2012 factory steering wheel alignment poll
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jholder70, Jan 6, 2012.
Steering wheel alignment
Poll closed Feb 5, 2012.
  1. Perfect
    30 vote(s)
    76.9%
  2. to the left
    5 vote(s)
    12.8%
  3. to the right
    4 vote(s)
    10.3%
  1. Jan 6, 2012 at 12:11 PM
    Jholder70
    Jholder70 [OP] Well-Known Member
    Iowa
    2012 TRD Sport V6 Silver
    Still trying to decide...
    alignment of the steering wheel on you 2012, that is if your driving straight down the road, is your steering will perfect or left or right?
  2. Jan 6, 2012 at 12:19 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    At first I thought it might be pulling to the right, but it was the road camber (slope).
  3. Jan 6, 2012 at 12:20 PM
    RightYouAreKen
    RightYouAreKen Well-Known Member
    Seattle, WA
    '11 4x4 DCLB TRD Sport
    Not a 2012, but my 2011 I bought in September was off center slightly...can't remember which way. Took it back for an alignment and tire balance (had vibes at 65 too) which fixed it.
  4. Jan 6, 2012 at 3:20 PM
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    Mine was off from day 1...took it in today and the techs were surprised...even the rear was off...they're checking all 2012 Tacoma alignments before they go out now.
  5. Jan 6, 2012 at 3:38 PM
    Aw9d
    Aw9d That one guy
    Az
    New 2011 pulled hard to the right on the test drive.. I told them and they said they would check the tire pressure.. Still pulled, took it in and it was way off. All good in the hood now.
  6. Jan 6, 2012 at 3:41 PM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    man i am going to check mine when i get off work in a few days and if its off ima take it right in.....
  7. Jan 6, 2012 at 3:45 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    To me it sounds like this poll is more about the orientation of the steering wheel when driving straight, not about whether or not the alignment is correct.
    When driving straight, my 2012's sterling wheel is perfect, at least I can't notice any orientation issues.
  8. Jan 6, 2012 at 3:54 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    there is no adjustment in the rear:confused:
    Only Independent rear suspension has adjustments. Last time I checked the tacomas had a solid rear axle.
  9. Jan 6, 2012 at 4:01 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
    I'll check when I test drive the Taco tomorrow :D Although I won't be buying the black colored one they current have.
  10. Jan 6, 2012 at 4:34 PM
    Jholder70
    Iowa
    I didn't notice on test drive day... well because it started getting dark.. I am at 500 miles now. the Taco tracks down the road fine, its just that the wheel is ever so slightly not straight, you know the feeling when you drive with a strong wind at your side... My OCD will not let me live with it much more.. calling for an appointment in the morning!!
  11. Jan 6, 2012 at 5:20 PM
    Commanderwiggin
    Calgary
    That's what I said...I'll check the alignment sheet later.
  12. Jan 6, 2012 at 7:09 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    This. Depends on road crown. Roads are not flat, they slope downwards toward the shoulder so that rainwater can drain.
    Four wheel alignment the first time (by a shop that knows what the hell they're doing) is a good idea. Not every frame that comes off the line is perfect, nor every axle housing. Thrust angle is a key spec for a good alignment, not just front end positioning.
  13. Jan 6, 2012 at 8:21 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Tires can have a pull to one side or the other, too. But I've usually experienced that in tires that have some miles on them.
  14. Jan 8, 2012 at 9:12 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The dealer should be checking this before they sell the car, period.
  15. Jan 9, 2012 at 9:25 AM
    jtcskr227
    jtcskr227 Member
    Joe
    Connecticut
    Mine is ever so slight to the left. It is still noticable but better after the dealer did an alignment and balance. I only notice start to pull left at speeds over 55MPH, which is also better but still present after alignment. I guess i'll be going back again for this issue. I thought it may be the tires causing this as it does not pull at all at 45MPH even though the wheel is slightly off.
