2012 TRD Sport soon to have TRD Supercharger installed with mods. Dyno?????
Discussion in 'Performance and Tuning' started by jarhead0313, Aug 8, 2012.
  1. Nov 21, 2012 at 8:09 PM
    #181
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Nov 21, 2012 at 8:39 PM
    #182
    jarhead0313
    jarhead0313 [OP] Well-Known Member
    Portland, OR
    2017 TRD ORDC LB 4X4
  3. Nov 22, 2012 at 2:06 PM
    #183
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Post up in that thread on XRU, or give Gadget a call. I know he is ready to have it tested!
  4. Nov 22, 2012 at 9:38 PM
    #184
    jarhead0313
    Portland, OR
    done
  5. Nov 23, 2012 at 1:19 PM
    #185
    jarhead0313
    Portland, OR
    Hit 8.22 on my plx boost gauge last night. Is that inline with what I should expect with my mods?
  6. Nov 26, 2012 at 6:05 AM
    #186
    Budokai
    Budokai Active Member
    Winnipeg
    2013 dbl trd with leather
    At Tires/running boards/skid plate/tonneau/bon jovi and hood deflector.
    I believe std boost is 6-6.5 and running urd pully will give you approx 25% more so that would be in line. Gadget will probably be able to give you the exact numbers expected. Btw im following with interest your continued path/quest for power. I stopped at headers/exhaust but quite interested in the fuel monitor and chip upgrade. So im currently watching your post before making that 2k decision. Keep em coming please.
  7. Nov 26, 2012 at 7:01 PM
    #187
    jarhead0313
    Portland, OR
    Thanks for the intrest and comments! It is an ongoing project for sure. I am going to give URD a few months to see if they come out with the plug and play ucon, if not I will be hacking up my ecu wires to put it in. Boost is addicting for sure!
  8. Nov 27, 2012 at 12:10 AM
    #188
    jarhead0313
    Portland, OR
    So tonight i did another 40-to 90 run and hit 8.49 on the boost gauge. I think It was 7 to 8 sec, hard for me to measure. Just think what she will do when she is tuned with the Ucon.
    http://youtu.be/FFCcAUiqkIY
  9. Nov 27, 2012 at 1:29 AM
    #189
    jarhead0313
    Portland, OR
    My NST crank lite pulley came in the mail tonight. Hope to put it in this weekend.
  10. Nov 27, 2012 at 8:22 AM
    #190
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I will have to add your time into the list on the Acceleration Wars thread. :thumbsup: Truck is really coming together performance wise!
    I also posted some links in another thread of yours. More goodies. ;)
  11. Nov 27, 2012 at 10:14 AM
    #191
    jarhead0313
    Portland, OR
    I love goodies! Posted up that link on xru, I think it is 7.5 sec...what u think?
  12. Nov 27, 2012 at 1:51 PM
    #192
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I think 7.5 is pretty damn quick, and will only improve with what you are planning.
  13. Nov 27, 2012 at 6:54 PM
    #193
    jarhead0313
    Portland, OR
    Tor, I looked all over to find a good write up on how to install the NST Crank Lite Pulley and couldn't find one. You have a link to help me out?
    Another question too. My afr goes way lean when I am coasting sometimes, clear to 20, is that normal, or bad unichip bs?
  14. Nov 28, 2012 at 11:55 AM
    #194
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is rather simple actually. Fan and shroud removed. Then the accessory belt. Then since yours is an automatic, you will need a compact impact gun. Unless you have a flat bar that has two holes in it to fit into the bolt hole on the pulleys, as well as allow access to the 22mm crank bolt.
  15. Nov 28, 2012 at 12:07 PM
    #195
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    too add to this you'll need an impact gun that makes more than 550 ft-lbs.
  16. Dec 3, 2012 at 12:35 AM
    #196
    jarhead0313
    Portland, OR
    NST crank lite pulley went on this weekend. I took a quick test drive and really couldn't tell a difference. I will update in two weeks. See if at least improves my mileage.
  17. Jun 2, 2013 at 7:34 PM
    #197
    trailhoor
    trailhoor Well-Known Member
    Colorado
    08 BLK TRD
    King Adj Remote C/Os, Icon UCAs, King Adj Remote Rears, Alcan Leafs, Light Racing Jounce Shocks, Defined Engineering Shackles, Defined Engineering X-brace, Hakkapelittas (winter), Tunes, TRD S/C, APR X-1, URD 2.825 pulley, AFE Stage II, Doug Thorley LT, All Pro Rear Plate Bumper, Tom Woods CV drive shaft, FX-R HID headlights, diff lock, door chime, fogs anytime, bright reverse lights, map lights wired to door lights, defrost A/C, bed bike mounts
    On your brakes, install stainless lines on all 4 wheels (Goodridge). I also put Hawk pads on the front. That was a nice improvement over stock, but I would still like more stopping power. Especially with a stronger engine!
  18. Jun 23, 2013 at 3:37 AM
    #198
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    went from brembo blanks and hawk lts with ss lines to ebc stage 5 kit.......brakes nicely, low wind noise, not much dust imho, no other noises.
  19. Nov 4, 2013 at 11:43 AM
    #199
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Keep the comments going.subscribed to this post.i think I'm guna follow each step your takin with these mods.!(and I promised myself i would stop after the s/c).since then...dtlt headers.mk2 cat back,2.8" urd pulley,afe cai.)your giving me lets of ideas!!!being in Texas I might be visiting you often torspd!
  20. Nov 5, 2013 at 12:36 PM
    #200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have to get a meet together. :thumbsup:
