2012 Tacoma and 4Runner VVT-i Engine Differences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saf023, Mar 11, 2012.
  1. Mar 11, 2012 at 8:41 AM
    saf023
    saf023 [OP] Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    The 2012 4Runner says it come with a 4 liter, DOHC 24 valve engine with Dual Independent Variable Valve Timing with Intelligence (VVT-i). The 4Runner 2012 engine makes 270hp and 278 lb-ft or torque at about 400 higher RPM as compared to a 2012 Tacoma. The 2012 Tacoma 4 liter, DOHC 24 valve engine, however, is discribed as a VVT-i and makes 236 hp and 266 lb-ft of torque.
    What is "Dual Independent Variable Valve Timing with Intelligence" and is the 2012 4Runner engine the same engine that is in the 2012 Tacoma?
    The 30 hp and 40 lb-ft torque increase increase is not a trivial improvement. I'm thinking the improvement is the result of some induction and exhaust tweeking and a difference cam and tune but I'd like to know for sure. The Toyota sales people certainly don't know and you can only believe half of what they say. Does anyone know what the difference is?
  2. Mar 11, 2012 at 9:12 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    1GR-FE
    [​IMG] [​IMG]
    1GR-FE 4.0 L V6 from a 2007 Toyota FJ Cruiser
    The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. An updated version of this engine features Dual VVT-i, increasing output to 254 hp (189 kW) and 270 lb·ft (366 N·m) on 87 octane and 285 hp (213 kW) and 289 lb·ft (392 N·m) on 91 octane. Inside, the 1GR uses a "taper-squish" combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc.), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are two such passages for each bank for a total of four. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
    A bolt-on TRD supercharger kit is available on the Tacoma and FJ Cruiser.
    Applications (with VVT-i) in model years:
    Applications (with Dual VVT-i) in model years:
    [edit]
  3. Mar 11, 2012 at 11:59 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    I was under the impression dual vvti had vvti on intake and exhaust cams.
  4. Mar 11, 2012 at 12:03 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    yup and the vvt-i we have is intake cam only.
  5. Dec 23, 2015 at 8:37 AM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Has anyone ever done or seen a 1GR-FE Dual VVTi engine swap into a 2nd gen? What would need to be done to get it to work?
