pair of channel locks. They are there to help but you don’t really need them. I had one twist on me when I went to go tighten so I just took it off. Maybe you received the incorrect alignment ring but I doubt it Morimotos should be a direct bolt in plug and play for H4. Hope this helps. You won’t have to take the lens off to take the ring off either...
  3. Dec 23, 2011 at 7:43 AM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    They look like they both just need to be rotated a little bit. The mini's are not perfect you still have to play with them a bit on the ones that I have done I left the clear lense off and put them on the truck so you can check the horizontal alighnment of the cut off. If they are a little off you can slightly rotate them by hand to get them level.
  4. Dec 23, 2011 at 10:09 AM
    Commanderwiggin
    Commanderwiggin [OP] Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    I'm going to try to find some time to adjust it today...just curious what I should be targetting for headlight aim/height adjustment and such? IE...truck 25ft away from wall...cutoff height?
  5. Dec 23, 2011 at 10:12 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Whoa! I used the rings and mine looks nothing like that!!!???
    Use this link for how to aim them properly
  6. Dec 23, 2011 at 10:13 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    that is just plain terrible!! arent those supposed to be pretty much PNP? one always needs to check the alignment when doing a retro, but i thought those things are closer than that when installed initially?!
  7. Dec 23, 2011 at 10:16 AM
    08PRELB
    Adam
    805
    08 Prerunner LB
    First off you want to get your cutoff level then you want to aim the in at 25'. You should have a 2.1" to 2.5" drop form the height of the midddle of your projector to the cut off on the wall. You cant use this link as a guide.
    http://www.hidplanet.com/forums/showthread.php?10848-HOW-TO-aim-HID-headlights
  8. Dec 23, 2011 at 10:26 AM
    Commanderwiggin
    Calgary
    Thanks!
    Supposed to be plug and play...dunno if the 2012 housings are different but the alignment notch is perfectly at 12 O Clock or 0 Degrees which is where it needs to be for horizontal alignment. :mad:
    Yes I will get the cutoff level before alignment...just wanted to take care of the aim after. Thx for the link.
  9. Dec 23, 2011 at 10:39 AM
    Commanderwiggin
    Calgary
    Ummm...they're orange?
  10. Dec 23, 2011 at 10:40 AM
    shweller
    Corona
    x2 those are nice!
  11. Dec 23, 2011 at 11:30 AM
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    If you black out the reflector, won't it affect the amount of illumination?
    Nice looking 2012.
  12. Dec 23, 2011 at 11:37 AM
    memario1214
    Colton
    Missoula, MT
    No. All of the light on the road is put out by the projector. This type of setup doesn't need a bowl to reflect off of in order to aim its light.
  13. Dec 23, 2011 at 1:00 PM
    Commanderwiggin
    Calgary
    2012's don't fit the Mini D2S kits without modification...confirmed
  14. Dec 24, 2011 at 2:31 AM
    Commanderwiggin
    Calgary
    So after many frustrations including a massive mishap with some epoxy glue and a broken notch on my bulb (will need to be replaced)...we have success!!
    Lows:
    Lows Again:
    Highs:
  15. Dec 24, 2011 at 2:33 AM
    #35
    memario1214
    Colton
    Missoula, MT
    Much better! We need to have a talk eventually about what you did to accomplish the task lol. Nice work
  16. Dec 24, 2011 at 2:45 AM
    #36
    Commanderwiggin
    Calgary
    I ended up shaving the housing where the adapter plate fits into and allowed it some play so I could dial the horizonal alignment in...made note of it and then used some heavy duty epoxy to lock it in place...I know the next time this comes off it will be getting an FXR Setup. The glue makes it permanent...not ideal but I ran out of time and needed a solution.
  17. Dec 24, 2011 at 6:50 AM
    #37
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Awesome job truck looks great...:headbang:
  18. Dec 24, 2011 at 8:00 AM
    #38
    08PRELB
    Adam
    805
    08 Prerunner LB
    Nice work glad you got it fixed.
  19. Dec 24, 2011 at 8:00 AM
    #39
    08PRELB
    Adam
    805
    08 Prerunner LB
  20. Dec 25, 2011 at 9:41 PM
    #40
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    nice mod! good looking truck!
