2012 v6 at DCSB engine knocking @ 1500 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B18blk, Jul 24, 2012.
  1. Nov 7, 2013 at 5:49 AM
    #361
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    And, if you also don't mind...
    http://www.surveymonkey.com/s/L7XZ8QP
    BTW there is presently no fix. (I do my regular TSB check in 2 weeks, but don't expect anything). Frankly, I doubt there ever will be a fix. They can't fix vibes, I strongly doubt they can (or want) to fix this.
  2. Nov 8, 2013 at 12:23 PM
    #362
    Brandon###
    Brandon### Well-Known Member
    :popcorn:
    Hi Toyota,
    If you're reading this and want a test truck that used to ping like crazy, but doesn't ping anymore, pm me...it's for sale
    87 octane too:D
    /hijack
  3. Nov 10, 2013 at 3:26 PM
    #363
    Bendecco
    Bendecco Well-Known Member
    Warren
    North OC Southern Cali
    12 MGM Prerunner DCLB
    Wet Okole, Weathertech, TRD FJ Trail Team Wheels, 265-75-16 Michelin AT2, Nfab side steps, Blue Guy Console cover,Front billy 5100 coilovers, tailgate and bed hatch locks
    Hey......appreciate the info on the fix :confused:
  4. Nov 12, 2013 at 12:13 PM
    #364
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Motor go boom?
  5. Nov 13, 2013 at 5:57 AM
    #365
    obscurotron
    N. Nevada
    '14 DCSB 4x4
    He apparently slapped in a set of NGK iridium plugs (same heat range as the stock plugs) and it eliminated his ping. To date, in all my searching, emailing and reaching out, he's the only person I know of to successfully eliminate the pinging by swapping plugs.
    I suspect if the problem was factory plugs, Toyota would have fixed the issue by now. I'm glad it worked for him, but it didn't for me. I also swapped in a set of the NGK iridium plugs, back in September or August, and I was pinging away. I pulled them back out (fun) and went back to OEM plugs so the dealer couldn't flip me any shit about them.
  6. Nov 13, 2013 at 7:54 AM
    #366
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    I try to either floor it or crank up the volume to NOT hearing these pings. I try the SAME gas on my RX350 and the Lexus runs just fine.
    Toyota....fix this issue.
  7. Nov 13, 2013 at 11:04 AM
    #367
    LooseNut
    LooseNut Active Member
    Texas
    2012 DCSB TRD OFF-ROAD
    I just found/read this entire thread because I was just about to take my 2012 Double Cab 4x4 TRD in for service and bring up the very same clacking engine problem (started happening at 5 miles new). It seems there is no fix for the truck so I'll save my breath and start looking for another option.
    My previous truck was a 2001 GMC 2500 that started clacking the exact same way at 60K miles (maintained to perfection). By 120K it was clacking every time I pushed the pedal, burning a quart of oil every 1000 miles, fouling spark plugs and throwing blow-by with every hard acceleration.
    This problem WILL prematurely wear the engine. This sucks.
  8. Nov 13, 2013 at 11:16 AM
    #368
    Brandon###
    I posted what I did several pages back. 1 member tried to replicate it and it didn't work for him.
    The only thing I've done to my truck is switch to iridium plugs and clean the MAF and throttle body. It used to ping consistently, and after I switched plugs it stopped.
    I run 87 octane in every tank and it hasn't pinged in over 40k miles.
    Nope, it is still running.
  9. Dec 2, 2013 at 11:05 AM
    #369
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Cool idea! I definitely try this.
    But, I do not think it's due to the spark being not hot enough. More likely the Iridiums run cooler so they are less likely to ignite the mixture like a glow plug.
    I'm running the iridiums in my bimmer and they work great. Smooth as butter. Now to get some in the truck too. Thanks for the idea.
  10. Dec 2, 2013 at 12:48 PM
    #370
    GoHuskers
    Nebraska
    For the last 3 weeks I have used Premium gas (91) and the pings are GONE (about 5 tanks now). Premium is about $0.25 more expensive than 87 with E10 and $0.10 more expensive than Regular 87. Gas mileage didn't improve but at least the pings are gone.
  11. Dec 2, 2013 at 12:49 PM
    #371
    BTO
    California
    Toyo8696,
    What exact model plug did you use? Since there is some disagreement about whether this iridiums fixes it. It could be the exact plugs you used are the only ones that fixes it. I was about to order NGK LFR6AIX-11 Iridium IX Spark Plugs but I think I'll hold off until I see your response.
  12. Dec 2, 2013 at 12:51 PM
    #372
    BTO
    California
    With a 10 to 1 compression ratio, this motor should not need more than mid grade gas.
  13. Dec 2, 2013 at 1:06 PM
    #373
    zeekevin
    zeekevin Well-Known Member
    San Diego
    I finally hit 30k miles and swap the plugs with a new set of oem Toyota ones and wow the truck feels better then brand new. I checked them for proper gap, I'm still on the 91 tank, I will go back to 87 to test if the Ping/knocking still happens
  14. Dec 2, 2013 at 4:59 PM
    #374
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    True. Too bad you can't find mid grade pure gas any more. I think the 10% ethanol is really the problem. I run non ethanol premium unless there is no other choice, and it works out to the same $ per mile. Try it yourself.
  15. Dec 4, 2013 at 4:28 AM
    #375
    OverPar
    OverPar Well-Known Member
    Dirt Guy
    NW CT
    09 TRD Sport
    Fold-a-Cover G4 Elite, Light bar (X3 Hella), Thule/OEM RR, Avid OR BO Sliders, TRS Projector HL (BHLM), 5100s F/Rear @ 1.75
    Follow up to my first post in this thread on 11/4, and one fill w/93. Have been running 93 since (~5/6 tanks). Still no signs of ping/noise/knock, whatever the hell it was. Have tried to create noise thru various situations (heavy accel, a/c running, not downshifting properly going up hill, etc). Nothing.
  16. Dec 4, 2013 at 4:33 AM
    #376
    OverPar
    Dirt Guy
    NW CT
    09 TRD Sport
    btw Obscuro...I did the survey
  17. Dec 4, 2013 at 5:07 AM
    #377
    oldracer
    oldracer Well-Known Member
    After reading all the posts, I'm still undecided as to what actually caused the problem. But here's my thoughts.
    a. Yes, the gasoline is definitely inferior to what we had available to us just a few years ago. Regular and Premium are not the same quality.
    b. Spark Plugs have been known to cause spark knock; but at his mileage; that doesn't seem like the case. Unless, there was a definite problem found on one or more plugs.
    c. The Electronic Control Module should have adjusted spark advance; once the engine showed the spark knock to any of the sensors.
    d. The owner's driving habits should not be a problem, the ECM should adjust to the conditions.
    I'm betting there was a fuel issue. I don't know what blend you have where you live; but here in PA we are forced to use the ethanol blended gasolines. These fuel are causing all sorts of problems; particularly in small engines, such as chainsaws, boat motors, lawn mowers, etc. These types of engines are particularly sensitive to inferior fuel.
    oldracer
  18. Dec 5, 2013 at 3:28 AM
    #378
    toyo8696
    toyo8696 Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
    In the Atlanta area some of the Valero gas stations have non-ethanol 90 octane gas you can get. Try it and see what happens.
  19. Dec 6, 2013 at 5:45 AM
    #379
    jmgarcia1
    jmgarcia1 New Member
    2012 SR5 V6
    Another update....
    I have used 93 octane(assuming with ethanol mix) for past 8 months and have heard zero knocking. Under every condition and load the engine no longer knocks. I don't know if this is simply a bandaid or actual fix, but maybe I'll eventually forget that it happened and finally be comfortable driving my truck. I'm paying enough for it,I should at least enjoy it.
  20. Dec 10, 2013 at 10:01 AM
    #380
    slipknot
    slipknot Member
    An update:
    Took my Taco to the dealer with this issue and they could not duplicate it, but at least it's documented. I have noticed since it has gotten colder here in Va., the spark knock even with regular fuel is gone. I ran about 3 tanks of 93 octane then switched back to 87. After 2 tanks, no knock yet. I'm sure it will return, maybe with the summer blend next year? The mechanic told me one reason the engine is so noisy is because the manifold is made of plastic!
    C'mon Man! Really?
