2012 Block Heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snoranger, Dec 8, 2011.
  1. Dec 8, 2011 at 8:13 PM
    Snoranger
    Snoranger [OP] Well-Known Member
    SW Washington
    Silver 2012 TX Pro
    Philips LED Headlights PIAA Xtreme White Fogs Block Heater 30% Tint Decals Removed
    Just put in the Toyota of Canada block heater in my 2012. One thing that I noticed was different than all of the other posts that I've read is how easy they go in. Apparently in 2012 they decided to add a bracket next to where the plug goes into the block. In order to get the plug in, I had to unscrew the bracket, monkey around w/the plug, and then screw the bracket back in. Total pain in the ass especially since you have to turn your hand into a piece of origami to unscrew/rescrew that f'n bolt that holds the bracket...
  2. Dec 8, 2011 at 8:34 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    That must have been a pita! When I did mine a few years back the hardest part of the whole job was finding the mounting hole.
  3. Dec 8, 2011 at 9:57 PM
    Snoranger
    SW Washington
    Silver 2012 TX Pro
    Apparently Toyota had a good idea w/their bracket!
  4. Dec 8, 2011 at 10:14 PM
    OffroadToy
    4X4 Offroad
    So...is this bracket used to hold it in place or is it still secured to the block with the clip on the block heater?
  5. Dec 9, 2011 at 8:58 AM
    Snoranger
    SW Washington
    Silver 2012 TX Pro
    No..the bracket is bolted into the tranny...or starter from what I can tell. All the bracket seems to do is hold the connector for the O2 sensor (I think that's what it is) away from the engine. They put it in the worlds worst place..complete pain in the ass because there's no room to work and the only way to undo the bolt holding the bracket is with a socket wrench...and you can't really turn it more than one clicks worth at a time...HORRIBLE!
  6. Sep 25, 2012 at 2:14 PM
    snopro99
    snopro99 Member
    2 mile high
    Magnetic Gray 2012 TX PRO
    I couldn't get the bolt to budge on the bracket in the way????????:mad:
    The job would take ten minutes top to install if that dam bracket was not there.........:duel:
  7. Sep 26, 2012 at 5:29 AM
    Snoranger
    SW Washington
    Silver 2012 TX Pro
    Did you get that bolt and bracket off so you could get the heater in?...or did it defeat you?
  8. Sep 26, 2012 at 8:29 AM
    exskwid
    exskwid No Man Is Useless That Can Serve As A Bad Example
    NC Mountains
    13 TRD Off Road
    Door Sill Protectors,All Weather Mats, Leather Heated Seats, Hunter Bull Bar, Kobalt Black Slim-Line Tool box.
    How can I get the part number for the kit? I am up in NC mountains and really like my pre-heated ride. I just acquired a 13 DCSB Off Road and I would like to put one in.
  9. Sep 26, 2012 at 8:38 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
    North Carolina?
  10. Jan 27, 2013 at 2:04 PM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Northern colorado
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    I'm also interested in the part number as mydealer thinks I'm crazy for asking about a block heater
