2012 Tacoma Suspension Air Bag Installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by helibear, Feb 7, 2012.
  1. Feb 7, 2012 at 10:26 AM
    helibear
    helibear [OP] Member
    Greg
    Indiana
    2012 Tacoma Access Cab 4X4 V6
    I just purchased a set of Firestone Ride Rite air bags for my 2012 Tacoma. The install instructions direct you to cut the rubber jounce bumper off level with the spring attachment U-bolts. Taking a sawsall to my new truck, even though it is just a rubber jounce bumper, makes me cringe.
    Am I risking an alignment problem or other issues if I loosen the U-bolts and remove the rubber bumper jounce rather than cutting it off?
  2. Feb 19, 2012 at 11:46 AM
    Hophornbeam
    Hophornbeam Member
    Trevor
    Adamant, VT, USA
    2011 4x4 Double Cab SR5 longbed
    Don't know if this is the case with Tacomas, but some truck's rear axle U-bolts are "torque to yield" and are meant to be tightened once and only once; re-use is at risk of trouble.
  3. Feb 19, 2012 at 11:50 AM
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    Just cut it. No reason to make something small a big deal. You bought something that requires modification to your truck and is obviously designed to work correctly when the modifications are done. Worst case if you decide to put it back to stock you can pick up those parts at the dealer or online somewhere.
  4. Feb 19, 2012 at 12:33 PM
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    I put AIRLIFT air bags on my Tacoma and didn't have to cut anything. Just installed them in front of the rear axel and frame. They work great. Don
  5. Feb 19, 2012 at 1:53 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Just cut it, if you ever decide to pull the air bags out, which you won't, bump stops can be easily replaced. I know what you mean though. You are gonna love them air bags.
  6. Apr 3, 2012 at 12:42 PM
    grumpyman
    grumpyman Active Member
    rob
    oakland ca
    2010 access longbed
    hey helibear did the bags go on with no trouble??
    no one at firestone will say whether they will fit a 2012 4x4
  7. Apr 4, 2012 at 5:39 AM
    helibear
    Greg
    Indiana
    They went on fine .... I cust the rubber off and cringed a bit doing so, but everything fit perfectly and went on fine. I had access to some stainless steel bolts and nuts to replace the provided steel hardware, but I only did this because it cost me nothing.
