2012 lift help (here we go again)
Discussion in 'Suspension' started by idoctr, Feb 12, 2012.
  1. Feb 12, 2012 at 6:44 AM
    idoctr
    idoctr [OP] Member
    Mississippi
    2012 TX TRD
    I have a 2012 trd, 3 leaf rear, want 3" lift (or so) . plan on 5100 all around,AAL, do i need brake extensions or diff.-drop. Some say i do and do not. Also I was told I would need a longer shock for rear. please help !
    Want to order something just don't know what. Thanks.
  2. Feb 12, 2012 at 11:19 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Brake lines are not needed with that set up and the diff drops do nothing for 2nd gens! You'll be under 3" with all that so nothing to worry about. The 5100s in the rear are fine up to 2" and as long as your not flexing them out hard you should be fine. I'd go with the 1.5" aal to stay even with the front!
  3. Feb 12, 2012 at 11:29 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    A little rake isn't a bad thing, otherwise you'll get bro lean under load.
  4. Feb 13, 2012 at 3:02 PM
    idoctr
    idoctr [OP] Member
    Mississippi
    2012 TX TRD
    I was told i would need longer shocks for rear with AAL? and I will not need difff.-drop and rear brake ext.?? Just want to be sure before i order.
    Thanks for help.
