2012 Tacoma steering wheel cocked to the left, when driving straight.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by highflyinmechanic, Apr 8, 2012.
  1. Apr 8, 2012 at 11:22 AM
    highflyinmechanic
    highflyinmechanic [OP] Well-Known Member
    Justin
    GA
    12 DBL CAB MGM 4x4 TRD OFFROAD
    Well after 2,500 miles since day one my damn 2012 Tacoma's steering wheel is cocked to the left while driving straight and true down a level flat road. Thought it was just me imagining things/ or the interstates slope I was driving home from the dealership on had something to do with it. Its brand new no mods done to it. I guess ill be paying the local dealership a visit in the morning and also gonna try and address the 3 leaf packs in the rear as well and get the TSB done. I guess the guy installing the steering wheel was more concerned about getting off that Friday afternoon than making sure the freakin steering wheel was put on the correct way.
    Has anyone else experienced this? Is it a pretty easy fix for the dealership to perform? ( Remove/Reinstall steering wheel)? or could it be an alignment issue?
  2. Apr 8, 2012 at 11:43 AM
    feyded
    feyded Member
    Whidbey Isle, WA
    2012 Toyota Tacoma TRD OR
    How many degrees off is the steering wheel from center?
    The dealerships I talk to say its a fairly common problem with the tacomas they see in among other issues they are brought in for, it should be a minor fix, my roommates was the same way(2012 access cab prerunner).
  3. Apr 8, 2012 at 11:45 AM
    highflyinmechanic
    Justin
    GA
    I would say mine is at the 10 O'clock position driving straight. Its enough to bother me for sure lol.
  4. Apr 8, 2012 at 11:55 AM
    feyded
    feyded Member
    Whidbey Isle, WA
    My frontier was the exact same, a little less. I took it in for my free oil change and had them fix it. Took 30 mins for oil change and fix. The problem for both my roommate and I was that it was not aligned properly at the factory, they gave both of us sheets showing the before and afters.
    It bothered me enough to bring it up as well as my roommate(his taco), might as well get it fixed since its free.
  5. Apr 8, 2012 at 12:02 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Dealership will perform alighnment to correct. Easy day all day.
  6. Apr 8, 2012 at 12:06 PM
    highflyinmechanic
    Justin
    GA
    Good deal thanks guys!
  7. Apr 8, 2012 at 5:07 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you talk them into the springs it gets an alignment just make sure the wheel is correct when you pick it up.
  8. Apr 8, 2012 at 5:53 PM
    ssault
    ssault Daniel
    Same issue when I picked mine up. Brought it back, and they put it on the rack with no hassle.
  9. Apr 8, 2012 at 10:43 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Yup, mine was off center when I took delivery also. They adjusted it as part of warranty. Just make sure they adjust it at the steering arms, not by removing the wheel and moving it over 1 or 2 splines.
  10. Apr 8, 2012 at 11:14 PM
    highflyinmechanic
    Justin
    GA
    Thanks for the heads up, ill tell um for sure not to touch the steering wheel!
  11. Apr 9, 2012 at 12:54 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Had this happen to my 2011 when I got it. Dealer said that most of the vehicles were out of alignment when they arrived. Byproduct of mass production. He said that it was the dealers responsibility to align the new cars when they came in. Fixed it free of charge, and has also checked the alignment at 5k and 10k free of charge "for my peace of mind"
  12. Apr 9, 2012 at 1:06 PM
    highflyinmechanic
    Justin
    GA
    Got it aligned the tech/mech said it was a few degrees out. Seems to be in spec now 12 O'clock driving straight.
  13. Mar 6, 2014 at 10:01 PM
    freddirt
    freddirt Well-Known Member
    Clint
    Southern Utah
    '13 DCSB TRD OR PRERUNNER
    Magnaflow muffler-stock piping, AFE intake, ADD W1 oil catch can, Diff breather mod, Tailgate lock mod, Partial debadge, LED interior lights (dome, map, vanity), LED Light bar in lower valence, Anit-Dark hood lighting, ADS 2.5 resi coilovers and shocks, Camburg BJ upper arms, Wheelers super bumps, ATX Artillery 17x9 wheels, BFG Rugged Terrains 265/65s.
    Hey fellas... man am I glad I found this thread. I just got my truck back from getting the driveline TSB done. I didnt notice my steering wheel was at about 10 or 11 o'clock position while driving strait until I was on the interstate headed home. I just thought I had like a side wind or somthin. I knew they had put in the steering dampener, so I thought they had taken the wheel off and didnt put it back on strait. So i moved it to the right one spline, then it was too far to the right. Then I looked closely and figured out they shouldn't have removed the wheel to install the dampener. I've been pulling my hair out trying to figure out why my steering wheel would be off center after having the TSB done. I thought maybe when they were driving it, they hit a curb or something and now the alignment is off. I didnt know they have to align it after doing the TSB. I am gonna call them in the AM to let them know. Thanks guys!
