2012 Tacoma V6 auto engine brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by daopi, Jun 16, 2012.
  1. Jun 16, 2012 at 11:39 PM
    daopi
    daopi [OP] Active Member
    Daniel
    Vancouver, BC
    2012 TRD Offroad AC auto
    Leer 100XQ canopy
    I didn't notice anyone mentioning a new feature in 2012 Tacoma V6 automatic transmission: engine brake (some type). I'm not talking about automatic downshifting and that's it, that is not engine brake, is just a way to mess the transmission. I'm talking about a device which creates a back-pressure in the engine or something like that.
    If you look inside engine compartment towards passenger side fender there is a new "thing" installed, which is connected with a small rubber pipe somewhere in the engine. The strongest feel of engine brake was around 40-45mph (65 kmh) going downhill and if I would press the brakes continuous for like 4-5 seconds transmission downshifts and I felt a strong braking force, much stronger than just a simple downshift, and the truck was holding around 50mph, without me touching the brakes. Also, a slight touch of engine brake was almost always available when approaching stops.
    All good for 6 month then ... don't know what happened, going down same hills doesn't even want to downshift, and if somehow does it feels more like a simple downshift, just the transmission keeps me back.
    Anyway, does anyone knows how this "thing" works, or is just my truck weird? (or me... :()
  2. Jun 16, 2012 at 11:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think that " Thing on the passenger side " is the evap system check pump. It has nothing to do with the imaginary " engine brake thing " that doesn't exist.
    :p
  3. Jun 16, 2012 at 11:56 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    That thing on the passenger side is emission crap Toyota put and the downhill asist is tranny doing engine braking
  4. Jun 16, 2012 at 11:57 PM
    BAMFTACO
    Jośe
    Taco
    Beat me to it
  5. Jun 17, 2012 at 12:21 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sometimes I'm pretty quick for an old fart........
  6. Jun 17, 2012 at 3:52 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When you touch the brake the lockup converter disconnects that might be what you are feeling.
  7. Jun 17, 2012 at 5:34 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    That "thing" on the side of the engine is what makes my engine sound like a dentist's drill on startup and has people running away from my truck...It's particularly badass sounding driving through the parking garage with that high pitched noise going off...
    One day turn your truck on in the morning and immediately turn it off and you can hear the pump pushing air into the exhaust...
  8. Jun 17, 2012 at 6:19 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    That is the #1 reason I didn't want a 2012. When that air injection fails on a Tundra it's only about a $4000 repair - and it'll stay in limp mode until you do it.
  9. Jun 17, 2012 at 6:21 AM
    daopi
    Daniel
    Vancouver, BC
    Leer 100XQ canopy
    Yes, I heard that "dentist drill" from the first day. First of all, can you tell me the name of the "thing"? Second, do you know how is working, what is for?
    Thanks!
  10. Jun 17, 2012 at 6:22 AM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    04 Tacoma DCSB TRD OR
    Its only on the sport model not off road at least I don't have it.
  11. Jun 17, 2012 at 6:26 AM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    hmmm mine does
  12. Jun 17, 2012 at 6:29 AM
    daopi
    Daniel
    Vancouver, BC
    Leer 100XQ canopy
    I have a Texas made TRD offroad and I have it...
  13. Jun 17, 2012 at 6:32 AM
    jtgroce
    jtgroce Got R Did
    Mine says Baja CA but made in Mexico
  14. Jun 17, 2012 at 6:38 AM
    iroh
    michigander
    tonneau
    Air injection pump. It pushes fresh air down the exhaust at engine startup to light the cats faster and reduce startup emissions. That's the only time it's active.
    Why I don't like it...
    The failures on the Tundras was caused by a) the inlet tubes pulling from the fenderwell which b) the pumps on engine start would blow all the water that somehow kept getting into the system to the control valves on the back side of each cylinder head, resulting in c) those two valves rusting open allowing exhaust to blow backwards to the pumps and destroying them.
    People who experienced this were shocked to find that the 5.7L engine has two of these puppies and each one is nearly $1400 from the dealer. The GM version of these things only costs in the neighborhood of $150, hence the shock. Once you add in those two valves that rusted, and labor, it's almost always more than $4000. Its frickin cheaper to blow the transmission.
    Not only that but to prevent fire from exhaust going up those hoses the computer would limit throttle to a very low level and set the redline at about 1800 rpm as long as those valves were stuck open. Might as well be rolling around in a 5.7L moped.
    There was one trick fix someone found. When the intake air temp is lower than something like 37 degrees F the injection system won't start because it would cool the cats more than the fresh air would help. He whacked the control valves on the heads until they'd close, and then soldered up a control board that would interrupt the signal from the IAT sensor and send a false reading of 20F whenever the starter was cranking plus a few seconds. The air pumps would never start, the PCM would never open those valves on the heads, and nothing needed to be unplugged (which ironically if they were would result in limp mode just like the failed valves). Reset the battery to make the PCM forget, it wouldn't go into limp mode on next start and think all was well.
  15. Jun 17, 2012 at 6:39 AM
    CanisLupus
    CanisLupus Well-Known Member
    Ashburn | VA
    '11 DCSB 4WD / '13 Ninja 300 / '04 CRF 150F
    So the DAC has a jake brake? Wish it sounded like one...Although that would be a funny sound to hear a Tacoma making...
  16. Jun 17, 2012 at 7:00 AM
    daopi
    Daniel
    Vancouver, BC
    Leer 100XQ canopy
    Looks like it's only "joke" brake...
  17. Jun 17, 2012 at 7:11 AM
    andrew8404
    ANDREW
    Albuquerque, NM
    Mine is made in Baja too weird.
  18. Jun 17, 2012 at 7:14 AM
    daopi
    Daniel
    Vancouver, BC
    Leer 100XQ canopy
    So my truck is now 7 months old. Few weeks ago I started to hear the "dentist drill" sound while I was driving around 40-50mph going downhill or flat with not much acceleration. The sound was not continuous, was on and off. The noise was there for like a week, and gone. After that two things changed: going downhill doesn't want to downshift, and second, going uphill or harder accelerations make a strong smell of exhaust or something, to come in the cabin. And I'm saying strong, I almost need to crack the window.
    Anyone had same experience?
  19. Jun 17, 2012 at 7:26 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Virginia
    '06 RC, 4X4, 5 speed
    This is very good information. Most people aren't aware that the 2TR-FE has had these pumps since 2005 (i.e. all 2nd Gen 4 cylinder Tacomas). I had no idea that they were causing such issues, or that the pumps were so expensive.
    Did the guy who bypassed the system do a write-up or anything?
  20. Jun 17, 2012 at 8:33 AM
    iroh
    michigander
    tonneau
    He did, but it's been a couple years since I've read into it so I don't remember what website it was on.
    If the 2TR pumps haven't been giving issues that's a good sign. Many postulated that the Tundra issue was from poor placement of the pump inlet tubes.
