2012 toneau cover quick one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, May 7, 2012.
  1. May 7, 2012 at 6:49 AM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Now that I got my truck, I want a cover. All the ones I see mount with the clamps that block the sliders racks inside the bed. Is there a good cover that does not block the rail system? Without drilling! I have a short bed and not looking to spend a ton
  2. May 7, 2012 at 6:54 AM
    1989supraturbo
    1989supraturbo Well-Known Member
    British Columbia, Canada
    2012 DCSB TRD 6 Spd MGM
    The hard folding one from toyota just has brackets that use the rail on the front and rear, it's not in the way at all. The tie downs have only certain spots they clamp into anyway.
  3. May 7, 2012 at 7:09 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    access roll up cover here. you remove the bed cleats and then bolt them to the cover rails. you still have access to them.
  4. May 8, 2012 at 7:43 AM
    Glocker23
    CT
    2012 DCSB Sport
    Ok but there is no tonneu cover that doesn't block the rail system.
  5. May 8, 2012 at 11:31 AM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    There is not a cover out there that doesn't effect the rails in some way.
    The trifold covers take the least space, a simple clip at each end of the rail.
    Second page, top pic
    As mentioned, the Access Roll Up is another option. You simply remount the rails to the cover rail.
    Access install
  6. May 8, 2012 at 11:37 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    x2 on the Access cover. Access LiteRider in my case, $280 new. Much cleaner install than my previous Truxedo LoPro QT.
  7. May 8, 2012 at 6:20 PM
    Glocker23
    CT
    2012 DCSB Sport
    sweet thanks for the instructions I like that access roll a lot
  8. May 8, 2012 at 6:21 PM
    Glocker23
    CT
    2012 DCSB Sport
    280 new where I am finding them around 400
