2012 fog light mod?
Discussion in 'Technical Chat' started by 2012, Oct 30, 2011.
  1. Oct 30, 2011 at 5:02 PM
    2012 [OP] Well-Known Member
    Garrett
    Colorado
    2012 TRD off road
    I have a 2012 tacoma and I just tried to do the fog light mod(s) that i have seen. my fuse box looks identical so i thought it was worth a shot. I tried the one where you splice into the lime green wire and then bend the prong on the relay- didn't work, so i tried the one where you jam the wire in with the trailer brake- didn't work. More than anything i just want to know what the wire i clipped goes to so that if it ever goes out i know the first place to look. if anyone knows anything, help me out.
  2. Oct 30, 2011 at 6:55 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Get a 2010
  3. Oct 30, 2011 at 6:59 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I'm sorry, I.jm helping. But the truck is too new for anyone to know if they changed anything.
  4. Oct 31, 2011 at 7:26 AM
    Garrett
    Colorado
    2012 TRD off road
    does anyone now what the green wire goes to on a pre '12? I found the fog light relay in the small fuse next to the big one in the engine bay, I'm going run a wire from the relay to said green wire, since it is already spliced. but if anyone has any IDEA, i'll settle for an educated guess, what that green wire goes to I would be most appreciative.
  5. Nov 13, 2011 at 2:37 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    i did some looking and the '12's have an extra fuse box next to the main box, our fog relay is located in there. the relay in our main box in the same location on the older models is now an intake relay.
  6. Nov 13, 2011 at 2:40 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  7. Nov 13, 2011 at 3:26 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    ive read it, i tried it and thats how I found out the 12's fog relay is in the smaller box. i havent tested to see if the light green wire (same as my 12) is the still the fog wire. I need to get some connectors, i will probably mess with it this week. If someone else has a 12 and has done this, feel free to share :gossip:
  8. Nov 15, 2011 at 10:23 PM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    uses the same relays...just have to run the cable between the 2 boxes. got the help from "OLYMPIC VIEW". I also posted pics of my install
    http://www.tacomaworld.com/forum/lighting/132862-fog-lights-w-parking-low-beam-high-beam-8.html#post4039711
    I posted 2 different methods that require no splicing, but require bending tab #1 of the fog relay
    Post #140 is fogs only when parkign/low/high beam lights are on
    Post #141 is fogs anytime the key is in the "ON" position
    both methods turn the fogs off when you shut down the car
  9. Nov 18, 2011 at 5:19 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    Found an even easier way
    edit: just read everything you wrote, i came to the same conclusion on my own lol, but now i see i sure wasnt the first! so hopefully my pic just helps someone else..... where were you 20 minutes ago when i started messing with it!!!!
  10. Dec 7, 2011 at 5:48 PM
    =toytruck=
    =toytruck= Active Member
    Jay
    Canada
    2012 TACOMA
    WTF is this seat htr? I got heated seats but no relay in there? Oh well I'm shoving a wire in there lol
  11. Dec 7, 2011 at 10:18 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
  12. Dec 13, 2012 at 9:57 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Oceanside, CA
    2012 SW Tacoma Sport 4x4
    17x9 XD black wheels, 285/70/17 bfg all terrain ko's, bhlm, afe pro dry s intake, magna flow cat-back with tailpipe cut after axle, all-pro sliders, tailgate theft mod, differential breather mod, hi-lift jack mounts on bed rail, bilstein 5100 with ome 887x springs, tc ucas, led map and dome lights, 35% tint front, 5% rear, cb radio, antenna & pa speaker, grill craft upper and lower grill, bamf light bar behind grill with hella 500ffs, horn relocation, yellow painted fog lights, fog light anytime, 5x D-rings on bed bolts, weathertechs front and rest, salex console organizer, Blue instinct console cover, ATO antenna mount,
    search button...that's how I figured how to do my 2012. I switched the lime green and red/black wires under the small relay box. It's a pita to pull those wires out if you don't have the proper tools. just put the bottom right light green where the top right red/black was and red/black where the green was. No splicing, bending, etc. Clean look, like factory. Will post pictures soon.
  13. Jan 10, 2013 at 8:40 PM
    VinnyMack
    VinnyMack Well-Known Member
    Casey
    Buda, Tx
    07' PreRunner DC LB
    Brute Force Hybrid w/ custom Longhorn cutout, Satoshi w/ Hella 500's, Wet Okole's, Kenwood DDX419 CD/DVD Player, Fog Lamp Mod, BHLM, Blacked-out badges/grill/roof/valence, 5100's up front @ 1.75, 1.25" Spidertrax, TacomaWorld Sticker, extra D-Rings and custom bed mat, interior LED lighting, and Car Seat Mod.
    Hi Nut, this mod is clean but would it be a little safer to put a fuse between the connections?
    Thanks.
  14. Jan 12, 2013 at 7:34 AM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    have a 2013 ac, mind does not have the small fuse box next to the large one. every year toyota changes these things, i guess i leave mind alone and forget installing fog lights. too many people are having problems after a install
  15. Jan 13, 2013 at 7:17 AM
    TOY4JMEBOOZE
    Oceanside, CA
    I will look at mine later this evening and let you know. I'm wiring my hellas today.
