2012 stock ride height
Discussion in 'Suspension' started by geoff7877, Sep 16, 2012.
  1. Sep 16, 2012 at 5:37 PM
    geoff7877
    geoff7877 [OP] Well-Known Member
    Petaluma, CA
    2012 SR5 4X4 Double Cab
    Between all 4x4 options, (and I guess prerunner) is the stock ride height the same between a base model, SR5 and TRD Off Road? I would assume the sport is higher to support the 17" wheels.
    I guess I could do a deep search but I'd rather have someone bitch that I didn't do a search! :D
  2. Sep 16, 2012 at 5:39 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The TRD Sport tires and the TRD Offroad tires are the same diameter
  3. Sep 16, 2012 at 5:39 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    SR5 has 245/75/16 tires and TRD off road has 265/70/16 so I wouldn't think it would be same height
  4. Sep 16, 2012 at 5:40 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    no. just cause the wheels are bigger does not mean you need a larger lift. the sport has a smaller aspect ratio on the tire. aspect ratio is the second series of number on a tire size designation... for example
    245/75/16 same as a 265/70/17
    245/265 is width in mm, 75/70 is the percent of 245/265 which accounts for the sidewall height, then the rim size. notice how the percentage is different? that accounts for the size difference of the wheel so the overall height is the same
  5. Sep 16, 2012 at 5:44 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    When using the tire calculator they come out to be the same. I am no tiremathologist, but I believe OZ-T is correct.
  6. Sep 16, 2012 at 5:47 PM
    jtgroce
    jtgroce Got R Did
    I too believe OZ-T is correct but on TRD Sport/OR those tires are 265/70/16 and 265/65/17 right? How would a 245 be same height? Although it is a 75 series
  7. Sep 16, 2012 at 5:57 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  8. Sep 16, 2012 at 6:02 PM
    TeamLombardo
    Tony
    El Paso
    Mine is a TRD O/R and it came with 265/70/16. When comparing mine against the 245/75/16 they come out to be the same diameter. 245 is the width, not height.
    Pretaco explained it here. Look at his post
  9. Sep 16, 2012 at 6:12 PM
    jtgroce
    jtgroce Got R Did
    Ahhh I see, makes sense
  10. Sep 16, 2012 at 6:15 PM
    TeamLombardo
    Tony
    El Paso
    Yeah, its a common misunderstanding. I fell victim to the numbers as well, but that was when I was like 16 :ohsnap:. :D
  11. Sep 16, 2012 at 6:26 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Any height variation between 245X75-16 and 265X70-16 is going to be very small, so your speedometer readings will remain fairly close.
  12. Sep 16, 2012 at 8:15 PM
    geoff7877
    Petaluma, CA
    So suspension (lift) wise, they're all the same set up pretty much? Great info by the way. Thanks for the great answers!
  13. Sep 17, 2012 at 9:55 PM
    Larry
    Larry CARL
    CARL
    my 2012 Sport w/ tsb is approx 1.5" higher in the rear than my 2010 SR5 was before tsb.
  14. Sep 18, 2012 at 3:00 AM
    cleveland48
    cleveland48 Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    I just measured my 2012 dcsb TRD off road.
    Front dr side 20.25
    Front pas side 20.50
    Rear dr 21.50
    Rear pas 21.50 mine has the 3 leaf pack is this bout normal? Needing to know gonna call today and check on a 1.5 AAL and 5100's set at 1.75. I wasn't sure how to measure so I measured center of wheel to center of fender. Thanks for any help
  15. Sep 18, 2012 at 3:16 AM
    TeamLombardo
    Tony
    El Paso
    A recommended way of measuring is from hub center to bottom of fender edge/lip.
  16. Sep 18, 2012 at 3:20 AM
    cleveland48
    Andrew
    2012 TRD Off Road
    Does those measurements seem to short to u Lombardo? I was just trying to get ball park just got off work and it's dark out side also what to u think of the 1.5 AAL and 5100 set at 1.75?? Should be pretty close maybe little nose high u think?
  17. Sep 18, 2012 at 7:06 AM
    OZ-T
    Peter North
    British Columbia
    20 - 20 1/4" is pretty standard hub to fender up front for a stock Tacoma
  18. Sep 18, 2012 at 7:18 AM
    Larry
    Larry CARL
    CARL
    2012 4x4 Sport
    hub center to fender (approx)
    front = 20 1/4"
    rear = 22 1/2"
  19. Sep 18, 2012 at 3:06 PM
    jtgroce
    jtgroce Got R Did
    Heck I've been 16 for the past 15 yrs now :yay:
  20. Sep 18, 2012 at 5:36 PM
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    2012 SR5 4 x 4
    Center of hub to wheel well
    Front = 20 1/2
    Rear = 22 1/4
