2012 tire size with lift
Discussion in 'Wheels & Tires' started by dustinclm, Apr 17, 2012.
  1. Apr 17, 2012 at 11:29 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    I have a 2012 4x4 and have the stock 245/75/16 dunlop tires. Also i have the 5100's set to .85" in the front and stock rear suspension. Im looking to replace the crappy dunlops with some General Grabber at2 tires. I dont need 33's but i am wondering if i should go up in tire size an inch or 2 and get my guages recalibrated (where and how much would this cost?) or stick with the stock size? i dont do any hardcore off roading but do pull a boat and hunt.
    im thinking of going with 255/75 or 265/75
  2. Apr 17, 2012 at 12:47 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    you could do 265/75 on stock suspension.
  3. Apr 17, 2012 at 12:56 PM
    dustinclm
    Thibodaux, La
    would i have any rubbing with the .85" lift in the front? im also considering 265/70/16
  4. Apr 17, 2012 at 1:00 PM
    TexasTacoma37
    There are plenty of members running the 265/75/16 with no lift at all, zero rubbing.
  5. Apr 17, 2012 at 1:21 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2 you could also run 285/75/16 just needs some trimming but you could do that
  6. Apr 17, 2012 at 1:30 PM
    dustinclm
    Thibodaux, La
    i dont need to go up to a 285/75, the 265 will do just fine for me. im also trying to consider mpg. which is why im not going with the duratracs again, the grabber at2's should drop me more than 2 mpg
  7. Apr 17, 2012 at 1:35 PM
    Large
    Large Red
    IIRC, I think 265/75 on 16s will be closer on your speedo too, plus there are plenty of tire choices in this size.
  8. Apr 17, 2012 at 1:48 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Wtih 265/75/16s you will have no rubbing, your speedo will read correct but your odo will read less than actual.
    When I run the 245/75/16 Dungflops my speedo reads 2 MPH more than actual (odo is corect) & with my 255/85/16 BFG KM2s my speedo reads 4 MPH less than actual. I put my GPS in info mode for MPH and miles on a tank.
  9. Apr 17, 2012 at 1:50 PM
    TexasTacoma37
    not with only 0.85 of lift and stock wheels. There would be rubbing on the control arms, and lots of plastic rubbing at full lock or when the suspension flexes.
  10. Apr 17, 2012 at 1:56 PM
    dustinclm
    Thibodaux, La
    i just wish the general grabbers werent a load range E tire. i dont want that heavy of a tire. so now the search begins again
  11. Jul 25, 2012 at 4:54 PM
    Sharky
    Sharky Well-Known Member
    Jon
    Utah
    White '12 DCSB TX Pro (also retired)
    Handicap Parking Permit
    I know this is kind of old, but the FJ Cruiser Trail Teams comes stock with load range E BF Goodrich AT's and to me they felt as smooth as anything out there. I liked the ride more than I liked the ride in a stock 17" wheel with the road tire they put on the base model FJ's. The setup is basically the same between the FJ and the Tacoma, so I don't think running an E rated tire is as big as a deal as people think. Plus airing down and such wasn't a scary deal, nor was it a big problem to tow something. I loved the E's. The vehicle never felt floppy. I owned 2 FJ's and had the E tires from the factory and then a 4Runner that had the C load tires, and I disliked them a lot. The tires felt floppy and like they were ready to tear off. That was probably because I was used to E's of course. But... I've had 3 leg operations, 3 spinal fusions, and hip surgery over the last few years, and if the 'E' ride didn't bother me, I don't think it will bother anybody honestly. It felt smooth and let the suspension do the work, but also there was a tire on there that had some heft to it and didn't feel weak and shaky. I'm going to risk throwing a set of the Grabbers on my Tacoma as soon as I can afford it and probably be proven wrong here (I know the FJ's ride differently than the Tacomas and are heavier, boxier, blockier, etc. etc.) but to me... I don't think they are anywhere near as bad as folks make them out to be in ride quality when switching from a C to an E.
