2012 Rattles.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnnief, Feb 1, 2012.
  1. Nov 12, 2012 at 3:51 PM
    yellowrubiu
    yellowrubiu Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    The rattle is still there but not worse. I have a sloped driveway and have noticed that it only happens when the truck is parked on the steepest part of the driveway, nose in. If I'm on level ground no rattle at all so I'm not paying attention to it anymore.
  2. Nov 12, 2012 at 4:24 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    I noticed a rattle on the right hand side of the front passenger side seat/door area. It sounded plastic-plastic and would have a 2-4 bounce/rattle every time I went over a bump. Started the day I got the truck.
    While doing my audio install, I took the cover (plastic interior trim piece) off the lower half of the passenger seat belt. I didnt remove the cover completely, just detached it to run cables. I noticed there are two white plastic snap pins that fit into holes in the frame/body. One was not in all the way....this was the bounce/rattle.
    I detached the driver's side and noticed the panel/piece was "in place" a lot better than the passenger side. I could replicate the bounce rattle by undoing one of the snaps.
    Hope this helps someone....if you need a pic, lmk via PM and I'll take one when its light out.
  3. Nov 12, 2012 at 5:02 PM
    2Low8
    2Low8 Active Member
    TN
    2012 4wd SR5 DC
    I've got very annoying rattles from both front windows near top of window seal. New truck w/ a little over 1k miles. Anybody got a fix?
  4. Nov 12, 2012 at 5:19 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    This rattle is probably coming from your seat belt attachement arm.
    I searched for like a month in mine before I found it. When the squeek happens, just take the seatbelt attachment mechanism, and move the entire assembly up and down all the travel. It will fix it for a week. LOL
  5. Nov 15, 2012 at 6:17 AM
    2Low8
    2Low8 Active Member
    TN
    2012 4wd SR5 DC
    Anybody have any answers to the window rattling? It's as bad as my 2002 BMW that had 230k miles. And it's brand new.
  6. Nov 15, 2012 at 6:26 AM
    rexel
    rexel Well-Known Member
    I've have this exact same sound that I've been chasing for a year now....I hope this is what's causing my noise, I'll have to check it tonight when I get home.
    Thanks.
  7. Nov 15, 2012 at 12:29 PM
    Thelt
    Thelt Well-Known Member
    Lenoir, NC
    '12 4x4 SR5
    I had an annoying rattle that I fixed by stuffing some felt between the windshield and the dash......
  8. Nov 15, 2012 at 2:37 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    Is your sound like a sticky or pulling tape off kind of sound? Hard to describe, mine is not a rattle per se, sounds like the weather stripping sticking and pulling away from door jamb. I went to dealer and got in a '12 and it did the same thing. I think it is the type of weather stripping yota used. I have tried armor all on every piece of weather stripping to no avail.:rolleyes:
  9. Nov 15, 2012 at 2:57 PM
    JustinKeillor
    JustinKeillor Member
    Justin
    Chico CA
    2012 Tacoma 4x4
    16x8 American racing wheels,265 /75 16 toyo mt's, 3 inch suspension lift , side steps, all deflectors , flow master exhaust, k&n intake, diamond plated toolbox, all custom mats inside and dash kit
    I had that issue as well on the driver side when I turne the radio up to not even half way, they did not seem to hear it when I took it on but I could! Not to many good things to say about my local Toyota service department but I fixes it myself, love my yota ! Can't have any rattles I'm to picky
  10. Nov 15, 2012 at 5:32 PM
    2Low8
    2Low8 Active Member
    TN
    2012 4wd SR5 DC
    Yeah, it sounds like the window is moving in the weather stripping and the weather stripping is moving around with it. I can press the window towards the outside of the truck and the sound stops. I tried using a silicon lubricant on all the weather stripping and it did not help whatsoever.
  11. Nov 15, 2012 at 5:50 PM
    conquistador
    conquistador Well-Known Member
    Tulsa, OK
    88 4Runner
    The damn center of my dash rattles every time I hit a bump. This started with only 1500 miles on the clock. Very annoying. I have an appt scheduled next week at the dealer. I am very skeptical to take anything to these idiots. They normally cause more damage then good. Anyone else experiencing this dash rattle and any remedies out there?
  12. Nov 15, 2012 at 7:01 PM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    11K miles on my '12 and no rattles at all. Damn, hope I didn't just jinx myself. . . .
  13. Nov 15, 2012 at 9:51 PM
    ElkHunter
    ElkHunter Member
    Mark
    Oregon City, Oregon
    2012 TacomaAccess Cab SR5 4x4
    Ditto...
  14. Nov 25, 2012 at 2:41 PM
    2Low8
    2Low8 Active Member
    TN
    2012 4wd SR5 DC
    My dash just started rattling as well. If I push on the aircon controls it stops. It seems they're loose on one side. And yeah, I took my truck to the dealer for window rattles and tire vibration and they fixed neither and haven't called me back about it. Best of luck to ya.
  15. Nov 25, 2012 at 2:48 PM
    #35
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    I am starting to get worried on my 13' I'll pickup in january all these negative things I have read are making me paranoid I bought it out right I wanted to keep it forever but all these threads on bad stuff WTF.
  16. Nov 25, 2012 at 3:56 PM
    #36
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    My rattle is somewhere in the drivers side door, sometimes. I went from a 1993 Ranger that rattled everywhere to a 2012 Tacoma brand new. The Ranger never really bothered me but every little sound out of the Taco seems so annoying. The 4.0L (and holey exhaust) in the Ranger did a pretty good job of drowning out weather stripping sounds, ha.
  17. Dec 19, 2012 at 3:16 PM
    #37
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    hey anyone with 2012 or older hear a noise when accelerating? I have never had a vehicle that ping'd so idk what it sounds like. But on my 12 if i just smoothly roll the throttle on till it shifts i get a wierd rattling sound. i run 91 only in my truck and it still does it... dealer gives me same line every time.. "we cant re-create it so we cant do anythign about it" which i understand but it bugs me..
  18. Dec 19, 2012 at 3:30 PM
    #38
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Mine rattles too. I will keep taking it back until they do something that fixes it.
  19. Dec 22, 2012 at 4:50 PM
    #39
    2Low8
    2Low8 Active Member
    TN
    2012 4wd SR5 DC
    I am as well. Keep me posted if they fix anything.
  20. Dec 22, 2012 at 4:54 PM
    #40
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    Toyotas rattle.. it's what they do and have always done. Pro Tip: Never take your dash apart, it makes it worse.
