2012 TX Pro
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mickdizzle, Jan 1, 2012.
  1. Jan 1, 2012 at 9:03 AM
    Mickdizzle
    Mickdizzle [OP] Well-Known Member
    Montana
    12 TX Pro
    Hey guys, been snooping around the forums for a week or so. I just bought a 2012 TX Pro in black last week. I am terrible about leaving things alone. I just cant drive a stock truck. I am looking to do a few mods and just wanted to pop in and ask some advice.
    I want a little lift but nothing too big right now. What i am looking at doing is getting some 5100 bilsteins all around and setting the fronts at 1.75. For the rear i have the 3 leaf spring pack so i am going to add a leaf in the rear(are the rear shocks adjustable?). I am looking to get a road armor bumper or iron bull bumper in the front with a winch. I want the truck to sit level and i want to clear some 265/75/16 fierce attitudes. Am I on the right track here?
    I will post pics later. at the in laws now.
  2. Jan 1, 2012 at 9:07 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Congrats on the new truck!
    U can add a leaf, or see if your dealership will install the TSB 4 leaf pack.
    Rear shocks are not adjustable. Go ahead and pick up a pair of 5100's for the back also.
    The tire size u suggested will fit on stock suspension.
    Id say your on the right track! Keep browsing the forums for more ideas, install guides, and other mods!
  3. Jan 1, 2012 at 9:10 AM
    Mickdizzle
    Montana
    12 TX Pro
    thanks man. I figured they would probably clear at that size but i just want to keep the truck off of the tire a bit. I also want to level the truck off. I don't like the front lean.
  4. Jan 1, 2012 at 9:11 AM
    Mickdizzle
    Montana
    12 TX Pro
    any sites that you can think of that i can order the 4 shocks and the AAL? Also i am ok with the stock coils for now right?
  5. Jan 1, 2012 at 9:12 AM
    Dark_Taco
    Dark_Taco ΜΟΛΩΝ ΛΑΒΕ
    08' TRD Rugged Trail Edition
    Sounds like a good plan. 265/75/16's will fit and look good with or without the lift.
  6. Jan 1, 2012 at 9:14 AM
    Mickdizzle
    Montana
    12 TX Pro
    how much lift would the eibach springs and the billys set at zero give me?
  7. Jan 1, 2012 at 9:15 AM
    wolfdog2314
    Brush Prairie
  8. Jan 1, 2012 at 9:16 AM
    Mickdizzle
    Montana
    12 TX Pro
    Tempted to go 285 if i am going to put this work into it haha
  9. Jan 1, 2012 at 9:18 AM
    wolfdog2314
    Brush Prairie
    Go for 285's. You can set your front 5100's to the .85 setting. Paired with the eibach springs you'll be around 2.5 inches of lift.
    You'll be able to fit 285's then. (you will have to trim some plastic junk in the wheel well and take your front mud flaps off too)
    I've ran this setup for over a year now and I love it.
    Not sure what the backspacing of those tx pro wheels are, but you'll probably need some wheel spacers to minimize rubbing. Or get a new set of wheels with a backspace of 4.5 or less.
  10. Jan 1, 2012 at 9:21 AM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    congrats on the truck! and welcome from louisiana
  11. Jan 1, 2012 at 9:23 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You don't need extended brake lines and BPV bracket relocator on a second gen with the mild lift that you are planning on. If you are planning on a bumper and winch then the stock coils won't do. Get the Eibachs and the 5100's.
  12. Jan 1, 2012 at 9:32 AM
    JavaJoe1
    JavaJoe1 Well-Known Member
    Joe
    Florida
    2012 Access cab Pre-Runner SR5
    Secondary air filter removal, AFE Pro Dry, 5100's all around front set at 2.5, 2" AAL in rear, ImMrYo Mirror Bracket, 265/70-17 Grabber AT2's, XD Addicts, wanting to do: BHLM, Satoshi/T-rex grill
    This thread will be of great use as I want to do the same thing to my truck. Sub'd.
  13. Jan 1, 2012 at 9:34 AM
    Mickdizzle
    Montana
    12 TX Pro
    So you are thinking going with the ome's instead of the eibachs?
  14. Jan 1, 2012 at 9:36 AM
    Mickdizzle
    Montana
    12 TX Pro
    Is the diff drop neccessary with what i am looking at?
  15. Jan 1, 2012 at 9:43 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not all all necessary for 6", because of the drop bracket, your cv angles don't change from stock.
  16. Jan 1, 2012 at 10:17 AM
    Mickdizzle
    Montana
    12 TX Pro
    you guys are awesome. Thank you for all of the replies so quickly. So this is what i am going to go with.
    Bilstein height adjustable 5100 Front and rear shocks
    $349.99
    Front OME 886 Coils(For the added bumper & winch weight)
    $169.99
    Top plate spacer(For taco lean)Do i need longer studs?
    $19.99
    Rear Toytec AAL
    $79.99
    TOTAL=$619.96
    I am going to set all shocks at 0 hoping to acheive 2"of lift in the front and rear. (I am guessing when the bumper is installed the front end will settle and make the truck sit level.) I don't have the tools, time, or space to install this myself. Could anyone guess what this would cost me in labor? Also i am going to stick with the 265/75/16 for now. I like this lift because it gives me the option to go bigger down the road.
  17. Jan 1, 2012 at 10:21 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  18. Jan 1, 2012 at 10:24 AM
    Mickdizzle
    Montana
    12 TX Pro
    yes just the one spacer for the drivers side. I will look into the studs. How important do you think that extended brake line is?
  19. Jan 1, 2012 at 10:31 AM
    Mickdizzle
    Montana
    12 TX Pro
    All these parts are for 2011. They will fit the 12's right? also do you think i am overdoing it with the 886's. Just don't want my ride to stiffen up too much
  20. Jan 1, 2012 at 10:35 AM
    Mickdizzle
    Montana
    12 TX Pro
    Extended brake lines in the front and rear?
