2012 v6 at DCSB engine knocking @ 1500 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B18blk, Jul 24, 2012.
  1. Jan 22, 2015 at 11:20 AM
    #481
    Boston
    Boston Member
    South Florida
    2013 TRD Double Cab 4x4 V6 Auto
    Stock
    The mild occasional knocking is gone.
  2. Jun 11, 2015 at 3:18 AM
    #482
    mike15
    mike15 Well-Known Member
    PA
    2021 Tacoma Limited
    If the pinging is very slight, is it worth getting the TSB done?
  3. Jun 11, 2015 at 4:51 AM
    #483
    Boston
    Boston Member
    South Florida
    Stock
    Mike 15- Yes, get it done. It will cost nothing to you and I have found that my truck's performance is improved.
  4. Oct 1, 2015 at 5:58 PM
    #484
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    Hi everyone, I just signed up in this forum because this exact problem. I have a 2012 tacoma v6 off-road dcsb with about 32k. I started noticing the noise couple of months ago between 1500-2000 rpm at 30-40 mph with slight acceleration. Changing to 93 octane helped reduced the noise but did not go completely. Well I printed the tsb and went to the dealer and was under the impression that they will perform it and I will be done. After waiting for an hour or so the guy came back and said that the technician that tested the car said that you have a bigger problem than the tsb and we opened a case with Toyota and we have to discuss it with themo_O. I'm pretty sure I have the same infamous noise that everyone here is talking about. They gave me a corolla and kept the truck, they will contact me tomorrow they said. I just don't want them to take the engine apart :facepalm:.
    I have an extended bumper to bumper warranty but this will be covered under toyota power terrain warranty.
    Will keep you updated
  5. Oct 1, 2015 at 6:10 PM
    #485
    Taco280AI
    Taco280AI Well-Known Member
    COS
    2017 TRD OR DCSB 4x4
    It was very noticeable on my '13. Haven't heard it at all in the '15
  6. Oct 2, 2015 at 9:06 AM
    #486
    Nalex
    Toyota headquarter told the dealer service to check the valves clearance. Which is mean they have to take the engine heads out, I really don't like that. As far as I know if the problem is with the valves clearance the engine would have failed long time ago. Also I don't have any other symptoms the truck runs fine except for that noise at 1500-2000rpm.
  7. Oct 2, 2015 at 9:36 AM
    #487
    lanestaco
    lanestaco Well-Known Member
    Lane
    Guthrie, OK
    '13 Tacoma TRD Sport 4x4
    Document everything. And show patience through the whole process, so if they start to screw you over, you can throw it at them.
  8. Oct 3, 2015 at 7:02 AM
    #488
    Nalex
    Thanks for the advise, will do. I'm surprised why they never tried to perform the TSB and Toyota just jumped to the expensive route. I have to wait and see I guess
  9. Oct 7, 2015 at 7:43 AM
    #489
    Nalex
    Dealer performed the tsb. The noise is gone
  10. Oct 7, 2015 at 8:22 AM
    #490
    lanestaco
    Lane
    Guthrie, OK
    I'm assuming since I'm well out of warranty that I'd have to pay to have a TSB done, right?
  11. Oct 7, 2015 at 8:24 AM
    #491
    Nalex
    96 months/80,000 miles federal emission warranty
  12. Oct 7, 2015 at 8:35 AM
    #492
    lanestaco
    Lane
    Guthrie, OK
    Excellent! So, just take that TSB number/ID in and tell them it needs to be done?
  13. Oct 7, 2015 at 8:45 AM
    #493
    Nalex
    This the # TSB 0044-14. You have to have the noise though. Also it seems hot weather exaggerates the noise, so do it soon before it gets colder. Good luck
  14. Oct 7, 2015 at 8:52 AM
    #494
    lanestaco
    Lane
    Guthrie, OK
    Talking about the gurgly...rattle can like sound made while under light acceleration?
  15. Oct 7, 2015 at 9:05 AM
    #495
    Nalex
    Yup
  16. Oct 7, 2015 at 9:19 AM
    #496
    lanestaco
    Lane
    Guthrie, OK
  17. Oct 9, 2015 at 11:52 AM
    #497
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    waiting to see what happens here...
  18. Oct 9, 2015 at 1:49 PM
    #498
    lanestaco
    Lane
    Guthrie, OK
    I probably won't get around to it until next spring.
  19. Oct 23, 2015 at 5:39 PM
    #499
    TheK
    TheK New Member
    FYI my 2013 was pinging badly prior to TSB. Had TSB performed and while the truck is not pinging nearly as much as before the TSB on a 80+ degree day I am still hearing pinging under certain throttle loads on 87 octane. Disappointing. Also the dealer did not install an modification label under the hood. Anyone else have a similar experience?
  20. Oct 26, 2015 at 8:36 AM
    #500
    lanestaco
    Lane
    Guthrie, OK
    I know the owner's manual says some pinging/rattling conditions are "normal," so maybe the little bit you hear now is "within the norm..."
