2012 Off-Road upgrade?
Discussion in 'Suspension' started by DoorDing, Jan 22, 2013.
  1. Jan 22, 2013 at 9:07 PM
    DoorDing
    DoorDing [OP] Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    The current OR 3-leaf rear springs are a joke, and while the truck does ok stock, I'd like a smoother ride off pavement. After pouring over several threads, I think this set up will work for me. It's my daily driver, so it needs to ride comfortably on the road. I may carry around 500 lbs of cargo and tongue weight (pop-up camper) on trips. No serious rock crawling, no jumping; I want to be able to drive rough mountain & desert mining trails.
    This is basically the suspension Miles used for his 2005 build. I'll likely order from DSM and work with Sonny to figure out valving and coils, and anything else they recommend. I'd like to stay around a USD$2500 budget. Suggestions are welcome.
    Front
    Fox Racing Toyota Tacoma 2005 - Current Extended Travel Factory Series Kit, Fox Part# 880-02-418-A
    Light Racing Upper Control Arms
    Wheeler's Off-Road SuperBumps - installed
    Extended brake hoses
    Rear
    Fox Racing Toyota FJ Cruiser 2009-2007 Rear Shock, Fox Part# 980-02-417-A
    OME CS047 2.75" lift Dakar Leaf Spring Set
    Timbren SES - installed
    Extended brake hoses - 2 for the OR rear, iirc
  2. Jan 22, 2013 at 9:29 PM
    Manwithoutaplan
    ID
    Not bad you can also look into all pro leaf pack.
  3. Jan 22, 2013 at 9:34 PM
    DoorDing
    Bodie, CA
    yes
    The All-Pro Expedition springs look like a good choice, too. Thanks.
    I better put longer brake hoses on the list, too.
  4. Jan 22, 2013 at 9:35 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Not sure on all the part numbers and all, but overall this looks like a pretty good setup. Downsouth Motorsports also makes UCA's for a pretty good price I believe.
  5. Jan 22, 2013 at 9:39 PM
    DoorDing
    Bodie, CA
    yes
    I'll see what DSM says. I want a ball joint UCA, and I like that the LRs are adjustable. Not bad for $375. Are there any other adjustable UCAs available?
  6. Jan 22, 2013 at 9:46 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Hey doording, I'd look at DSMs build your own mid travel package, you can get everything you have there and then give Sonny a call and he will give you a great deal. I called yesterday for my setup and he beat the cheapest price I could find by almost $200
  7. Jan 22, 2013 at 9:56 PM
    Redfox1
    Conner
    Camburg, DSM, ICON, only ones I can think of off the top of my head. Just saw a feeler for some used UCA's somebody wanted to sell on here I think...
  8. Jan 23, 2013 at 10:13 AM
    DoorDing
    Bodie, CA
    yes
    Thanks guys. Since I've read that the rear FJ shocks work better with the valving tweaked for the Tacoma, I'll be going through DSM for sure. I haven't read a bad word about them yet, and they seem to have the expertise to put together the right package for me. My only complaint is that the way their website is set up makes it difficult to build a package by part number.
    On rear springs, is there much of a difference between the Dakar and All-Pro Expos? I think the Dakars offer a little less lift, which is fine with me. DSM carries them, so unless there's a significant advantage with the All-Pro Expos, I'll probably go OME.
  9. Jan 23, 2013 at 10:18 AM
    Monster Coma
    Corey
    Some people have problems with the Dakars going flat under a lot of weight. Not all bit some. And the expos offer a little more lift. So if you don't want a cap and don't plan on adding a ton of weight to the back then Dakars should be fine.
  10. Jan 23, 2013 at 10:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I carry 450 lbs at all times , my Dakars settled just under 1" from when I installed them 2 years ago with that amount of weight , they rebound back to their original height when I remove my tools ( about 250lbs ) of that weight
  11. Jan 23, 2013 at 10:23 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build
    excuse my ignorance but why fj shocks on the rear of the tacoma??? not to thread jack jsut have never heard of this til now.
  12. Jan 23, 2013 at 10:57 AM
    Manwithoutaplan
    ID
  13. Jan 23, 2013 at 12:21 PM
    OZ-T
    Peter North
    British Columbia
    or Dakars
  14. Jan 23, 2013 at 4:35 PM
    DoorDing
    Bodie, CA
    yes
    Thanks to all for the advice.
    TacoFMS, the FJ model shocks offer more travel than the standard Tacoma model. All it takes is a little bit of work to modify the bushing, and valve adjustment for a better ride. HBMurphy and Milowilli are happy with the results. If DSM recommends against using them, I'll go with something else.
    Jasmine, thanks for the advice. Since the majority of the time I won't have a loaded bed or be towing, I'd prefer the lift height of the standard All Pros, which seem similar enough to the Dakars that it's a wash. My camper only has a 200 lb tongue weight, I have aluminum skids, and my Softopper only weighs 30 lbs. Like I said, I've kept an eye on weight. Since DSM only carries Dakars and they're good enough for Canadians, I'll go with them.
    Gelo760, I already have SuperBumps front, Timbrens rear. I decided on Timbrens for the rear for more support in case whatever springs were installed needed the help; the OR leafs sure do. If I decide they're a problem, I'll put the Timbrens on my camper and buy SBs for the truck's rear. I don't believe TC makes a ball joint UCA, and I don't want a uni-ball.
  15. Feb 5, 2013 at 9:46 PM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 Sport
    All stock
    Looks like we are going for the same thing with the mid travel! How do you like your superbumps? This thread is definitely sub'd :popcorn:
  16. Feb 6, 2013 at 2:53 AM
    DoorDing
    Bodie, CA
    yes
    I haven't had the SuperBumps on long enough to have much to say about them. On stock suspension, they just barely touch the frame, and I haven't felt any jarring from the front end. Since I know they're making contact, that's a good indication that they're providing a smooth response.
