2012 technical questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdh022764, Feb 3, 2012.
  1. Feb 3, 2012 at 10:26 PM
    jdh022764
    jdh022764 [OP] Member
    john
    toledo ohio
    i just sold my 1998 and i already have questions about a 2012 truck i havent got yet lol . whats the deal with the tire pressure monitors can they be eliminated and keep the one on the spare to keep the light off or does it know about all five of them , also i read about swapping out the wiper stalk and purchasing a delay stalk . i also found out the base tacomas will come with standard tail lights not leds . anyone with insight on any of these questions please feel free to send me a message
  2. Feb 3, 2012 at 10:37 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    My 2012 has a delay stalk, if you mean an intermittent wiper switch.
    I don't think you can delete the TPMS. The system can see all 5 sensors. You can however remove the gauge cluster, disassemble it and remove the light or cover it.
    As far as the LED's in the tails, I'm not sure.
  3. Feb 18, 2012 at 9:55 AM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    I'm going to remove the TPMS on mine, if I had CTIS it would be a different story. I'm not down with all the bs electronics that our government is requiring now. My 12 dc offroad w/ manual box is supposed to arrive in 2 weeks, it'll be a short while until I figure the tpms out but I'll post about it. Maybe someone else will post first or already did and i haven't found it?
    In case of interest, I noticed that the headlights switch rotates on the outer part of the turn signal stock too, that's dumb so I'm relocating the lights control to on the dash. Also planning to remove or delete any other ecu and memory module connected data inputs beyond fuel delivery. The final other items on my list are to reverse the switches for clutch-in starting and traction control so the default for those things is "off".
  4. Feb 18, 2012 at 10:21 AM
    badger
    badger Well-Known Member
    07 SR5
    The TPMS measures relative differences between the tires. It senses when when one goes low of the others. I actually like mine and have had no issues once I understood them. What some have done is to make a chamber out of PVC and throw the senders in the chamber. Mount a valve stem in the end. You pressurize the tank to the same level as the spare and then you retain the spare TPMS. The little tank with the other senders can be put anywhere. Pretty simple and cheap fix if you don't want them in your road wheels.
  5. Feb 18, 2012 at 11:22 AM
    OverRated
    OverRated Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    You can also drill and mount all 4 tpms onto the spare.
    The Tacoma isn't so bad it's just a small light. My IS350 had a annoying warning on the cluster where it kept telling you the tires were flat. But the sensors saved me once, I ran into a nail and was about to leave for work and saw the warning light. Without it I probably would had drove 30 miles on a flat and not know it until I left the house.
  6. Feb 18, 2012 at 12:02 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Why are you so afraid of the electronics?
  7. Feb 18, 2012 at 12:30 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Instead of ruining the spare get a small tire (like a wheel barrel tire) or make a chamber, throw the sensors inside and air up.
  8. Feb 19, 2012 at 1:43 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Primarily because I plan to keep this thing for 10-20yrs.
    The justification is my experience being in the auto industry & software technology, specifically with BMW and Porsche and mobile operating systems. I guess when you're on the inside you see more of the problems associated with short and long term electronics. Seriously, a vehicle is the worst place you can put electronics: outdoors, vibration, rapid and slow process temp fluctuation, humidity & water exposure, not to mention software issues. These + the eventual defects for production shortcomings from the multitude of vendors sourced from, ie solder issues, wiring insulation, glues, etc. are enough to give me concern over this stuff.
  9. Feb 19, 2012 at 1:47 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Thats why you are afraid of computers failing :D
  10. Feb 19, 2012 at 1:50 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Re TPMS removal, found this thread!
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/161292-complete-tpms-disable-guide.html
  11. Feb 19, 2012 at 7:46 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Yes! And Audi's the worst, but BMW especially makes me want to do this: :smash:
  12. Feb 19, 2012 at 7:48 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    For what its worth, In 8 years as a Toyota tech I only installed 1 ecu. And that was on a LEXUS lol.:bananadance:
  13. Feb 19, 2012 at 8:14 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    After you hack it up let us know how the warranty works for you if you have a problem. ;)
    Besides didn't you see it on the news the world is going to end on Dec 21st anyway. :cool:
  14. Feb 20, 2012 at 8:03 AM
    Utard
    Mark
    Nyssa, Oregon
    Sounds a little (actually a lot) paranoid to me? Sounds like you need a new friend like a psychologist?
    Why not buy an older taco and do a complete rebuild? Sounds cheaper to me? Strip it to the frame and get it galvanized. Put in what ever motor you want?
  15. Feb 20, 2012 at 8:51 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    FWIW, isn't it possible to drop the tire pressures real low, then accomplish a reset of the monitor system, bring the tires back to normal pressure, and not get a light until the new minimum pressure is reached?
    PK
  16. Feb 22, 2012 at 9:13 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    utard. You typed WOT's like fear and psychologists? yeah... that's normal for forums about trucks.
    Maybe you're cool, but I don't know you.
    Since you don't know... 14hrs of rewire I can do myself + $32k on a taco (only counting 50% depreciation) is less time consuming and less costly than a used purchase, frame off, diesel transplant, machining, brand new parts on everything, paint, and more, that I'd have to send out to get an equivalent condition vehicle as I'd want, then deal with CA smog. Yeah that makes sense, glad you asked.
  17. Feb 22, 2012 at 9:14 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Interesting. Let me know if this works please.
  18. Feb 22, 2012 at 9:26 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Most Japanese vehicles have had the headlight switch on the turn signal stalk since at least the 1980s. If you came from American or Europeans cars, it may seem unusual.
    Good luck with that. You are pretty much guaranteed to have problems. Toyota electronics are actually reliable and should not be compared to Audi- or BMW electronics.
  19. Feb 22, 2012 at 9:32 PM
    OffroadToy
    4X4 Offroad
    I think the lowest you could go is 25% of the set inflation pressure...or around 24psi if your running 32psi. Any lower than that will set off the light. At least that's how I read this...
    http://www.toyotatpms.com/tpms-toyota.html
  20. Feb 22, 2012 at 9:46 PM
    KenLyns
    Belly of the Beast
    ^ The set inflation pressure is set by you. i.e. You can inflate your tires to 40 psi, hold the button below the dash to reset the system, and the light should come on at 30 psi.
