2012 ONLY Hewitt-Tech Secondary Air Injection Bypass kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 12TRDTacoma, Aug 19, 2019.
  1. Nov 14, 2019 at 5:41 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    I have a 2012. The valves and pump was replaced by Toyota under warranty. They are still covered until 2022 under the extended warranty issued on them by Toyota. I was wondering if they might fail again past that. What exactly does the bypass kit do? And what else would one need to use the kit?
  2. Nov 15, 2019 at 8:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They will fail again. It's not an IF, it's a WHEN situation really. I have heard of the valves failing a few tens of thousands of miles after warranty replacement. It's just a bad design and a bad operational strategy by the PCM to operate the air pump system almost specifically on the 12s, but the 13-15s have issues as well. Near identical actually but these kits are designed for 2012s only.
    The bypass kit essentially deletes the entire kit without having to do any removal work of the system and prevents the check engine light from turning on by fooling the PCM.
    Nothing else is needed to run the kit other than the air pump check valve lines block off plates which you can get from @Roostfactor for pretty cheap. Install it, then forget it. You will never have to worry about stuck valves or triggering limp home mode ever again.
  3. Nov 16, 2019 at 9:29 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Bump
    I'm surprised this hasn't sold. Toyota's extended warranty replaces a bad designed pump with the same bad designed pump. This kit eliminates it entirely...
    GLWS
    12TRDTacoma[OP] likes this.
  4. Nov 16, 2019 at 9:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am surprised as well honestly and I'm really starting to think it's a lost cause trying to sell it. Then again I don't think a lot of people even know this item exists. So... Thanks for the free bump!
    vssman[QUOTED] likes this.
  5. Dec 3, 2019 at 11:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bumping this again. I'm wondering if the thread needs a rename so people understand what the item is actually for.
  6. Dec 9, 2019 at 9:35 AM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    He has kits for 13-15 as well!
    Well worth the purchase before truck goes into limp mode!
  7. May 19, 2020 at 5:18 PM
    mylilyota
    mylilyota Member
    Just got new pump valves and hoses all placed through toyota free of charge for my 2012. Would ahve been qround $1600 - ouch. You still got this? I never want to think about this ever again.
  8. May 19, 2020 at 5:25 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I may be mistaken, but i believe i have this kit on my truck now
    Edit: im going with hptuners in the next few weeks so will possibly be parting with it in a few weeks.
  9. May 19, 2020 at 7:01 PM
    mylilyota
    mylilyota Member
    cool, let me know.
  10. May 19, 2020 at 7:26 PM
    mylilyota
    mylilyota Member
    Has anyone ever actually had one of the newer systems replaced by toyota and it fail. theyve supposedly addressed the issue with the replacement system.
  11. May 24, 2020 at 1:04 PM
    lunalobowolf
    lunalobowolf Well-Known Member
    New Mexico
    2012 TRD Offroad DCSB
    Just bought it last week, just tinted the windows and added the paint protection for hood and front bumper. Installed weather tech digital floormats, the rearview mirror extender (from this site), an Optima battery with custom tray, TRD oil cap, rad cap, TRD supercharger!!! Ya!!! Just this week $3710.00 plus $690.00 installed in El Paso, TX at Hoy Fox Lexus Dealership, TRD exhaust, Airaid cold air intake waiting in box in garage, Amsoil Dual Filter remote with 42 Design Oil catch can still to install. Need advice on URD Y-Pipe???? Have URD Welbro fuel pump to install also but want help. Have to sell the mid-mount light bar from (Pelly off this site) never opened it, still in box, but decided to go a different route $100.00 takes it plus shipping in USA.
    Is this still for sale?
    PM me and I’ll take it if so
