2012 Whistling sound indentified
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Appljaxx, Nov 23, 2011.
  1. Nov 23, 2011 at 7:32 AM
    Appljaxx
    Appljaxx [OP] He said "Member," ahuh huh
    Jeremy
    Albuquerque, NM
    '12 4x4 DCSB
    OME Nitrocharger front, 5/8 front spacer, 885s, OME N182s rear, dakar leafs, Diff Drop, TRD exhaust, Blackout emblems, 20% tint, Hi-Jack bed mounted, Dwreck sliders on order :)
    My only complaint with the new 2012 tacoma has been a consistent whistle that begins at 40 mph and gets louder as I drive it. I can hear it over the music and it has been driving me totally insane.
    Incidentally, when i took the problem to toyota they had me drive 2 other brand new trucks and they all made the exact same sound. Thus, they would not fix it. They said the truck was factory spec. I told them the whistle was driving me insane, but they didnt care.
    I started taping up parts of the front end and then driving around until i located the source. The sound is from the front grill, there is a small gap between the grill and the hood filled. The weather stripping is weak and when you hit 40 it bends and the air passing through makes a whistle.
    1.4" plastic drip line. Just shove it inside the weather strip and presto.*
    Credit to USMC91 for posting fix.
    Bearheat, DrexLock and Biscuits like this.
  2. Nov 23, 2011 at 7:42 AM
    Appljaxx
    Jeremy
    Albuquerque, NM
    '12 4x4 DCSB
    wilco ty
  3. Nov 23, 2011 at 7:42 AM
    Thy Lj
    Thy Lj iviomentuivi
    Lj
    Texas
    2012 TRd Sport :]
    i just picked my 2012 up about 3 weeks about and havent heard this noise you speak of yet now you gonna have me listing for it..\: ill let you know if i do hear it boss
  4. Nov 23, 2011 at 8:05 AM
    johnnyman1
    johnnyman1 Well-Known Member
    Jax
    2012 TRD OR PRE
    nerf audio
    I have a 2012 and I have not heard that noise. I did put in a crazy audio system in so maybe it was hiding the sound. I will drive with my music off and see if I can hear it.
  5. Nov 23, 2011 at 8:18 AM
    Thy Lj
    Thy Lj iviomentuivi
    Lj
    Texas
    2012 TRd Sport :]
    what kind of sys did you put?
  6. Nov 23, 2011 at 9:27 AM
    johnnyman1
    Jax
    2012 TRD OR PRE
    nerf audio
    Kenwood HU DD, Pioneer speakers/front/back/tweeters, Kicker 5way amp behind passenger side back seat, Kicker 10" sub/shallow behind driver side back seat with custom fiberglass/wood enclosure. I had an installer do it. This was beyond my capabilities. Its pretty noisy. :)
  7. Nov 23, 2011 at 9:43 AM
    tpr676
    tpr676 Well-Known Member
    So this noise is (a) grill or (b) windows ? Some have some don't I guess I will find out shortly sure hope I am one of the don't.
  8. Nov 23, 2011 at 5:01 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    thanks for the info! i haven't heard it on mine yet, but i haven't driven it a lot either.
  9. Nov 24, 2011 at 9:17 AM
    r6hokie
    r6hokie Well-Known Member
    Virginia
    tint, fog light anytime mod, weathertech visors
    I had this problem of whistling noise and took it to the dealer, they replaced the front grill because it was installed without insulation, the dealer said a tsb may be coming soon!
    After getting the new grill installed, I still here the noise
    I plan on taping up the front end this weekend and looking for the noise
  10. Nov 27, 2011 at 8:23 PM
    walleyeguy
    walleyeguy Well-Known Member
    '12 4x4 DCSB TRD OR Auto MGM
    I have the same whistling problem with my 2012. Can you post of picture of the area you found to be the issue. I was planning on starting to tape off my windshield and take it for test runs to see if I could location the problem area.
    The local Toyota dealership told me there was nothing wrong with my truck. Normal road noise, B.S.!
  11. Nov 28, 2011 at 12:38 PM
    r6hokie
    Virginia
    my truck is still making the noise but the installed the new grill wrong, one of the tabs is not seated properly, taking it back tomorrow for them to fix, will update after
  12. Nov 28, 2011 at 12:59 PM
    cpaul
    cpaul Active Member
    CT, US
    2016 TRD Double Cab Sport SB
    Can you post up some pics, maybe of the back side of the grill? I'm curious what you meant by an "insulated" grill.
  13. Nov 28, 2011 at 9:32 PM
    r6hokie
    Virginia
    If I determine the grill is the problem I will do that
  14. Nov 29, 2011 at 8:26 PM
    warriors_03
    warriors_03 Active Member
    Mark
    San Marcos
    2012 Tacoma DCLB Sport 4x4
    Subscribed. Please update when you have information. I have a 2012 DC LB 4X4 and I can hear a faint whistle as well from time to time.
  15. Dec 1, 2011 at 5:07 AM
    r6hokie
    Virginia
    Noise is still there, replacing the front grill did not help
  16. Dec 1, 2011 at 6:24 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Wow, I am glad I got a 2011. It's just a 2.7 with a non-scooped hood and here in Wyoming I have driven into some of the nastiest head winds for 70+ miles and only sound to be heard is the wind beating against the truck.
  17. Dec 1, 2011 at 8:10 AM
    r6hokie
    Virginia
    attached is a taping layout that for now, has stopped the noise, I think, it has only been 24 hours.....
    I will continue problem solving and seeing with causes the noise on my truck, hopefully it will help others
    Notice the only part of the windshield taped is at the bottom corners
  18. Dec 1, 2011 at 8:19 AM
    johnnyman1
    Jax
    2012 TRD OR PRE
    nerf audio
    LOL,, dude that is awesome!!! "Scientific Method" all the way. I knew those science courses were not a complete waste.
    Good job.
  19. Dec 1, 2011 at 2:19 PM
    walleyeguy
    If you remove the tape that is on the bottom corners of the windshield does the noise come back?
  20. Dec 3, 2011 at 9:53 PM
    r6hokie
    Virginia
    I think the noise is coming from the front under the hood, the weatherstriping has gaps in it, more tomorrow if I have a chance to take some of the tape off and drive it
