2012 mirror swap.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajan246, Feb 16, 2012.
  1. Nov 6, 2013 at 6:10 PM
    #41
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    So after a long workday I came home to find the Mirrors w/ turn single from parts geek came in so I took some pics. Front and back then the outers are after I took the mirror out and back off and the wire harness. I hope this just will be a plug and play.
  2. Nov 6, 2013 at 6:41 PM
    #42
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    Looks plug and play to me
  3. Nov 7, 2013 at 7:55 AM
    #43
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    dave what was the total $ out the door for all your stuff...
    i really want to do this but just cant muster up the nads to drop the cash... yet.
  4. Nov 7, 2013 at 1:10 PM
    #44
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    The parts came to 169.01 out the door. And i just ordered some paint to match the truck. will post pics when done.
  5. Nov 7, 2013 at 1:21 PM
    #45
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3
    I just ordered a set as well. Was it difficult to take it apart to paint?
  6. Nov 7, 2013 at 4:26 PM
    #46
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    It was a little tricky. I don't know your experience level. Ive been a mechanic for 14 years so it was not that hard for me. But if it's to tricky for you I would use the painters tape and spend the time to tape it off real well and paint it that way.
  7. Nov 7, 2013 at 5:48 PM
    #47
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Tacos (Sport edition) earlier than '12 never had integral blinkers in their mirrors, I wouldn't count on the wiring being in place for a swap.
  8. Nov 7, 2013 at 7:39 PM
    #48
    B737
    Kevin
    Jersey Shore
    stock
    my understanding was to go from stock mirrors to these sport mirrors it was right around $500 in parts... i also believe it will be P&P...
    you need sport mirrors plus covers... $250 a side?
  9. Nov 8, 2013 at 6:18 PM
    #49
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    Thats if you buy them from Toyota I bought mine off of part geeks or geeks part they are OEM style. and there is one more web site that has the mirrors but no pic so i did not buy and that is Go Parts. you should check them out and save some money.
  10. Nov 9, 2013 at 9:58 AM
    #50
    B737
    Kevin
    Jersey Shore
    stock
    No freaking way? That's awesome. How's the quality?
  11. Nov 9, 2013 at 7:15 PM
    #51
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    Really good I can't tell the difference in them, when I held them together. I'm going to do the switch in two weeks or so. I will post pic of the of the two tougher.
  12. Nov 12, 2013 at 4:38 PM
    #52
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    I have some bad news the mirror does plug right in but it does not play? the turn signal does not come on? I've tried every thing i can think of the only thing that i might try is to call a dealer and see if the ECU needs to be reflashed. so it will recognize the mirror turn signals. does any one have any outer ideas?
  13. Nov 12, 2013 at 4:54 PM
    #53
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Bought, not built:-P
    You sure you're pre-wired for it?
    If the power mirror adjuster works, only thing I can think of is that it's missing the wiring from the fuse/junction box on the driver side, to the plug on the door.
  14. Nov 12, 2013 at 4:55 PM
    #54
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ^^^This
    i highly doubt the turn signals are wired to the ecu some how...
  15. Nov 12, 2013 at 5:35 PM
    #55
    B737
    Kevin
    Jersey Shore
    stock
    There is a DIY somewhere in the forums. Wire Tap into your signal wire near the cabin fuse box. You'll get them to work
  16. Nov 12, 2013 at 5:57 PM
    #56
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    I agree with you but i was just throwing out ideas, and hoping something will come to mind.
  17. Nov 12, 2013 at 5:59 PM
    #57
    BovaTaco
    BovaTaco Member
    Dave
    New Jersey
    TRD off road
    The mirror does work. do you know where the the wiring from the fuse/junction box on the driver side is?
  18. Nov 12, 2013 at 6:31 PM
    #58
    itsmekyle
    itsmekyle Well-Known Member
    Orange County
    05 Prerunner SR5 White
    So for those of us who it is not plug and play for, there are 2 missing wires. One for the ground and one to the fuse box correct? I understand that I need to "tap into" the turn signal wire in the fuse box? Would I just need to buy extended wiring from somewhere like Home Depot and extend the wire from the door harness to the ground and fuse box? Just want to be clear before I dive into it.
    Thanks for the help.
  19. Nov 13, 2013 at 6:59 PM
    #59
    itsmekyle
    Orange County
    Bump.. Looking to do this tomorrow and was hoping someone may have recently done it as well. My main questions are:
    1. Do I need to purchase more wiring to extend from the mirror harness to the fuse box? If so, what kind?
    2. How do I tap into the existing turn signal wiring to allow the mirrors to work in sync with the turn signals?
    Thanks again guys.
  20. Nov 13, 2013 at 7:09 PM
    #60
    kas930
    kas930 Member
    Keith
    SC
    12 4x4 DBL Cab TRD OffRoad
    For my 2012 OFF Road, this is exactly what I had to do. I posted a wiring diagram of what I found in a previous post. The door wiring was intact, and the wires were present in the fuse panel but missing somewhere in between. Ground the white black wires on each side and tap into the pink and blue / white wires.
