2012 levelling questions.
Discussion in 'Suspension' started by jermoids, Sep 27, 2012.
  1. Sep 27, 2012 at 6:01 PM
    jermoids
    jermoids [OP] Well-Known Member
    jeremy
    Moose Jaw Saskatchewan
    2016 TRD Sport
    nothing yet
    hey everyone, im new on here, lots of good info! i have searched through a ton of threads about levelling and lifts but it's hard to find certain answers when you're scanning through pages and pages.
    all i want to do is level the front of my 2012 tacoma.
    How much does it need to be raised to make it level?
    i have read all the good and bad, mostly bad by the looks of it, with the levelling kits and also a lot about the bilstein 5100s.
    what would be better for my truck in the long run, the bilsteins up front with the stock springs or a spacer?
    also, with the bilsteins, will they raise the front a bit without adjusting them? or do they have to be raised up to .85/1.75 etc?
    im a little worried about having issues that will affect my warranty if i do too much of a lift.
    im only putting 265/70/17 duratracs on so i don't need much of a lift.
    plus i don't plan on doing any 4x4ing other then getting around in the winter.
    any help or advice would be great, and i know there are a ton of threads about this but like i said, it's hard to find certain answers when you are looking through some many posts.
    and im not a mechanic, so sorry if i sound like i don't have a clue.
    thanks,
    jeremy
  2. Sep 27, 2012 at 6:06 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Depending on your cab 5100s set at 1.75 should level it
  3. Sep 27, 2012 at 6:11 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks for the quick reply,
    it's a double cab.
    will i be ok with everything stock at that setting? and im assuming you are saying that is the better option?
  4. Sep 27, 2012 at 6:23 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Better then spacers yes, ya that may still leave you a bit of rake but the 2.5 setting will be too high for sure
  5. Sep 27, 2012 at 6:26 PM
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Seattle area
    2008 AC TRD Sport
    i would set to 1.75 but think you should get a rear tsb. I have 265/70/17 duratracs with no lift and it fits fine.
  6. Sep 27, 2012 at 6:33 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks guys!
    tsb? quick search shows it to be something with the leaf springs.
    can you explain what exactly that is, why i would need them and what could happen if i don't?
    thanks.
  7. Sep 27, 2012 at 6:37 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    hey jared, you wouldn't happen to have a pic of your truck with those tires would you?
  8. Sep 27, 2012 at 7:44 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    You have a 2012 so you may have the "tsb" springs already. All they are is a 4 leaf pack rather then a 3, for the 2005+ trucks people would find a harsh ride or bottoming out with the leaf springs so Toyota put out a tsb (Toyota service bulletin) for them to fix the problem with "tsb" springs. You should have the 4 leaf pack.
    People with the 3 leaf pack usually get them because they add a little extra height due to an extra leaf.
  9. Sep 27, 2012 at 7:57 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thank you,
    just checked and you are correct, i have the 4 leaf pack.
    after some more searching around, it looks like a pretty good setup to do the 5100s all around with the fronts set to 1.75
  10. Sep 27, 2012 at 8:12 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Ya it's a popular choice
  11. Sep 28, 2012 at 9:08 PM
    Jareds Toyota
    Jared
    Seattle area
    2008 AC TRD Sport
    Oh shoot. Sorry my bad
  12. Sep 28, 2012 at 9:11 PM
    Jareds Toyota
    Jared
    Seattle area
    2008 AC TRD Sport
    Here she is.. Procomp 7005s and duratracs
  13. Sep 29, 2012 at 4:42 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 DuraTrac 16X8.5 Level 8 Trackers HID, LED interior, 3" N-Fab step bars
    Most likely the front needs to be raised 1.75". Measure your center hub to fender on both the front and back. The distance in the rear should be about 2" more. So raising the front 1.75" will make it perfectly level. 2.5" will be too much and look stupid.
    I my opinion, just 5100s with the fronts raised 1.75"
    They must be set to raise, if you leave then at 0, they will not raise the front
    Will not impact your warranty. Just have it aligned after you put your 5100s.
    See my write up on the same topic on my truck
    http://www.tacomaworld.com/forum/suspension/239836-i-simply-want-level-my-taco-2.html#post5711649
  14. Sep 29, 2012 at 5:39 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks jared, looks good!
  15. Sep 29, 2012 at 5:43 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks! your truck looks great. all you have done is the 5100s on stock springs with the fronts set at 1.75?
    that's my plan, with duratrac 265/70/17 tires and mayhem riot 8010's 17x8 matte black.
  16. Sep 29, 2012 at 5:51 AM
    757 Taco
    757 Taco StormTrooper
    Tyler
    East Haven, CT
    2012 DCLB TRD Sport 4x4 Super White
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - Tinted Windows 20% Front, 5% Rear Window - White 48-LED Dome Light - Two 12-LED Map Lights - Sylvania Silverstar Ultra Headlight Bulbs - LED License Plate Bulbs -20" LED Lightbar - 886 Reverse Light Mod - FogLight Anytime Mod - AFE ProDry S Drop-In Air Filter - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's - Wheeler 1.5" Progressive AAL - TRD License Plate Brackets - Front Recovery Shackle - Black LED Tail Lights - Toyota Bed Mat - LED Third Brake Lights - Sockmonkey Bedside Decals - 285/75/16 Goodyear Wrangler Duratracs - Procomp 7089's - Rear Diff Breather Mod - FlyzEye V1 - Grillcraft w/ FJ Emblem - Removed Sway Bar - TRD Auto Shift Knob - TRD Offroad Transmission Skid - Hose Clamp Mod
    check out my build. running billys in the front @ 1.75". sits level, looks great, rides very close to stock. also im running 265/75/16 Duratracs on Procomp 7089's
  17. Sep 29, 2012 at 6:24 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    looks awesome, the exact look im going for, thanks!
  18. Oct 2, 2012 at 2:24 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    has anyone experienced any issues with re-alignment having the 5100's set and 1.75?
  19. Oct 2, 2012 at 2:57 PM
    757 Taco
    Tyler
    East Haven, CT
    i told the guy at the shop i had my setup mounted and balanced to give it an alignment and when i came back he told me that he honestly didnt think it needed one. my tires are wearing nice and even and it rides very straight so i guess he was right.
  20. Oct 2, 2012 at 5:27 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    cool, thanks.
