2012 lift install help please!
Discussion in 'Suspension' started by knine00, Feb 25, 2012.
  1. Feb 25, 2012 at 4:25 PM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    I got a strap. I will give that a shot. I should have done this upgrade at the M&G huh ajohnson! LOL
  2. Feb 25, 2012 at 4:30 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Is the nut on tight? You should be able to crank on it some more with a socket to pull it down
  3. Feb 25, 2012 at 4:45 PM
    knine00
    Hudsonville, Mi
    Stock for now
    So I tried the strap and a block of wood w/floor rack. No luck although I got closer just not close enough. Any other ideas
  4. Feb 25, 2012 at 4:52 PM
    tbturner47
    you've got the nut on the threads right? Looks like it in the pic.
  5. Feb 25, 2012 at 4:55 PM
    knine00
    Hudsonville, Mi
    Stock for now
    yeah I have torqued the nut down as far as I can!
  6. Feb 25, 2012 at 5:01 PM
    knine00
    Hudsonville, Mi
    Stock for now
    what do you guys think about a smaller castle nut?
  7. Feb 25, 2012 at 5:07 PM
    tbturner47
    What ft lbs is as far as you can? When I did mine it wasnt easy but once the nut was threaded I just cranked on it a good bit.
    Set your torque wrench to 100 and see if it clicks. If it does then idk what to tell you besides strapping/jacking them together. If it aint clicking then keep turning.
  8. Feb 25, 2012 at 5:16 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You need to keep pressure on the ball joint going inside the tapered hole of the spindle to keep it from spinning. Try pushing the UCA down onto the spindle with your bottle jack against the top of the inner fender, just use care that it doesn't slip off and hurt you. Eventually the ball joint will get tight enough to stop spinning and you need to torgue it to atleast 45 ft-lbs.
  9. Feb 25, 2012 at 5:20 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    This.
    As far as getting that bolt through I've done my LR UCAs twice on each side. Each time I used channel locks to pull the sheet metal out and then just beat the bolt out with a punch from the other side.
    That gap should be fine once you use all washer provided PLUS stock washers and torque the UCA bolt. Don't forget, only torque it once it's sitting on its own weight.
  10. Feb 25, 2012 at 5:21 PM
    knine00
    Hudsonville, Mi
    Stock for now
    did yall ditch the sway bar?
  11. Feb 25, 2012 at 5:22 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Yes i did, with the coilovers it doesnt "feel" any different. Some guys leave them some take them off
  12. Feb 25, 2012 at 5:23 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I did like 20k miles ago but I have stiff 886 coils.
  13. Feb 25, 2012 at 5:30 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    id you cant get the old bolt out, how are you going to get a new one in without cutting the fender?
  14. Feb 25, 2012 at 5:33 PM
    ajohnson
    Andy
    Charlotte, NC
    The factory inserts the bolts through the front of each mount. When reinstalling you can push them in from the rear. There is a lot more room on the back of the coil buckets.
    I used channel locks to bend the sheet metal enough to get the factory bolts out and reinsert them through the rear of the mounts.
  15. Feb 25, 2012 at 5:34 PM
    #35
    TrdSurgie
    TrdSurgie revised
    Oahu
    oh ok cool. Thanks.
  16. Feb 25, 2012 at 5:37 PM
    #36
    knine00
    Hudsonville, Mi
    Stock for now
    Alright I got the factory cotter pin in with a ton of sweating! I am going to ditch the sway bar for now! Thanks for the help guys. Anyone know a good alignment place for tacoma around raleigh fayetteville or goldsboro area? Also, anyone know the torque spec for the steering knuckle?
  17. Feb 25, 2012 at 5:41 PM
    #37
    ajohnson
    Andy
    Charlotte, NC
    Good job man. It can be a PITA. Make sure to torgue it when its back on the wheels and retorgue everything after 100 miles.
    Oh, and the long mounting bolts need to be torqued at ride height, otherwise you will tear the rubbing bushings.
  18. Feb 25, 2012 at 5:52 PM
    #38
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    118 ft lbs for the two lower 19mm bolts holding the LCA balljoint to the knuckle. 45 ft lbs for the upper ball joint to knuckle, then enough to get the cotter pin through. 150 ft lbs for the LR UCA ball joint jam nut. 85 ft lbs for the UCA to the frame bolt/nut.
    I'll say it again, the UCA to frame bolts need to be torqued only when the truck is sitting on it's own weight, just tighten them up a little to let the truck down.
  19. Feb 26, 2012 at 7:23 AM
    #39
    knine00
    Hudsonville, Mi
    Stock for now
    I got everything together for the front lift last night! Thanks for the help. I am starting the back today which includes billy 5125 and icon 3 leaf progressive retaining the overload leaf!!!! Any helpful hints would be great. Thanks again
  20. Feb 26, 2012 at 9:35 PM
    #40
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    I'm a mechanic what I've always done is got a pry bar under the uca then back to the top of the strut an push up then use my impact an tighten it always works for me
