2012 Tacoma U-Bolt Flip kit arrived today!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wizzard005, Mar 7, 2012.
  1. Mar 7, 2012 at 6:46 PM
    Wizzard005
    Wizzard005 [OP] Well-Known Member
    Greg
    Sacramento, CA
    Stock
    Aloha all,
    I love getting mail!
    Old crappy way:
    The way daddy likes it :)
    Out with the old crappy ones ;/
  2. Mar 7, 2012 at 6:48 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    :thumbsup:
    plan on getting a set of these soon too!!
  3. Mar 7, 2012 at 6:50 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    Guys when i install them, I dont have to jack the truck up right? i can just undo the old and install the flip kit correct? I think nothing will move as I dont really want to take the tires off to do this simple job :)
  4. Mar 8, 2012 at 6:56 AM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    You could probably do it without removing the wheels, but it would be so much easier to do without them on.
  5. Mar 8, 2012 at 7:00 AM
    Bo Rocks
    Bo Rocks Well-Known Member
    Brian
    Southern CA
    2006 4x4 Long Travel
    what is the purpose of doing this? I dont see any benefit besides maybe like an inch of clearance where the ends of the U hangs
  6. Mar 8, 2012 at 8:23 AM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    2 reasons:
    1 Protects the bolts from damage
    2 Less to snag and hang up if you are out wheeling
    Bacon
  7. Mar 8, 2012 at 11:12 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    I wasn't going to use Bump stops, there is really no need in my case as there is no way it can bottom out because how high the truck is. Install took like 30mins, I didn't have to take the tires off, tho an impact wrench would have made the job only take 5mins :)
    The reason why i wanted to do the flip kit was for looks, i don't like shit hanging down off of the truck :) i like clean lines etc.....
  8. Mar 8, 2012 at 11:56 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    ah so much better now :)
  9. Mar 9, 2012 at 12:30 AM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    no need u-bolt flip kit when u get monstah blocks!!!! lol :p
  10. Mar 9, 2012 at 12:36 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    Those are some blocks !
  11. Mar 9, 2012 at 12:45 AM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
    :eek:
  12. Mar 9, 2012 at 12:48 AM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    is that a piece of 2"x4" wedged under your spring?
  13. Mar 9, 2012 at 4:38 AM
    Large
    Large Red
    Lmao^
  14. Mar 9, 2012 at 7:10 AM
    COMAtose HI
    2012 TRD SPORT 4x4
    Lol i guess you could say that, but it's only 1.5" bigger than the original lift kit block...ah it's okay...no more rear sag!!!!
  15. Mar 9, 2012 at 7:27 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    So you would rather rip a fender off with your tire then install bump stops?
    I do not understand why you would risk damage to a 2012....for something that takes 30 minutes to install and is required should you use the truck as an actual truck.
  16. Mar 9, 2012 at 7:30 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I ran mine without bump stops for months, wheeled it and everything. I just recently took the time to make my stock ones work.
    An angle grinder will make quick work of this. Also I used a hammer and an anvil to flatten out the ends.
  17. Mar 9, 2012 at 7:41 AM
    XXXX
    sKiP
    05 Prius
    Not to be an asshole, but you didn't really wheel it hard if you didn't bottom out at all in "months".
    We don't need members reading this thinking its OK to run around with no bump stops then crack a frame or get hurt. Running with no bump stops is not recommended by anyone who sets up trucks.
  18. Mar 9, 2012 at 11:46 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    Last I checked, I never said it was ok. If you have a 6" + lift in your truck, there is no way in hell the leafs will ever come close to the frame, if you have a 2" / 3" lift, of course you should use bump stops...
  19. Mar 9, 2012 at 11:56 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    XXXX's comment was directed toward Tacomalex, who doesn't have a 6" lift.
    I am running Timbren bumpstops with All-Pro's U-bolt flip kit.
    I did one side without taking off the wheel. The All-Pro kit uses locknuts with a high rundown torque. It was a pain in the ass (or rather, arm) because there is very little swing space for a long ratchet handle. With the wheel off, it's easy to reach down over the brake drum.
  20. Mar 9, 2012 at 11:58 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    I used WD40 to get them off and put the new ones on. It was a pain in the ass.. All was well once WD40 went on...
