2012 v6 at DCSB engine knocking @ 1500 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B18blk, Jul 24, 2012.
  1. Apr 5, 2014 at 9:58 AM
    #401
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    2024 TRD Off-Road Hybrid Premium
    Stock
    My '12 was doing the same thing under load at around 1500-2k RPMs. Changed over to Amsoil, it helped from running the conventional the dealer was putting in. Moved over to 0w-30 Amsoil from the 5w-30 and it got a little better. Started running Shell 93 octane and problem is now totally gone for the past 5k miles. The crap they put in 87 these days with Ethanol does not make these 4.0's happy. I think it's mostly contributed to the Ethanol content they put in as a "filler" in 87 octane. Shell 93 has very little if none at all. I've run Shell 93 in both of my Acura's since they call for premium gas anyways and my TSX has over 200k on it with never an problem in motor from knocking or injector issues. Shell 93 is very good gas compared to most other brands IMO.
  2. Apr 6, 2014 at 12:35 PM
    #402
    Magna2406
    Magna2406 Member
    PreRunner
    I have a 2012 Toyota Tacoma (V6, DC, SB, blah, blah, etc.) and in the Owner's Manual, in Section 6.1, on page 569 it states:
    If your engine knocks
    Consult your Toyota dealer.
    You may occasionally notice light knocking for a short time while
    accelerating or driving uphill. This is normal and there is no need for concern.
  3. Apr 7, 2014 at 8:03 AM
    #403
    rnls06
    rnls06 Member
    Luis
    Orlando, FL
    2017 Tacoma TRD OR 2WD
    I too have the exact same sound obscuron has in his video. You know what to listen for when you have it and mine is an exact replica. Funnny thing is my dads '09 4runner with the exact same engine never knocked and he only used 87 fuel from the cheapest source around town. His '12 4runner with the same engine which produces 270 compared to my 236 doesn't ping either, again using 87 octane. I live in miami and have no hills and mine makes the noise everytime I hit that rpm. It does not matter if the ac is on or off I always hear it. My '06 frontier never did it niether did my '12 4cyl tacoma. But this '13 Tacoma has been doing it since 9,500 miles and its agravating. Worse thing is you can actually hear it over the radio unless you have the radio blasting. My dealers response so far is that its normal to to use premium only.
  4. Apr 7, 2014 at 11:55 AM
    #404
    TRDreamin12
    TRDreamin12 Active Member
    Elliott
    Arkansas
    2012 Silver Streak TRD Offroad
    +1 for Magna2406. It says the same thing in my manual. I had the same problem with mine. It was a low speed knocking which sounded like rockers/ lifters from my limited knowledge of engines. It only happened at low RPMs (1500 range) and more often when going uphill. It happened EVERYTIME I had my oil changed by the dealer. I tried higher octane and I personally didnt notice any difference. It lasted till about 45k miles then seemed to go away after the oil changes. I have noticed it maybe 1-2 times since then but very minimal and went away pretty quickly.
    I have to say, in general I have been far from impressed with Toyota's continuing customer service.
  5. May 5, 2014 at 2:23 PM
    #405
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Has anyone had any luck with an ecm reflash for this issue? I see it was mentioned earlier in this list that Toyota was working on it. My 12' is pinging like crazy at that magical 1500 rpm on shell 93, it's pretty annoying.
  6. May 5, 2014 at 2:46 PM
    #406
    slipknot
    slipknot Member
    Hey alloutdrs1,
    I live in vb too. I have a 13 DCSB and it knocks like mad, starting getting worse lately. Chumps at Checkered Flag keep telling me its normal. It is pissing me off. It started after my 1st oil change and gets worse after each one too. Im not sure what to do at this point.
  7. May 5, 2014 at 3:08 PM
    #407
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I've been told the same as well, but to me a truck with 29k miles shouldn't be sounding like one with 300k miles. Mine is doing it with ac on or off as well,I'm getting ready to change my plugs this weekend so I hope that helps the issue.
  8. May 5, 2014 at 3:56 PM
    #408
    slipknot
    slipknot Member
    Good luck and please let us know if there is any difference. I'm on the verge of getting a different truck if it's not resolved soon.
  9. May 5, 2014 at 8:16 PM
    #409
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Slip are you running 93 octane in yours as well? I hope i can figure out something as i fear the upcoming hotter weather is only going to make it ping worse.
  10. May 6, 2014 at 5:32 AM
    #410
    slipknot
    slipknot Member
    On 87, it is bad. I have used 89 and it lessens the issue. If I use 93 it is about 90% resolved. It is strange how after every Toyota Careless oil change it is more noticeable until I drive a couple of hundred miles. I believe that it is a timing issue with the ECM code though. I have 15k on my "diesel" taco now. It began after the 1st oil change at 5k. I don't think m they will ever do anything to correct it. May buy a Ford Raptor instead.
  11. May 6, 2014 at 8:35 AM
    #411
    Bendecco
    Bendecco Well-Known Member
    Warren
    North OC Southern Cali
    12 MGM Prerunner DCLB
    Wet Okole, Weathertech, TRD FJ Trail Team Wheels, 265-75-16 Michelin AT2, Nfab side steps, Blue Guy Console cover,Front billy 5100 coilovers, tailgate and bed hatch locks
    I just turned 13k miles last week and the pinging on a hot day was so bad I siphoned and refilled with 92 octane....
    Has anyone taken them to court over this?
  12. May 7, 2014 at 6:16 AM
    #412
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    More than one person has gone after them on lemon law grounds, but I don't think anyone has ended up at trial (rare with lemon law), or otherwise pursued a lawsuit against Toyota.
    The oil change correlation has me stumped. Question is whether this is being held up by EPA/CARB or Toyota. Then again, it only took Toyota 9 years to figure out the driveline vibration issue (apparently the most recent TSB is actually fixing it). So perhaps by 2018 or 2019 the 1GR-FE will have a 'ping' fix.
    And I'll sprout wings and fly with rainbow-pooping unicorns.
  13. May 7, 2014 at 6:58 AM
    #413
    Bendecco
    Warren
    ^good to see you still here following this...
    I hurt my back at work and have some time on my hands...
    While I'm burning up my sick time do you think it's worth a shot filing in small claims?
    I've pretty much come to the conclusion that after 14 or so documented visits to the dealer that I'm stuck with a truck that pings if I don't use "Top Tier super unleaded"
    And try not to drive on a really hot day....
  14. May 7, 2014 at 7:25 AM
    #414
    slipknot
    slipknot Member
    Hell, I still get the "that's normal" response about the drive train vibrations and the chassis squeaking . I should have known better that to buy a Toyota after all the lies they were caught up in a couple of years ago with the Camry.
  15. May 7, 2014 at 3:58 PM
    #415
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Slip you are fighting all the same issues as me, driveline vibs and i have some horrible squeaking going on up front. Now that there is a driveline fix that works I will be making an appt. to try and get this taken care of. Working with the dealer is such a hassle though and i always end up loosing time at work.
    As for the pinging I have always run Exxon 93 since the truck was new, since i started noticing the pinging i have gone to shell 93 and i am now on my 3rd tank of that and it seems to have improved, at 4.04 a gallon it better!!! Now next two days the temps are going to get up to 86-90* so we will see how it does then.
  16. May 7, 2014 at 5:06 PM
    #416
    slipknot
    slipknot Member
    ^ yeah but it totally pisses me off to pay that much for gas when it should run on the 3.50 87 just fine. Please let me know if you get the squeak and vibration issue fixed. I'm trying to find the time myself to drop mine off again, after I refill with 87. I was there 2 weeks ago with no luck on any of the issues. Maybe we should have a tag team match!
  17. May 8, 2014 at 5:23 AM
    #417
    slipknot
    slipknot Member
    Quick thought. I read on other threads where there was evidence that Tacos built in Mexico have more quality control issues like ours. I checked mine and guess where it was built? Mexico. Not sure if there is really any truth to that but I'm curious where other trucks having this problem noted in this thread were built. If the VIN begins with a 3, it's Mexico. You can also check the stickers on the driver side door frame above the tire sticker.
  18. May 8, 2014 at 6:11 PM
    #418
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That theory doesn't pan out, mine is a Texas built truck. How was yours today with this 90* eat we had?
  19. May 13, 2014 at 5:57 PM
    #419
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    From other thread...
    Engine pinging in hot weather
    Few weeks ago we had hot weather and I noticed my engine pinging under light load 1500rpm 30 to 40 MPH. As the weather cooled I changed the spark plugs to OEM correctly gapped and made sure it had 91 brand gas and the pinging fully stopped. Today the weather got hot again, almost 97 degrees and my truck started pinging again pound enough to hear it inside the truck with the radio off.
    I'm sure it is engine knock and it appears to be related to the heat, plus the crapy gas here in CA does not help.
    Anyone out there have noticed this issue?
  20. May 13, 2014 at 6:05 PM
    #420
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I have the pinging hot or cold doesn't matter and on 93. Yesterday I changed my plugs to OEM denso gapped to spec and today was 93* and it stopped the pinging. I will put some more miles on her and see if it changes, i'm still on the tank of gas it was pinging on before I changed them as well.
