2012 Tacoma 3" Lift What's the largest tire I can run?
Discussion in 'Suspension' started by RUQWKNF27, Feb 3, 2012.
  1. Feb 3, 2012 at 10:25 AM
    RUQWKNF27
    RUQWKNF27 [OP] Member
    ALABAMA
    2012 Tacoma
    From just what I have seen a 285/65/18 is a good size to run. But also wondering about a 295/70/18 . I really do not want to start cutting on anything to make it work. The truck is a 2wd and will never be offroad.
  2. Feb 3, 2012 at 10:26 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    I am pretty sure you are going to have to cut with both the sizes you listed but I could be wrong. You won't notice that you need to trim until you had a speed bump or are at full lock in reverse.
  3. Feb 3, 2012 at 10:29 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    you can fit 315/90/16's no problem. just a little nip and tuck here and there
  4. Feb 3, 2012 at 10:31 AM
    motorsport36
    motorsport36 Morto un papa, se ne fa un'altro
    Furnace, AZ
    2016 Tacoma TRD Off road 4x4 DCLB
    I have 3 inch toytec with TC UCA's and run 285's with no trimming and I don't rub at all. Could go 315 with some taken off here and there
  5. Feb 3, 2012 at 10:36 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You can run 295s with tons of trimming... I run 285s and I still rub with the amount of trimming I've done..
  6. Feb 3, 2012 at 12:16 PM
    XXXX
    sKiP
    05 Prius
    The problem with all these answers is they are mostly misleading - thus my BS first post.
    People say they don't rub, but never tell you they have never taken their truck offroad or their caster is set at 4* so they don't rub.
    My truck rubs the rear of the fender running 265/70/17 with 2" of lift (Kings) and TC UCA's.
  7. Feb 3, 2012 at 12:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Dont you mean .4*?
  8. Feb 3, 2012 at 12:21 PM
    XXXX
    sKiP
    05 Prius
    I'm 99.9% sure I mean 4.0*
    I'm currently at 2.4* and rub like a SOB. I was much better at 2.9 - 3.0*
    I know a guy who said he is at 4* so he doesn't rub his monster tires :D
  9. Feb 3, 2012 at 12:21 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I'm running 255/85/16s (a hair taller than 285s) on 1st Gen TRDs with no cutting, chopping or rubbing. And yes I go off road.
  10. Feb 3, 2012 at 12:22 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    People who say they don't rub with 285's are blowing it out their ass. You WILL have to trim. Some people go as far as doing a cab mount chop.
  11. Feb 3, 2012 at 12:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah. Ok. I was thinking you had stock UCA's May bad.
  12. Feb 3, 2012 at 12:24 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Those tires are also more narrow...
  13. Feb 3, 2012 at 12:27 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Don't you have some odd caster setting right now ?
  14. Feb 3, 2012 at 12:27 PM
    OZ-T
    Peter North
    British Columbia
    Nevermind , lol
  15. Feb 3, 2012 at 12:28 PM
    4Wheelin4Banger
    Randy
    Yes I know 255 < 285
    :facepalm:
  16. Feb 3, 2012 at 12:32 PM
    XXXX
    sKiP
    05 Prius
    Oh I do have stock UCA's....they just aren't on me truck :D
    derp
    I agree. "Web wheelers" don't rub with 285's.
    Where's Ant when you need him? He has 3" lift, 1" body lift, cab mount chop, pinch weld beat in, and still rubs when we go out wheeling with his 285's.
  17. Feb 3, 2012 at 12:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cookiemonster:
  18. Feb 3, 2012 at 12:44 PM
    XXXX
    sKiP
    05 Prius
  19. Feb 3, 2012 at 12:46 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I didn't have any rubbing with 285's at full stuff full lock. I did with 315's even with glass. I would suggest 285's.
  20. Feb 3, 2012 at 10:47 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I had a little rubbing with 285s stock TRD 16s and spidertrax but not much. That was full stuff moab.
