2012 engine crank/turnover problem...help
Discussion in '4 Cylinder' started by sacha7905, May 15, 2014.
  1. May 15, 2014 at 8:22 AM
    sacha7905
    sacha7905 [OP] Active Member
    Updated with video below
    I have a 2012 2.7 4x4 tacoma and am having problems with the engine now that it's getting hot(doesn't happen when cold). It cranks weird when it's hot outside and of course won't do this when I get to the dealer to complain about the issue. I have a video linked to the crank problem. If anyone knows what the problem is please let me know. This seams unacceptable for a 2 year old truck. I'm guessing that it might be the starter or fuel pump? But the odd thing is that it only happens when its hot outside (93 when the video was taken), and if I shut her off and fire her back up she'll crank and turn over normally.
    https://www.youtube.com/watch?v=lqRs1oEDdAg
  2. May 18, 2014 at 8:03 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    Maybe vapor lock...if that is even possible.Not sure.
  3. May 18, 2014 at 8:56 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
  4. May 18, 2014 at 9:00 AM
    sacha7905
    I have an appointment with my dealer tomorrow(its still under warranty). He didn't seem too concerned. Is this maybe just a normal characteristic of the 2.7?
  5. May 23, 2014 at 12:34 PM
    sacha7905
    Bad forum etiquette but, Bump for video of the problem added to my original post.
  6. May 23, 2014 at 3:09 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab 4x4 SR5
    Satoshi grill, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, 2nd air filter delete, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, IronMan Lift Kit, Camburg Ball-Joint UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, G-Tek Fab door sills
    So when it does this, did you start it once before (when the truck is cold), shut it off after it ran for a minute, then start it back up some time (maybe a half hour)? If I do this, my truck will start like this.
  7. May 23, 2014 at 3:21 PM
    sacha7905
    Not exactly. Left the house around 7 it was cool (75 degrees) and it cranked normally. I left to come home in the afternoon (93 degrees) outside and it cranked weird like this. I then shut the truck off waited a couple seconds fired her up again and she cranked up normally. From what I've noticed, it only cranks weird if it been sitting in the heat and humidity for a few hours (it's done this the past few weeks now that it's getting hot). Dealer ran diagnostics but it didn't throw any codes.
  8. May 23, 2014 at 3:32 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My advice is simply to get a OBDII code reader. It's the best $50 you ever spend. Got this one off of ebay. It will tell you exactly what's going on with every component even when there are no codes showing.
    You will never be left guessing... :)
  9. May 23, 2014 at 4:18 PM
    sacha7905
    Thanks. I'll probably invest in one. I'm just mad that the dealer blew off my concern and said nothing was wrong when clearly the crank doesn't sound normal in the video.
  10. May 23, 2014 at 4:52 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab 4x4 SR5
    Okay, I didn't think it was going to be the same, but was just throwing out the idea. I agree with tooter, an OBD reader is always a good investment.
  11. Jun 1, 2014 at 2:00 PM
    tooter
    Greg
    Los Angeles
    You will not believe how much information that scanner can tell you, even pending codes that haven't yet triggered a CEL light. It also shows real time fuel trim input so you can see if you're running rich or lean. It even logs any cylinder misfires as well as which cylinder is misfiring.
    I was totally blown away, as my last code reader was purchased many years ago for my gen1 taco and showed way less information.
    Greg
