2012 Tacoma. Will a lift void my warranty?
Discussion in 'Suspension' started by RUQWKNF27, Jan 24, 2012.
  1. Jan 24, 2012 at 7:37 PM
    RUQWKNF27
    RUQWKNF27 [OP] Member
    ALABAMA
    2012 Tacoma
    Want to do like a 3" lift and also looking for suggestions for a good one!
  2. Jan 24, 2012 at 7:38 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    no.. Just whatever parts you replace won't be covered..
  3. Jan 25, 2012 at 5:58 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Google the Mugnusson-Moss act. The dealer cannot void the warranty on your vehicle for any reason. However they can deny individual warranty claims if they can prove that an aftermarket part caused the failure.
  4. Jan 27, 2012 at 8:47 AM
    petezny
    petezny Active Member
    Pete
    Long Island
    11 Standard Cab 4cyl 4WD
    And remember they can refuse warranty replacement on any part that may have failed prematurely because of your lift not just the parts in the lift. So they might refuse warranty replacement on U joints, CVs, rear end or even some transmission problems (rear seal or bearing from the increased vibration due to excessive drive line angles) just to name some possibilities.
  5. Feb 3, 2012 at 2:33 PM
    Royce99
    Royce99 Taco Samurai
    Royce
    Houston
    2012 MGM Prerunner SR5 Debadged
    Just getting started.
    Hey guys, I also have a 2012. I just left the dealership, none of the guys could give me straight answer when I asked them about this. They all had different answers. I want a 3 inch lift, but dont want to void my warranty.
  6. Feb 3, 2012 at 2:35 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    Get your 3" lift installed by the Toyota dealership...and make sure you keep all of the receipts, documents, etc.
  7. Feb 3, 2012 at 2:37 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    The two posts above you are correct. They cant void the warranty completely but they can deny service if something is broken/worn soley because of the lift. The problem is if they deny you, YOU have to plead your case and prove the lift didnt cause the problem.
  8. Feb 3, 2012 at 2:42 PM
    Royce99
    Royce
    Houston
    I've been leaning towards this, but it costs so damn much!
  9. Feb 3, 2012 at 2:43 PM
    Royce99
    Royce
    Houston
    This is why I'm on the fence of where to get it done. I know of a reputable 4x4 shop who will save me $500...but in the long run?
  10. Feb 3, 2012 at 3:07 PM
    COMAtose HI
    2012 TRD SPORT 4x4
    4wheelparts has a pretty good warranty policy as well, but it costs 500 bucks. It's a 5 year 50k mile warranty that basically saves your ass if anything lift related breaks. I would say your safest route is the dealership, even though it's expensive and most of the mechanics are clueless about installing suspension lifts...atleast you are some what taken care of if something goes wrong.
  11. Feb 3, 2012 at 3:13 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I had a reputable 4x4 and fabrication shop install mine. Granted my truck isn't brand new and doesn't have as much warranty left, but still. Rather have people do it that routinely do that kind of work. Don't know why having a dealer install it is going to matter for them trying to void a warranty claim. It's still aftermarket parts not covered by Toyota. They could still try and turn around and say something cause something to break. It's not like your installing an approved Toyota part that carries a warranty like a TRD supercharger.
    Just know your rights with the above referenced warranty act and have someone that knows what they're doing install it, saving you money at the same time.
  12. Feb 3, 2012 at 4:12 PM
    COMAtose HI
    2012 TRD SPORT 4x4
    Typically Toyota installs a kit that they "say" is covered under their warranty. I really think its a load of BS because I called three different dealerships and got three different lift kit brands lol....but hey if they say it's covered and you have it in writing....then why not get it installed at the dealership.
  13. Feb 3, 2012 at 5:00 PM
    jtav2002
    Josh
    Reading, PA
    Depends what kit it is. You'll see dealers selling new ones with lifts on from time to time. Can't remember the brand either. But I wouldn't buy a kit that they have just for the sake of them saying it's under warranty then. The kit and installation will be a lot more potentially then picking out your own kit and having it installed elsewhere.
    I mean sure, if it's what you want, and they say it will be covered, go for it. Still don't know it's worth paying that much more. Seeing as Toyota themselves doesn't sell a lift it's going to vary dealer to dealer from what they might have. So I'd absolutely make sure you have it documented that they said it's under warranty since it's a dealer thing and not Toyota corp.
  14. Feb 3, 2012 at 5:52 PM
    COMAtose HI
    2012 TRD SPORT 4x4
    ^^^ yup exactly!!!!
  15. Feb 3, 2012 at 6:23 PM
    RUQWKNF27
    ALABAMA
    2012 Tacoma
    The Kit my dealership uses is a Revtec Spacer kit. But today I got a Pro Comp 3" Suspension lift and 285/65/18's put on and I am very happy and the ride is great. I figured what the heck its what I want . If someone runs a red light next week and kills me a warranty wouldn't do me any good then either. Now life insurance and the wife thats another story.
  16. Feb 3, 2012 at 7:16 PM
    Royce99
    Royce
    Houston
    The dealer I spoke with uses a Ready Lift brand. I've heard to stay away from spacer/block lifts, but I won't be doing any offroad driving in this truck. I basically only need the lift to clear my wheels and tires.
  17. Feb 3, 2012 at 7:20 PM
    Royce99
    Royce
    Houston
    How much did that lift cost you? If you dont mind me asking. Any pics?
  18. Feb 4, 2012 at 3:04 PM
    RUQWKNF27
    ALABAMA
    2012 Tacoma
    Lift was $ 485.00 It looks awesome.
  19. Feb 4, 2012 at 3:06 PM
    RUQWKNF27
    ALABAMA
    2012 Tacoma
    Here is is with a 285-65-18 Only problem I had was not enough of the factory wheel studs came thru with the new wheels. I could only thread 1/2 of the acorn style lug nut that the wheel was made for.
  20. Feb 4, 2012 at 3:18 PM
    KPT
    09 Prerunner
    http://www.tacomaworld.com/forum/showthread.php?t=119883
