2013 access cab 2.7l manual
Discussion in '4 Cylinder' started by mercer03, Oct 17, 2012.
  1. Oct 17, 2012 at 9:52 AM
    mercer03
    mercer03 [OP] Member
    matt
    california
    2013 access cab sr5
    Whats up guys i want to put some bigger rims and tires on my truck. was wondering if anyone knows how big i can go without any rub? I believe it is the same setup as the 2012
  2. Oct 17, 2012 at 9:57 AM
    mercer03
    matt
    california
    2013 access cab sr5
    no not a prerunner it has P215/70R15 wheels.
  3. Oct 17, 2012 at 3:03 PM
    scaplus
    scaplus Well-Known Member
    I assume if it has the 215's, then it's the 5 Lug, RWD. If so, your best bet is 235/70/15 is the biggest tires you can put before you need to lift it.
  4. Oct 18, 2012 at 7:19 PM
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    I'm in the same boat. After research I think you can install 235 75 15's without any rubbing or needed lift. I'm installing them tomorrow and will know for sure in a couple of days.
    Bill
  5. Oct 19, 2012 at 10:35 AM
    mercer03
    matt
    california
    2013 access cab sr5
    Post some pictures when it's done
  6. Oct 19, 2012 at 2:15 PM
    paid4c4
    Northern KY
    The tires 235/75/15 have been installed. The look, ride, handling and ride height are all great! The truck sets about one inch or so higher, the handling has been improved and the tires look like real truck tires. Lock to lock no rubbing and plenty of room in the rear. Alignment scheduled for Tuesday. It's raining out so I'll take pictures tomorrow and get opinions.
    Bill
