2012+ Clutch Problems
Discussion in '4 Cylinder' started by norcaldude82, Dec 20, 2012.
  1. Nov 23, 2013 at 8:43 AM
    #101
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    First, explain to them what you are experiencing. Second, tell them you are familiar with the problems and TSB for the earlier trucks. Tell them you believe you're experiencing the same problems. Make sure you have the TSB# in hand because they may tell you they've never heard of it. they'll tell you Toyota fixed the problem and the TSB doesn't apply to 2012s. Direct them to this thread if necessary. they have to get approval from corporate to do the repairs under warranty. Push the issue. if corporate refuses, you may be screwed. At 30k, the dealer probably won't cover the cost claiming its a wear item. If necessary, contact corporate yourself. Make it clear that you specifically bought their product so as to avoid problems like this.
    Mine was approved by corporate, but it was under 9k miles when it started slipping.
    Good luck!
  2. Nov 24, 2013 at 6:49 AM
    #102
    jtl2012tacoma
    jtl2012tacoma New Member
    OK, got it. Have an appointment this Tuesday, 11/26/13 at White River Toyota in WRJ, VT. I will report what I learn.
    These are the TSBs I will mention (Please suggest others I should include):
    TSB 3663
    TSB 0066
    Has anyone out there purchased access to Toyota's Technical Information System? (https://techinfo.toyota.com) There is a $15/2-day access, which I'm considering b/c it would be helpful to read the actual text of their TSBs.
    jtl2012tacoma
  3. Nov 26, 2013 at 6:41 AM
    #103
    jtl2012tacoma
    I'm following up on my previous posts on this issue. My local Toyota dealer, who sold me the truck, assessed the situation and said/did the following:
    1) The truck is unsafe to drive - clutch could fail and leave me stranded.
    2) They will repair under T-SB-0066-11
    3) The entire job, including the brand-new loaner (rental) truck will be paid-for by Toyota
    At the time of visit, my 2012 2.7L 5-speed manual Tacoma had about 31,900 miles.
    I have attached scans of their T-SB documentation. Of note is the updated range of years of applicability: 2005-2013. Also, the extent of the repair job is impressive - clutch disk, cover, spring, and... flywheel. I don't see a throwout bearing in that list, but I'm hopeful that they are not foolish enough to do this size job and not replace that item. In fact, I'll check with them to make sure they do, even if it's at my expense.
    jtl2012tacoma
  4. Nov 26, 2013 at 2:06 PM
    #104
    DEZLPWR
    DEZLPWR Member
    Tacoma, WA
    2012 Reg Cab 4x2 2.7L 5spd
    Pro Comp Wheels and 31" Pro Comp M/T tires.
    Hi all, brand new to this site. Bought a used 2012 reg cab 2wd 5spd on Saturday. Truck has only 12,000 mi and is slipping, intermittently, and mainly when you romp on it in 3rd, 4th or 5th or when going up hills. Have an appointment tomorrow at the dealer. Hope I don't get the "cannot duplicate problem" BS since it is intermittent. Thanks for the info though guys and I will report back the outcome.
  5. Nov 27, 2013 at 6:35 AM
    #105
    jtl2012tacoma
    DEZLPWR:
    Mine is 4WD, extended cab, but that difference shouldn't matter WRT warranty coverage. Mine was doing exactly what yours is: I noticed the slipping clutch going up hills in 4th. As the season got colder, I noticed it slipped in 3rd. Of course I then tested it to understand the extreme cases - when would it slip? I never got it to slip in 2nd, for obvious relative torque reasons.
    The language you use when you talk to the dealer may or may not be important. I did not mention TSBs up-front. I just described the problem, which was:
    1) Clutch slipping in 3rd, 4th, 5th (going up hills, when accelerating hard, etc.)
    2) Drivetrain judder/studder on 'taking up drive' (ie. letting clutch out under load) in 1st & 2nd gear.
    T-SB-0066-11 seems to discuss my problem #2 above more closely. I do not know whether that's important, but I mention it in case it's helpful for you.
    Best of luck!
    jtl2012tacoma
  6. Nov 27, 2013 at 8:25 AM
    #106
    DEZLPWR
    DEZLPWR Member
    Tacoma, WA
    Thanks JTL! Took it in this morning. They made a copy of the TSB. Waiting to hear back. I just bought the truck Saturday and this is a reputable dealer. I am confident they will fix it. My salesman assured me they would, and he is not a schmuck. I told him if they don't, they can have the truck back.
  7. Nov 27, 2013 at 5:24 PM
    #107
    DEZLPWR
    DEZLPWR Member
    Tacoma, WA
    Just heard back from the dealer. Good news! They will be replacing the clutch as per the TSB. TSB does not call for replacement of the pilot bearing or throw out bearing so I am paying out of pocket for them. Thanks for the info on this guys!
  8. Nov 27, 2013 at 5:32 PM
    #108
    bzzr2
    bzzr2 Well-Known Member
    let your truck get nice and hot, run it at idle, turn on the a/c; now, do you notice any extra noise coming from under the truck? listen closely, you may notice that the release bearing does have a slight rattle to it. when toyota did my clutch i asked if they were doing the rest and they said yes to eliminate all possibly causes since they had never seen this issue before (dealer here doesn't see many 4 bangers). not long later the noise i talk about was back so the whole transmission was replaced and release bearing/pilot shaft again. no more slipping but noise is back! anyway this might be a way to save a few bucks on your end..
    ask them so see the old clutch, my luk pos clutch pressure plate had warped fingers all around causing the slippage.
  9. Dec 4, 2013 at 8:46 PM
    #109
    DEZLPWR
    DEZLPWR Member
    Tacoma, WA
    Picked up the truck yesterday. Dealer replaced clutch components and flywheel per the TSB. Also a new clutch pedal spring?? I paid for the new pilot bearing and throw out bearing since the TSB does not call for these components to be replaced. So far, everything is great. No more slippage and it shifts great! :D
  10. Dec 5, 2013 at 9:01 PM
    #110
    sodoscott
    sodoscott Well-Known Member
    south california
    2006 tacoma trd off road mid-travel
    kingshocks, total chaos
    Great news ! Congratulation hey how much did you paid? Over all
  11. Dec 6, 2013 at 9:40 AM
    #111
    DEZLPWR
    DEZLPWR Member
    Tacoma, WA
    $83 out of pocket for the throwout and pilot bearings.
  12. Dec 12, 2013 at 2:10 PM
    #112
    sacha7905
    sacha7905 Active Member
  13. Dec 12, 2013 at 6:05 PM
    #113
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    ^Yo, I made a youtube video too and made a thread about it. They took it once for diagnostics, gave it back to me while they ordered parts (master cyl I think, and pedal assembly). Few days later I went to have parts installed, got it back and it squeaked a few days later. A few days after that it was louder than it had ever been.
    I took it back one last time, a week after they replaced parts, tech diagnostic was that the new assembly was improperly greased or something, and I assume he just smeared a ton of lube on it. Hasn't squeaked since. Some others have said, and I fully agree, just DIY lube it and save yourself a ton of time waiting at dealership. It's shitty that it does it in the first place but what can you do.
  14. Dec 13, 2013 at 6:05 AM
    #114
    sacha7905
    What parts did you grease exactly? I've noticed that it doesn't squeak when cold. I woke up this morning ant it was 29 and no squeak. I've read on these forums that the clutches are weak also. Mine hasn't slipped yet but the engagement is horrible and vague(top 1/3 of the pedal travel) and it hates to be rushed between shifts. Nothing like the civic si I had before and that had over 100k on the stock clutch.
  15. Dec 13, 2013 at 2:12 PM
    #115
    sodoscott
    south california
    Same here! Sound like mine
  16. Dec 25, 2013 at 10:52 PM
    #116
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I thought this was normal until my passenger started laughing at me. fuck, looks like I will be taking it in.
  17. Dec 25, 2013 at 11:02 PM
    #117
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    That damn clutch pedal lever is made of plastic. Plastic?!?! Surprised the hell out of me when I found that out one day checking things out. They made the brake pedal lever out of steel, but not the clutch.
  18. Dec 26, 2013 at 5:56 AM
    #118
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My '13 5 speed is not slipping in any gear or situation. But I am curious about the TSB. It says it only applies to 2WD vehicles before the production change with vin#s ending up to 21603. Mine is 22081. I would assume the higher # means my vehicles was produced after any changes were made?
  19. Dec 26, 2013 at 7:49 AM
    #119
    acero12
    acero12 New Member
    seattle
    2012 tacoma 4x4
    2012 I had 30000 and slips the clutch on 4 gear and hills
  20. Jan 17, 2014 at 10:04 PM
    #120
    Mountain girl
    Mountain girl Member
    Duvall Washinton
    2012 toyota tacoma 4x4
    I have an 2012 tacoma 2.7 4 cly. It slips in 4 th and 5 th gear only. The service guy said I'm not driving it right. I laughed and said I had a taco before you were born!! Anyway its under 10,000 miles. Toyed to take it to another dealership, they said I had to take it where I got it from!!! I'm so frustrated !!!!! I bought it a WEEK ago!!
