2012 BHLM and Retros
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Commanderwiggin, Dec 22, 2011.
  1. Dec 25, 2011 at 9:54 PM
    #41
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Those look so sick!! Good job on the mod!! I have the same setup except only on a 2006.:)
  2. Dec 26, 2011 at 2:46 AM
    #42
    socal_av
    socal_av Well-Known Member
    Rudy
    Palmdale <CA
    2012 TACOMA DC LB Sport Mag Gray
    alot soon. hopefully
    looks good. my truck looks exactly like yours except the retros. still not to sure if i should do it or not. never done them before. how much time did it take you initially to do the retros?
  3. Dec 26, 2011 at 9:57 AM
    #43
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    congrats...I guess it is confirmed the tilt is a 2012 issue. glad you got it resolved. I trimmed the retaining plate so that it would be level
  4. Dec 26, 2011 at 12:01 PM
    #44
    dantastic
    dantastic Well-Known Member
    818<->626
    2012 DCLB 4x4 BLK
    Yep, that's how the Mini H1 projectors look on my 2012 too... So much for PnP. I'll probably just trim the tab on the H4 adapter ring a bit to allow for the projector to be clocked in the right direction.
  5. Dec 26, 2011 at 2:43 PM
    #45
    sparkhill
    sparkhill Well-Known Member
    I am getting ready to do the retro-fit next week on my incoming 2012. I selected to Morimoto Mini D2S with Denso ballasts and Phillips bulbs. I am more concerned with performance and ease of install and less concerned with cost. If I bought the wrong stuff, I don't mind exchanging it.
    Do any of you guys who have been through this have any thoughts or suggestions/tips regarding the equipment and the install?
  6. Dec 29, 2011 at 12:57 PM
    #46
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I'm planning on doing this in a couple days, are there any major differences on the 2012s from how it is explain in the sticky for the older models? It is possible to do this with all the OEM parts right?
  7. Jan 23, 2012 at 10:44 PM
    #47
    sparkhill
    I just finished the Mini D2S retrofit install on my 2012. Other than shaving off the tab of the alignment ring, it was plug-and-play: no housing mods, but definitely not super-easy. I'm not sure I wouldn't just invest in some better bulbs in the stock housing rather than doing the retrofit again. The stock lights were loads better than the ones in my 2002 Tacoma but I need a few days to see how much better I like the retros.
  8. Jan 23, 2012 at 10:48 PM
    #48
    Hydrolai
    Hydrolai Well-Known Member
    Johnny
    friendswood
    trd off road 4x4
    Firestick NGP Uniden 520 PROXL BadaBling! 6k Hid Plasti-Dip Wheels/Badges Leds Bed Lights
    im lovin in man ! looks sick. was the bhlm easy? im worried to do it on mine since ive never bake my lights before... also how do you take off the head lights for the 12?
  9. Jan 28, 2013 at 9:06 PM
    #49
    Pete4757
    Pete4757 Well-Known Member
    Chet
    GA
    2017 4x4 DCSBOR; 2016 4Runner; 2013 4x4 DCSB SPORT
    Tint, Door Sills, OEM bike rack, LED's: Dome, map, and Lic Plate
    x2
  10. Jun 12, 2013 at 2:29 PM
    #50
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    What 'tab' needs to be trimmed for the '12's? The one on the alignment ring and then self align and epoxy into place?
  11. Jun 12, 2013 at 3:13 PM
    #51
    QTacoma
    QTacoma Member
    Q
    Houston, TX
    PreRunner LB
    I just did my retro not too long ago with the same setup as yours and mine look exactly like that. I haven't had time to take them off and align them properly but after seeing how yours turned out I'm going to get on it. Trucks looks good by the way bro. All black everything...
  12. Jun 12, 2013 at 5:25 PM
    #52
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yea that's how I had to do it to get them straight, not bad, but a pita extra step!
  13. Jun 12, 2013 at 5:45 PM
    #53
    ckeene9
    Chesterfield, VA
    See Build Thread
    Thanks, just started BHLM and will be doing the retro in a few weeks (when I have more time for it and hopefully the TRS group buy will be done and shipped).
  14. Jun 12, 2013 at 7:07 PM
    #54
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I did it a little different. I used a dremel and ground a little off of each of the three outer tabs. I didn't have to epoxy anything. You just need to make sure the projectors are good and tight before you reseal your lights.
  15. Jun 12, 2013 at 7:12 PM
    #55
    ckeene9
    Chesterfield, VA
    See Build Thread
    I think I understand what you mean. Guess I'll have to play with it when I get the kit. I only have a day to mess with this so hopefully it's easy to get right the first time.
  16. Sep 17, 2013 at 9:47 AM
    #56
    KENNY
    KENNY Well-Known Member
    Reviving an old post, but about to start this project and was curious if you guys had to modify the shrouds at all to seat properly? I got the Apollo 2's, and before I paint everything want to make sure they dont scratch the bowl if they dont seat right. I see there is a black ring that goes in to slide over the projector, do I just glue them together when seating? This is for 2012 too. Thanks a lot!
  17. Sep 17, 2013 at 9:58 AM
    #57
    fenderpicks
    fenderpicks Well-Known Member
    I have the Gatling gun with my D2S that i am working on right now.
    Fits perfect no cutting needed, and the Gatling sits deeper than the Apollo. So there shouldnt be any cutting with Apollo.
    Also I noticed what these guys are talkng about as well, with the "TILT"
    At first i tried trimming down the H4 Adapter plate from TRS, but it looked rather skinny on the metal after trimming. So instead i filed down the actual reflector bowl tabs. (The tabs that keep the H4 Adapter plate in place.) I believe once the Adapter plate is straight with the line on the back of the reflector bowl, ur rotational should be good)
    But i am not sure if that is how you do the rotational alignment. lol
    Since u have to trim down stuff to make the projector sit in the center, i will be using epoxy to glue the adapter plate in place, so it wont move and throw off the alignment from vibration and what not....
  18. Sep 17, 2013 at 10:09 AM
    #58
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    Damn, looks good man! Can't wait to do my lights. Thanks for taking the time to posting this up so we all can learn from your experience.
