2012 TACOMA FRONT END CONVERSION RG11
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11T4x4TRD, Sep 1, 2013.
  1. Feb 27, 2019 at 12:16 PM
    #321
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    For those doing the front end conversion, how do you get DRL to work. Is running an extra wire required? Also, I'm guessing it is necessary to install a new turn signal stalk with DRL on the headlight switch?
  2. Feb 27, 2019 at 12:30 PM
    #322
    Armedine
    Armedine Well-Known Member
    St George, UT
    2020 TRD Sport 6' 4WD
    Quicksand
    If you're talking about something like this it's plug and play with manually engaged DRL, no extra wires.
    If you meant the automated DRL mod for the brighter lights, that's this mod using a kit.
  3. Feb 27, 2019 at 12:32 PM
    #323
    bradforj
    TN
    07 4x4 v6 TRD Sport
    I am planning to use OEM headlights. I thought they had DRL, right?
  4. Feb 27, 2019 at 3:10 PM
    #324
    Armedine
    St George, UT
    Quicksand
    They do. You don't have to change anything if you want the stock DRL. The headlights are plug and play.
  5. Feb 27, 2019 at 3:38 PM
    #325
    bradforj
    TN
    07 4x4 v6 TRD Sport
    Wouldn't I at least need a new stalk on the column with the DRL light position?
  6. Feb 27, 2019 at 4:13 PM
    #326
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, the 2012 didn't have it, that was added in 2013 and let's you turn gen on or off. My old 2010 had DTRL that you couldn't turn off
  7. Feb 27, 2019 at 4:20 PM
    #327
    bradforj
    TN
    07 4x4 v6 TRD Sport
    Ok, just one more question. If I put headlights from a 2015 on my 2007, the DRL will stay on all the time?
  8. Feb 27, 2019 at 4:22 PM
    #328
    TireFire
    Olympic Peninsula
    Not sure, the lights will function exactly as the ones you have now because the plugs and bulbs are the same.
    Do you have DTRL now?
  9. Feb 27, 2019 at 4:26 PM
    #329
    bradforj
    TN
    07 4x4 v6 TRD Sport
    No, not currently.
  10. Feb 27, 2019 at 4:37 PM
    #330
    TireFire
    Olympic Peninsula
    Then you won't have it post conversion either unless you do the flasher relay mod. Adding the 2013 stalk that lets you turn the DTRL on and off is probably more work than reward.
  11. Feb 28, 2019 at 9:13 AM
    #331
    bradforj
    TN
    07 4x4 v6 TRD Sport
    When buying the fender liners, be sure to buy the correct ones. There are differences depending on whether or not you have fender flares.
  12. Mar 1, 2019 at 7:57 AM
    #332
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    Updated today: 3/10/2019
    In case anybody wanted a quick reference guide on what you need to buy with working ebay links
    , I just put this together today with everything I used on my truck so there's no guarantees the items won't sell out in the future.
    Headlights -
    Hood -
    Hood Scoop -
    Hood Scoop Grille -
    Grille -
    Hood Latch Support -
    Hood Latch -
    Fog Lights -
    Headlight Mount Tabs (You'll need 2x) -
    Plastic Mount Tab For Bumper Fillers (You'll need 2x) -
    Lower Bumper Brackets Inner (You'll need 2x) -
    Lower Bumper Brackets Outer -
    Upper Bumper Retainer RIGHT -
    Upper Bumper Retainer LEFT -
    Front Bumper, Reinforcement, Left and Right Upper Support Brackets, Center Support Bracket, Headlight Fillers, Bumper Flares, Bumper Grille -
    Bumper Flare Clips -
    Other things you'll need are the clips/nuts to hold the hood scoop bulge on.
    You'll also need metal rivets to attach the bumper brackets to the reinforcement.
    Also if you want it here is the TRD Pro grille insert -
    And finally, it's not a requirement and I didn't replace mine, but if you want the fender liners to fit to the bumper properly you'll need these.
    LEFT -
    RIGHT -
    Clips For Liners
    (Because they will break) -
  13. Mar 1, 2019 at 8:35 AM
    #333
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    How long have you had your headlights installed? I'm considering that style but I'm worried they will yellow over or peel faster than OEMs. I was going to try the OEM Pro lights but they are a dark grey, not black. I have TacomaBeast lights and they have been fine for a year but I think halogens are brighter with a reflector rather than projector.
  14. Mar 1, 2019 at 10:08 AM
    #334
    YotaProject
    Adrian
    Charleston SC
    I was looking at the same set on Tacoma beast, only reason I didn’t go with them is because I wanted a set of lights without orange marker reflectors. These I bought off eBay and probably won’t last as long as OEM but as of right now seem to be holding up. They’ve been installed almost a year.
  15. Mar 1, 2019 at 11:16 AM
    #335
    Minny Taco
    Minnesota
    I really like the look of those, I just bought 'em so if they've been OK for a year that makes me feel better. I'm going to seal the edge just in case. Too lazy to BHLM my OEM lights or I'd go that route instead.
    YotaProject[QUOTED] likes this.
  16. Mar 5, 2019 at 11:59 AM
    #336
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    @YotaProject Thanks for that list kind sir, going to pull the trigger on this soon and your list is fantastic!
    Tacolvr79 likes this.
  17. Mar 5, 2019 at 8:27 PM
    #337
    Tacolvr79
    Tacolvr79 Well-Known Member
    Ben
    Missouri
    09 TX TRD Pro 6sd with 12+ conversion
    Complete interior and exterior led conversion, TRD short shifter, 12+ interior upgrades (steering wheel etc) aftermarket double din touch screen, marbled Sickspeed shift knob, blacked out headlights, taillights, and 3rd brake light, painted pinch welds, taco bed mat, taco all season mats, tonneau cover, charcoal filter delete, towing plug relocation bracket, '12 baja suspension, 12+ front end conversion, 30" led lightbar in lower grille, Meso interior lights, more to come...
    Ordered everything to do this yesterday. With a nice raptor style grille insert with tacoma lettering and 30" light bar for the bumper it was right over $1500 in parts. Not too bad! And since my dad owns his own autobody shop, i will be painting and installing it all myself :thumbsup::bananadance::bananadance::bananadance:
    drewskie and YotaProject like this.
  18. Mar 5, 2019 at 9:06 PM
    #338
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    And you can sell your old parts for more mods :D
  19. Mar 6, 2019 at 5:19 AM
    #339
    YotaProject
    Adrian
    Charleston SC
    Awesome man, post it up when you start the project :thumbsup:
  20. Mar 6, 2019 at 2:39 PM
    #340
    kyson_carpenter
    kyson_carpenter Member
    Kyson
    2006 Silver Tacoma
    Still looking for a hood it’s all I lack. How many people are ordering the hoods from eBay? Are they all coming damaged or are some of you guys lucky and not have any damage. Looking for hood with scoop since I already have the scoop insert sitting in its package.
