2012 Mirror into 2009+ Truck, wiring in TEMP/Homelink
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackSeven, Feb 17, 2012.
  1. Feb 17, 2012 at 7:54 PM
    BlackSeven
    BlackSeven [OP] Grab your helmet, this shits about to get retarded
    Maryland
    '10 Reg Cab 4x4
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    Whats covered in this guide:
    Running Homelink and Temp output to the 2012 Mirror in the 2009+ trucks.
    What's not covered:
    How to install the mirror itself. This is covered in other places on the forum. I'm also not going to go over the wiring diagram itself or how to disassemble your truck. These will be the pinouts only. The wiring diagrams can be difficult to read and it's my goal not to confuse you.
    Parts Needed:
    For Reg cab only:
    1x Pin kit for connector A-14 P/N 82998-12870 + Press Sleeve (Crimp) 8299-12020
    For all trucks:
    2x Pin kit for connector I8 82998-24290 + Press sleeve 8299-12020
    (these are used to get a wire into the connector, their use is pretty straight forward, you crimp in your wire and insert it into the blank pin where specified)
    Some Automotive thin gauge stranded wire available at any autoparts store. You'll need about 10 feet for Regular cab trucks. Much less for V6 trucks.
    Various taps/crimp connectors.
    In 05-08 trucks, the temp sender will not work, at least I haven't found a way to make it work. It's a two wire resistor type temp sensor meaning you have two wire inputs (+/-) that need to be connected to the temp display.
    2009+ Trucks looks for a temp on a single wire in pin 12 of connector I8, this connector is found in the headliner of all 2009+ trucks (reg cab, dbl, access). This is the connector you'll plug into your new mirror to get your 2012 mirror working with the back up camera.
    The only problem is the 2009, 2010 and 2011 are missing this circuit from I8. These circuits exist in the v6 trucks in plug A28 Pin 5 that plugs in to your overhead console to display temp. This circuit is completely missing from the regular cab trucks. FEAR NOT MORTALS FOR I HAVE A SOLUTION FOR ALL OF YOU!
    On the V6 trucks you simply tap into the wire that runs to your overhead console temp display(Pin 5, connector A 28) and run it down to pin 12 of your I8 Connector. Very simple.
    For the Regular cabbers like myself, we'll need to get a little more involved. You can get the temp signal from Pin 27 of Connector A-14 at the A/C Amplifier. The bad news, is this connector is up under the dash. You'll need to run this wire through the dash to the pillar and up into the headliner to get it over to pin 12 on connector I8.
    To get homelink to work you need to run 12v+ Constant to Pin 8 of the I8 Connector, I'll leave it up to you where you want to get this from. I recommend the cabin light, that way if you need to open your garage without the key in the ignition you can. You may choose to run this to ignition powered source so if someone breaks into your truck they can't get into your house without the key.
    Hope this helps. Let me know if you have any specific questions about the modification. I figure if it's there, it should be fully functional. If you somehow manage to destroy or fry your truck, that's your problem. I'm assuming you have some basic automotive electrical skills. :)
    tbird95 and DistortedAxis like this.
  2. Feb 17, 2012 at 8:00 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Great guide!
  3. Feb 17, 2012 at 8:20 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    subbed.
  4. Feb 17, 2012 at 9:29 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Nice write-up! Even after 6 months of driving this truck, I still find myself looking at the mirror to see what the outside temp is since that's how my last vehicle ('04 Wrangler) had it. This mod is definitely on my list.
  5. Feb 19, 2012 at 9:17 PM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Also, if you're looking for the cover that covers the wire from the mirror to the headliner, the part number is 87818-04010, shouldn't run you more then 8 dollars, if you pay more they're ripping you off!
  6. Mar 26, 2012 at 9:34 AM
    DelTaco
    DelTaco Well-Known Member
    Jeff
    DELAWHERE
    '21 TRD Sport DCSB
    To get Homelink to work with the ignition "on" can i just tap into the thick green wire in the I8 connector and bridge it to pin 8? If that makes sense..
  7. Apr 6, 2012 at 10:29 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Blackseven, many thanks for posting this as I have been wanting to try this for some time.
    One quick question, is the A-14 connector tough to find and identify? Any quick tips?
  8. Apr 6, 2012 at 11:17 AM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Pull off your glove box and look up under there, there will be a black box with a connector plugged into it, That should be A-14.
  9. Apr 6, 2012 at 12:40 PM
    Tunngavik
    Alberta, Canada
    Many thanks Mike - I look forward to ordering the parts and getting this done!
  10. May 26, 2012 at 4:30 PM
    Tunngavik
    Alberta, Canada
    I just tried this mod on my 2010 4cyl access cab and it didn't work (at least the temperature does not read out and there are only 2 bars where the temp should be displayed). The compass and backup display does work.
    To confirm, you use 2 terminal repair wires (Part #'s 82998-24290, 82998-12870), connect these to pin 27 on A-14 and pin 12 on I-8 and then run a thin gauge wire between the 2 connections.
    For pin 27 on A-14 is there any other existing wires in the connector? It's really tough to determine the pin #'s on the connector - the one I used was free but had wires on either side.
    Any advice you can give?
  11. Jun 2, 2012 at 7:37 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    bump for an answer
  12. Jun 2, 2012 at 8:17 PM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Sorry we were talking via pm. I tried using a 2012 temp sender to see if I could solve the problem. Thats not the solution. They're the same part. I need an oscilloscope to really find the problem ... And correct it. I think its a difference between what the ac amplifier is putting out and what the mirror is looking for signal wise. If I had a 2012 wiring manual I could probably come up with a solution. I only have the 2009 manual.
  13. Jun 2, 2012 at 8:29 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    sounds good. I know im in no rush but i would like to know what comes of it whenever you figue it out
  14. Jun 4, 2012 at 8:31 AM
    Tunngavik
    Alberta, Canada
    How much does the wiring manual cost? Can you buy portions/sections of it? Please let me know as I'm really interested in finding out if getting the temperature to work is possible.
  15. Jun 4, 2012 at 10:21 AM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Normally it would be here: http://www.helminc.com/helm/search_service_owner.asp?Style=helm&class_2=TOY
    But I don't even see the 2012 listed yet.
    The 2009 manual I have I got lucky and picked it up on ebay for about 40 dollars. Alternatively the techinfo.toyota.com site will give you access for 15 bucks for 48 hours. It has the information, but I've extremely frustrated using this site as I can't save anything if I need to reference it again later. So I refuse to use it at this point. They may feel their information is invaluable, but I paid alot of money for my truck. I feel that this information should be free to owners.
  16. Jun 6, 2012 at 7:41 AM
    Tunngavik
    Alberta, Canada
    When the 2012 diagrams do come out, and you feel confident that you would be able to figure out how to get the temperature readout to work, then I would be willing to throw in a few bucks for the diagrams.
  17. Aug 24, 2012 at 8:03 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    i cant seem to locate the:
    "Press sleeve 8299-12020" on Champion, can someone point me to this part?
  18. Aug 24, 2012 at 8:15 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I am having more issue with the mirror's harness trying to figure out what the 12 wires are for. I need the pins for connector I8 detailed. I don't see them.
  19. Aug 25, 2012 at 7:16 AM
    jassco
    NH
    2023 TRD Offroad
    There are 9 wires used in the 2012 I8 connector on the truck. There are 12 pins in the mirror harness which all go into the mirror and are filled. This leaves 3 unused wires. The wires in the mirror harness unused are as follows:
    Pin #4: Orange
    Pin#5: Red
    Pin#10: Purple
    Now to figure out what what the mirror wold use these for as the truck doesn't seem to output to them as factory configured. I wish gentex had pinouts for these mirrors on their site.
  20. Aug 25, 2012 at 7:32 AM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    I cut a Target pill bottle (plastic) in half (or more) and painted it black until I found the cover. I think I paid like $13. or so.
