2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mailman13, Aug 18, 2014.
  1. Aug 18, 2014 at 3:19 AM
    mailman13
    mailman13 [OP] Member
    2012 Access Cab SR5 4WD
    Hi everyone. Just bought a 2012 Tacoma Access Cab 4WD with SR5 package.
    The truck didn't have the window sticker with it. Is there anyway I can find a list of the accessories that came on the truck? The interior ones are obvious, at least to me. I'm more concerned with things such as does it have a heavy duty alternator & battery, transmission cooler? I see the newer models do so I'm just curious. It has a trailer hitch and wiring harness and steel wheels.
  2. Aug 18, 2014 at 3:55 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    The tow package usually has the trans cooler. I think the trd with power outlet in the bed had the bigger alternator
  3. Aug 18, 2014 at 5:44 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    if your truck has the tow package (my base does) it will have HD alternator and extra cooler.
    if you have the V6 it should be very easy for you to add in back up camera with mirror that has the display. or have a 12 volt guy wire it into an aftermarket head unit (mine does both)...
    you can add cruise control (mine came with it so i only know by reading here)
    you can add in intermittent wiper stalk (i think yours has it already)
    you can add in fog lights (should also be pre-wired if you dont have them already)
    welcome to the forum... theres prob other stuff too members will chime in...
  4. Aug 18, 2014 at 7:47 AM
    mailman13
    Thanks guys. Forgot to mention I already have the back up camera with Homelink mirror, fog lights, cruise and intermittent wipers.
