2012 Tacoma Fog Light Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rotorheader, Nov 26, 2011.
  1. Nov 26, 2011 at 9:13 PM
    Rotorheader
    Rotorheader [OP] Active Member
    Don
    Eugene, OR
    2012 Prerunner 4-cyl
    I had a request to post a couple pictures of the fog light plug. I'll give it a try now.
    Diameter on the back side of the plug is 3 3/4"
    The tabs on the side is 4" on center. Two screws on one side, and the other side just has two slide-in tabs.
  2. Jan 4, 2012 at 4:53 PM
    myersct99
    myersct99 New Member
    Warner Robins, Ga
    Rotorheader, did you add aftermarket foglights to your 2012 Tacoma?
  3. Jan 5, 2012 at 7:28 PM
    Rotorheader
    Don
    Eugene, OR
    I haven't done it yet. Searching on eBay, it looks like a pair of Camry lights might work. In a little while, I'll go by the used car lot with my tape measure and find out.
  4. Jan 23, 2012 at 7:33 PM
    Cobalt719
    Cobalt719 Well-Known Member
    Chesapeake, VA
    '12 4 Banger PreRunner DC
    LED Interior Lights, Tailgate Anit-Theft Mod, OEM Skid Plate, Aftermarket Fogs, Tow Hitch
  5. Jan 23, 2012 at 8:49 PM
    Rotorheader
    Don
    Eugene, OR
    The inserts are held in place with a pair of phillips screws, and slots on the opposite side. If you turn your wheel full to one side, you can get a light and mirror up in the wheelwell and see what's up. I'm still waiting for Toyota to make an OEM set of fogs. I looked at the setup on eBay, and can't quite see how they would install behind the bumper
    If you try 'em, let us know how they install
  6. Jan 24, 2012 at 11:30 AM
    Cobalt719
    Chesapeake, VA
    Cool thanks, I may have to try them. The descriptions says satisfaction guaranteed so if they don't mount right I would probably just return them. I don't suppose you happened to notice if the wiring was there when you pulled the plugs out?
  7. Jan 25, 2012 at 10:37 AM
    Rotorheader
    Don
    Eugene, OR
    Not pre-wired that I saw.
  8. Jan 26, 2012 at 6:15 AM
    Cobalt719
    Chesapeake, VA
    Okay I did some more research and looked for people who purchased the lights and asked for their feedback. I got two very different responses. I asked the person with the positive experience for more info. It could be the person that sent them back did not want to do the work.
  9. Feb 2, 2012 at 5:34 PM
    wvgoofy
    wvgoofy Well-Known Member
    scott
    charleston west virgina
    2014 tacoma TRD sport Debadged
    /husky liners/speed dog shifter knob
    you can buy just the lights from toyota at 180.00 a light. 360.00 for two lights. holy crap:eek::rant::rant::mudding:
  10. Feb 10, 2012 at 7:35 AM
    ajan246
    ajan246 Well-Known Member
    Orange County, CA
    2012 Access PreRunner V6 2WD
    any update on this? I'm wanting to add fogs to my 2012. Did the Camry lights fit? Any ideas if any other car fogs fit? highlander/venza?
  11. Feb 10, 2012 at 9:09 AM
    flyingpostman
    flyingpostman Well-Known Member
    Richard
    Caledon, Ontario
    2012 Double Cab, SR5
    I ordered the Blinglights kit supposedly for the 2012, but I was sent a 2011 kit (or there never was a 2012 to begin with). Being in Canada it isn't worth the hassle sending it back. The problem is that even if the lights are the right size (the 2011's are bigger as I'm sure you know) there isn't a very good way to hold them in there unless you have the proper housing mount which of course isn't a straight forward affair. You probably won't get them to fit nicely, or even straight in the plastic housing that surrounds the bulb. I bit the bullet and ordered two fog lights from Toyota and use the wiring that came with the blinglight kit. The lights of course are back ordered.
  12. Feb 10, 2012 at 12:37 PM
    Cobalt719
    Chesapeake, VA
    What was the model on the bling lights you got? I just got mine yesterday. I think they are the bl300w or something to that affect. I was gonna try an install tomorrow.
  13. Feb 10, 2012 at 4:50 PM
    flyingpostman
    Richard
    Caledon, Ontario
    I ordered:
    "2012 2013 2014 Toyota Tacoma Xenon LED Fog Lamps Driving Lights Foglamps Foglights Drivinglights Kit"
    I don't have the box in front of me as it is at work. The kit I received does certainly not fit the 2012. As I mentioned it is not all lost as I can use the wiring, relay, and switch and still save hundreds of dollars over the whole kit from Toyota. Granted the switch isn't as nice, but still.
    Unless they provide a proper mounting bracket/housing which I highly doubt, the whole kit they send is mickey-mouse at best (the lights themselves look ok). They should make it clear on their website that they don't provide proper mounting brackets/housing.
  14. Feb 11, 2012 at 7:47 PM
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    Nice thread. Looking to add fogs to mine as well. Subscribed.
  15. Feb 11, 2012 at 7:52 PM
    Cobalt719
    Chesapeake, VA
    Okay so I got the fogs mounted. Took me longer to take the bumper off than it did to mount them and put the bumper back on cause there were some catch point with retaining clips I couldn't figure out. Alas i got it put back together now just working out the wiring. I'm attempting to use an OEM switch for the fogs and a rocker switch for the secondary blue lights. I'm getting help from someone else on the forum to get the wiring straight. Once I get it all setup I'll post some pics.
  16. Apr 22, 2012 at 6:59 PM
    wvgoofy
    scott
    07/11 camry kit fits with a little mod,on tabs on fogs and extending 2 wires for the switch. I used the whole kit:cool:
  17. Apr 22, 2012 at 8:46 PM
    TNDrew
    TNDrew Well-Known Member
    Drew
    Chattanooga, TN
    '12 Reg Cab 4x4 Silver
    WeatherTech DigitalFit Liners, Bench Seat Angle Fixed, Fog Lights (Nokya 2500k HyperYellow bulbs), aFe ProDry drop in, DeeZee bed mat, UWS black low pro tool box, Marathon Seat Covers (ordered should arrive mid-May). iSimple iPod adapter, Blacked out badges, SockMonkey WhiteTail Toyota Horns decal, LED Dome and License Plate Lights (LEDSolutions), Black Headlight Mod,
  18. Sep 18, 2012 at 6:36 PM
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    Are there any updates to this mod?
    I am looking to do this for my new 2013 Tacoma.
    Thanks and great information.
  19. Sep 18, 2012 at 7:47 PM
    us3rname
    us3rname Member
    El paso
