2012+ Winch Mount Bumper Development
Discussion in '2nd Gen. Tacomas (2005-2015)' started by usoffroad, Feb 28, 2014.
  1. May 19, 2014 at 8:30 AM
    #101
    SAtaco210
    SAtaco210 Member
    San Antonio
    Hella excited can't wait for production to be done...
  2. May 19, 2014 at 8:54 AM
    #102
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I've found other hidden winch mounts on line. None of them are built like this. Or look as nice as this. I'm personally on the fence between this mount and a bumper. Can't beat this set up to keep a stock looking truck. Might have to entice me more...
  3. May 20, 2014 at 1:15 PM
    #103
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    Question for you Brad...
    What is the vertical spacing between your new winch bumper insert and the bumper. I'm looking to add 2 4" LED bars on either end and want to make sure they'll fit before I order them. Thanks
  4. May 20, 2014 at 1:31 PM
    #104
    usoffroad
    usoffroad [OP] TEXAN Vendor
    Brad
    Hico, Texas
    1998 4Runner and 1970 FJ40
    Nope..maybe. :)
    2 reasons.
    1. The vertical opening is 3-3.250".. always some variance with plastic.
    2. The depth of almost all lights will run in to the winch.
    We design these to accommodate our Sirius 2" lights which have a 3" housing and fit fine. I'm going to sit down with CAD tomorrow and try come up with a bracket location that will facilitate up to a 6" light but will probably be limited to 4". Obviously some winches are longer/wider than others but I'll use an average dimension there.
    Keep in mind that winches are seldom symmetrical, the motor end is usually longer than the clutch end.
    I don't have any 4" lights but the Sirius 6" lights are 3.280" tall and might fit, however it could rub, but their depth is 3.324" front to back which will put it well within the winch. Same for the 2"...they must clear the winch. So the bottom line is that they can't intersect with the winch or the will hit it... must be clear of each end of the winch.
    Now, having said that, these specs are for our Sirius lights and others like Rigid will be pretty much the same but you might find some to fit.
    See the attached dimensions.
    Most winches like the Viper Max or the Engo 10000 are 21-22" long/wide (however you care to view it) and right now our winch tub for the 12+ Taco is 33.5" wide so in theory a couple of 4" lights will work and some 6" might. Also, there is 1-1.5" of lateral adjustment on most light brackets so you have some wiggle there too.
    I'll find the sweet spot and set the tabs at the most advantageous spot but it won't work for everything over 4".
    I've attached the preliminary CAD drawing (which is going to change) but you can see the fundamental layout of the winch tub and endwalls. The light tabs and shackle mounts are coming inward around 2".
  5. May 20, 2014 at 4:19 PM
    #105
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I'm in, pending final price and delivery.
  6. May 20, 2014 at 7:45 PM
    #106
    JoyStick
    JoyStick Member
    Benjamin
    Lantana, Texas
    13' Texas Edition
    Running Boards Delete, Tint, Big R Type Shift Knob, Core Short Shifter, Borla Cat Back, Afe ProDry CAI, URD- Maf Calibrator, Doug Thorley Long Tube Headers
  7. May 23, 2014 at 6:43 AM
    #107
    motionridr8
    Drew
    Greenville, SC
    any CAD update Brad?
  8. May 23, 2014 at 6:57 AM
    #108
    usoffroad
    Brad
    Hico, Texas
    I made about a half dozen adjustments and they are being incorporated today. Will be in the shop later to sit down with CAD and go over final details.
    Moved shackle mounts in, tightened up the hole diameter a bit from .910 to .880", moved light tabs in about 1.18" that will give a 5" light housing (most 4" lights) just that much room.... no way to make 6" lights work as either you were going to hit most winches and/or the curvature of the bumper cover as it tapers out and down, but at least it opened up the use of 2" and 4" lights now.
    Tightened up mounting holes, added the 4" drain/access holes underneath...clearanced a few other items.. mostly small stuff.
    I think we'll have a green light later today to go make a 'production prototype' for test fitting in a week or two.
  9. May 23, 2014 at 8:21 AM
    #109
    motionridr8
    Drew
    Greenville, SC
    awesome! thanks for the update!
  10. May 27, 2014 at 3:10 PM
    #110
    usoffroad
    Brad
    Hico, Texas
    A little sneak peak update after adding center 4" holes, moving light tabs and shackle mounts and making a few other tweaks.
    Going over all of the dimensions again tonight so hopefully I can give a green light tomorrow.
    The main problem I have right now is that there is only 1" of material below the two center 4" holes and you can't really brace it. Without those holes you don't have a fighting chance to mount the winch after the bumper is mounted.
    So, in my opinion it either all 4 holes, the 2 cutout/holes for the recovery point.. or cut off the recovery point and have no holes. Keep in mind that part of the bumper is .125" so one good shot below one of the center 4" holes and there will be dent. If you cut them like the cutouts then it starts looking a bit like the Punisher.
    Now's the time for some input/feedback.
  11. May 27, 2014 at 3:47 PM
    #111
    TacoMiller
    TacoMiller Dude
    Calgary
    '13 DCSB SR5 V6M
    Is it not possible / extremely difficult to mount the winch prior to mounting it to the frame?
  12. May 27, 2014 at 3:51 PM
    #112
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    I vote for structural strength first. If that means I need to have the winch ready to install when I install the bumper, so be it. I'd rather have it braced as you see fit than worry about adding a winch without dropping the unit.
    I had already assumed you'd have to drop the bumper to add a winch anyways. Looking great!!!
  13. May 27, 2014 at 3:56 PM
    #113
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I would rather cut the Oem hook off and have more strength in the bumper
  14. May 27, 2014 at 4:11 PM
    #114
    eazyrider711
    Jay
    Northern, CO
    Black DCSB T|X Baja
    Man, I didn't even think of that. I'm still voting to cut the stock hook off, but I think you're right its important to be able to service the winch without dropping the entire bumper.
  15. May 27, 2014 at 4:16 PM
    #115
    usoffroad
    Brad
    Hico, Texas
    Remember the nuts are in the winch frame so it's bolts that need to go vertical but then you would have some 3/4" ish holes kind of randomly in the front plate... unless I did away with the center 4" and we cut a bunch of 1" holes...kinda cheese grater style....drainage, air and access holes to use a socket with an extension to insert the bolts.
    No real easy way to do this. Getting so many gussets as is... 2 end plates then 5 gussets.. so really 7 already. Hmmm... this may require a whiskey and go marinate a bit on it.
    I'm listening though.. keep it coming.
  16. May 27, 2014 at 4:30 PM
    #116
    usoffroad
    Brad
    Hico, Texas
    This is quick and dirty but kind of what I have in mind.
  17. May 27, 2014 at 4:30 PM
    #117
    TacoMiller
    TacoMiller Dude
    Calgary
    '13 DCSB SR5 V6M
    This.
    Personal preference is to not remove original OEM recovery loop however, as Id imagine most people wanting this kind of bumper are trying to avoid changes to the OEM design.
  18. May 27, 2014 at 4:31 PM
    #118
    usoffroad
    Brad
    Hico, Texas
    Thought about that but if you ever catch a bolt head or even a stove bolt on something it's all over. Plus you can't gusset behind it so it would still be pretty weak... then you would also need some recessed threaded fittings
  19. May 27, 2014 at 5:09 PM
    #119
    dandyone
    dandyone Active Member
    Puget Sound
    2014 DCLB Sport
    sub'd
    much interest
    still confused...
  20. May 27, 2014 at 6:32 PM
    #120
    eazyrider711
    Jay
    Northern, CO
    Black DCSB T|X Baja
    Speaking for myself, I want to cut the OEM off. I like this bumper because it keeps a very factory LOOK and I don't have to cut sheet metal/body panels. I don't mind losing the OEM loop by replacing it with something better.
