2012 TRD rad leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badhaircut, Jun 6, 2022.
  1. Jun 11, 2022 at 7:23 AM
    badhaircut
    badhaircut [OP] Well-Known Member
    2012 TRD double cab long bed
    Ok so I bought this OEM 50/50 pink at Canadian Tire and filled up the reservoir tank to the full line. I did not fill the actual rad though, just the reservoir.
    I used my truck for the day and this morning I checked the level and it's down to the same level as before, like way below the Low level line.
    I havent turned on the cab heat though. Should I assume I have a leak?
  2. Jun 11, 2022 at 9:45 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't assume anything yet. It could have just gotten air in the system from running the thing low on coolant.
    Top it off again and give it a day or two then top it off again. If you continue having to top it off after several tries you most likely have a leak somewhere.
    Turning on the heater doesn't matter as the coolant cycles through the heater core all the time regardless of if it is on or not.
    badhaircut[QUOTED][OP] and Dm93 like this.
  3. Jun 11, 2022 at 1:00 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If you really want to know now, you can get a free loan a tool at most auto chains to pump the cooling system up to pressure (thru rad cap) and see if you have a leak.
    Or do as Jimmyh said and wait and see.
    Jimmyh likes this.
  4. Jun 11, 2022 at 8:47 PM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    When the engine is cool, pop off the radiator cap and make sure the radiator is full to the top with coolant. After that, top off the reservoir.
    Jimmyh likes this.
