2012 sluggish after oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StinkPickle, Sep 4, 2019.
  1. Sep 6, 2019 at 4:24 PM
    #41
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The alternator voltage is regulated by the ECU. Unless the alternator is failing there will be no harm. The modules are usually designed to run to run off varying voltage. I believe they can be rated to 18v, perhaps even up to 24v. Unless the full wave rectifier is failing and AC is making its way into the system, everything is pretty well protected. In fact that’s one helpful thing a battery does perform is helping to eliminate pulsating DC currents/AC currents.
  2. Sep 9, 2019 at 11:52 AM
    #42
    StinkPickle
    StinkPickle [OP] Well-Known Member
    Brandon
    SuperWhite 2012 TRD OR
    3" OME
    Wow baking soda works awesome. Thanks for the tip. Waiting for the sealant\gasket maker to cure on the roof rack while it rains all this week. Hopefully runs better. It was starting to run better but not like it was before I removed the cables.
  3. Sep 9, 2019 at 1:32 PM
    #43
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Oh---Oh It's like a BAD WRECK -- I can't stop looking... hideous - LOOK AWAY! :notsure:
  4. Sep 10, 2019 at 8:08 PM
    #44
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Alternator voltage is regulated by the Voltage Regulator Circuit inside the alternator... Just for accuracy.
    https://www.customtacos.com/tech.ol...6toyewd/06toypdf/ewd/2006/tacoma/h/em01d2.pdf
    TnShooter likes this.
  5. Sep 11, 2019 at 2:04 PM
    #45
    StinkPickle
    Brandon
    3" OME
    Truck ran waaay better today after cleaning with baking soda. Thanks for the advice
