2012 Tacoma Issue...Help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fsfty, Apr 19, 2012.
  1. Apr 19, 2012 at 12:15 PM
    fsfty
    fsfty [OP] Active Member
    I have 5,000 miles on my 2012 Tacoma, and I've noticed that when Im idling at a light, I will sometimes see the RPMs increase a little bit for like 5 seconds, and then return back to normal. If I don't have my foot "firmly" on the brake, I will actually move forward a little. Is this common? Am I just too light on the brake? Any advice would be appreciated.
  2. Apr 19, 2012 at 12:17 PM
    fsfty
    AC isn't on...I would say the increase is from 500 RPM to like 800 RPM...
  3. Apr 19, 2012 at 12:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    As the dealership would say..."Normal".
  4. Apr 19, 2012 at 12:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    Your AC will engage whether it's on or not. The lurch you feel is the tranny down shifting into first.
  5. Apr 19, 2012 at 12:19 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    does it do it more when cold? see if it happens when you slightly turn the wheel. as soon as there is any sort of pull on the power steering your rpm will bump up a bit.
  6. Apr 19, 2012 at 12:20 PM
    fsfty
    LOL...no, just a slight increase while idling...Im new to Toyota, and I feel like the brakes are kinda mushy. My bro has a Tacoma too, and he thinks the same thing. Maybe its more of getting used to the brakes (putting more pressure on them) than anything else???
  7. Apr 19, 2012 at 12:22 PM
    fsfty
    So my situation is normal then???
  8. Apr 19, 2012 at 12:23 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Really sounds like the defrost is on. Defroster will cause A/C compressor to run.
  9. Apr 19, 2012 at 12:24 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    What model is it? My 07 does that at the light sometimes. I never noticed any increase in rpm's though. I was told it is the LSD engaging. :confused:
  10. Apr 19, 2012 at 12:25 PM
    fsfty
    well, I do leave it on defog (defrost???) ... that would cause this???
  11. Apr 19, 2012 at 12:27 PM
    xmadcowx
    xmadcowx Old man club. Sold out to Ford.
    Connecticut
    19 Raptor/21 Bronco. 12 OR sold. 05 xrunner sold.
    Functional
    I have the same thing. At first I thought someone was nudging me from behind, even though I felt no impact, the truck lurched forward ever so slightly. Now I just lay into the brake when I'm stopped.
  12. Apr 19, 2012 at 12:30 PM
    g35man
    League City, TX
    2012 MGM DC 4x4 OR
    LOL! yup :)
  13. Apr 19, 2012 at 12:34 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    If you turn the fan on with the vents set to Windshield or Windshield + Floor, it will cause your A/C compressor to run, also causing the ECU to bump your RPM a little bit to compensate.
  14. Apr 19, 2012 at 12:36 PM
    fsfty
    Thanks...didn't realize this. i will set the vents to the floor and see what happens.
  15. Apr 19, 2012 at 1:13 PM
    2012 Well-Known Member
    Garrett
    Colorado
    2012 TRD off road
    I know EXACTLY what your problem is...you drive an automatic.
  16. Apr 19, 2012 at 2:40 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    This happened in the first week I got my truck. It happened at night and I was at a set of train tracks waiting for the train to pass. I had thought that the truck behind me had rolled into me, we were on a small hill. I pulled over and checked after and nothing. It doesn't from time to time and mostly I don't notice. A weird feeling if you weren't use to it that's for sure.
  17. Apr 19, 2012 at 7:05 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It's normal man. My 06 did it, and my 09 does it. It still gets me sometimes. Lol like mentioned before, its either the compressors or torque converter since I've noticed with the A/C on and off.
  18. Apr 19, 2012 at 7:41 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Next time you are at a light take your hands off the wheel and see what happens.
  19. Apr 19, 2012 at 8:13 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Every Toyota I have owned has done this, starting with my 99 Camry. It's a Toyota thing...you'll learn to love it...
  20. Apr 20, 2012 at 3:18 AM
    Squirrellydw
    Squirrellydw Well-Known Member
    2012 PreRunner TRD Sport
    really? How often does it run, enough to affect gas milelage?
