2012 cruise control
Discussion in '4 Cylinder' started by tlh178, Apr 28, 2012.
  1. Apr 28, 2012 at 7:22 AM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    mich
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    has anyone added cc to there 2012 r/c w/ a manual tranny. i can't believe toyota did not put this on. not to mention the cheap two speed wipers. i would like to replace that at the same time. when you pay 20k for a truck, it should have all the bells and whistle on it. i read alot of threads on this, but can't find anyone who has done a 2012 w/ manual tranny?
  2. Apr 28, 2012 at 7:45 AM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
    I added cruise to my 2012 reg cab. It wasn't pre-wired. I got the wires from Brandon Distributing, the part number was Rostra 250-1836. I think I had to call and order it, it might not be available online. If you go to the rostra web site there are install instructions there . The only other part that is different from the previous years is the steering wheel cover, the part number for that is 4518604030B0. This should be helpful as well, http://www.toyotanation.com/forum/61...e-control.html
  3. Apr 28, 2012 at 9:29 AM
    tlh178
    terry
    mich
    great info ming! by chance do you have a manual tranny. from what i have read, the clutch is a bummer! any tips on that if you do have a stick?
  4. Apr 28, 2012 at 12:30 PM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
    Yes, I have a manual trans. I didn't use the clutch switch. You have to make sure you cancel the cruise or hit the brakes before pushing the clutch in. If you buy the whole kit from rostra it will have the clutch switch and the right plug for it, I think.
  5. Jun 26, 2012 at 10:43 PM
    Catwoman
    Catwoman Twilightmist
    Lori
    California
    GREEN Access cab 4x4 6sp manual V6 TRD
    locking fuel cap, Pop & lock PL5300 tail gate lock, Bak Rollbak G2 hard aluminum tonneau cover, ProTecta Heavy Weight Truck Bed Mat, ScanGauge II
    I want to remove my cruise control on my 2012 manual. I keep bumping it with my knee (I am tall) and accidentally engaging it. Not good while trying to turn and slow down! Weird stuff happens.
  6. Jul 4, 2012 at 6:26 PM
    Dirty Jersey
    Dirty Jersey Rich
    Rich
    South Jersey
    2012 Access Cab - White
    Wet Okole Seat Covers, Debadged, Custom Fit Bed Mat, Cargo Net for Long Bed, All Weather OEM Floor Mats, MX Grillcraft Grill, Bully Tailgate Lock, Mini Mag Center Console Mod, SockMonkey 3rd Brakelight Cover, Lots of Love
    Bought mine for $20,000 with cc. The 2 speed wipers are a pita
  7. Jul 4, 2012 at 6:31 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Wipers are a simple bolt-on mod.
    Cruise control is most likely the same, but we have not had any confirmations of a successful conversion.
    Total for the parts for BOTH modifications is about $250 shipped, plus the cost for the clutch switch for the manuals.
    There are a number of threads on both mods.
    I did both mods on my '08 RC base in my driveway with nothing more than my Gerber multitool and 15 minutes of time, but I did not need the clutch switch for my automatic.
  8. Jul 4, 2012 at 6:36 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    :rofl:
    You can't even get a loaded Kia for 20k..
  9. Jul 4, 2012 at 6:52 PM
    Dirty Jersey
    Dirty Jersey Rich
    Rich
    South Jersey
    The wipers are the only issue so I can deal
  10. Jul 4, 2012 at 7:05 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  11. Jul 5, 2012 at 7:39 AM
    Dirty Jersey
    Dirty Jersey Rich
    Rich
    South Jersey
    Holy crap. Thanks for the link. Wipers look super easy
  12. Jul 5, 2012 at 5:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Very easy.
    Like I said, I did the wipers and cruise in 15 minutes with a multitool.
    Biggest pain on the wipers is getting the assembly to release from the column.
    Look at the new one and study it and it's clips and it'll release.
    You don't need to force it... there's just a "trick" to popping it free.
  13. Jul 6, 2012 at 12:01 PM
    tlh178
    terry
    mich
    as rich said, wipers are so easy. i finally was able to get my cc installed. had to make my own clutch switch wiring harness. seeing how the harness is not on the 2012 tacoma, i took the plastic housing that the two pins set in and cut it right off. then found two female connectors that would fight snugly.
  14. Aug 10, 2012 at 10:02 PM
    BLKHILLSGUY
    BLKHILLSGUY Member
    Michael
    Rapid City, SD
    2012 2.7 liter Access Cab
    Bug guard, killer subwoofer n speakers.
    Ain't that the truth!! I have a 2012 I4 5 speed WITH cruise, backup camera, temp gauge, multi speed wipers. I'd rather Toyota put the money in the important components under the hood and below the truck. If you want the "fancy" extra features, happily pony up for 'em.
