2013 Bedrug Installed on Tacoma - Tacoma Fitment News
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brian AutoCustoms, Dec 30, 2012.
  1. Dec 30, 2012 at 5:28 AM
    Brian AutoCustoms
    Brian AutoCustoms [OP] Member
    Brian
    Ocala, FL
    06 PreRunner Double Cab
    Bedrug made some minor changes to their 2013 Tacoma Bedrug part number for the first time since '05. For those of you that don't know, each Bedrug is custom made for each truck bed and designed to allow you to use all of the features that came with the truck. The Bedrug ships with pre-cut holes for an easy installation. However, we installed a Bedrug on another Tacoma and the pre-cut holes were a little big...not much, it still was a nice fit...but not perfect.
    Bedrug is phasing out the old Tacoma part numbers and all 2nd gen Tacomas will receive the '13 part number by the end of the year. I'm sure they're just getting rid of their stock and will supersede the part number.
    I have an '06 Tacoma, but I ordered the 2013 part number so that I could have the best fit possible. The only big difference was that we cut holes for the two cubby holes closest to the cab. It ended up with a perfect fit.
    Here are some pics on the Bedrug Installation blog post. Our installation video will be done soon.
  2. Jan 4, 2013 at 7:38 PM
    Donkeythekidd
    Donkeythekidd Active Member
    Beaumont, CA
    2017 MGM Tacoma TRD Off Road Double Cab
    Thanks for the post. I ordered a BRY05DCK bedrug a few weeks ago from my local shop for my 2008 Tacoma. I went to install it today and noticed there were no cubby hole cutouts and that the model number I received was BRY13DCK. I called up the place where I bought it and they said that when they type in the model number it automatically changes it to BRY13DCK. They tried calling Bedrug but they where already closed. So they said I could try back on Monday. After reading your post it doesnt look like I'll have to call back Monday. Were you able to cut out the cubby holes in the bedrug with out cutting the seams? Did everthing else line up perfectly.
    Thanks
  3. Jan 5, 2013 at 7:10 AM
    Brian AutoCustoms
    Brian
    Ocala, FL
    Yes, everything lines up perfectly and the Bedrug was very easy to cut. I wish I had our videographer edit that install video first so I could just show you. That should be available next week.
  4. Jan 6, 2013 at 7:24 AM
    FastEddie
    FastEddie Well-Known Member
    MD
    2012 super white access cab, base model
    thanks for the info on the 2013 bedrug... i just bought one and did not realize that bedrug changed their model for all 2nd gens. when you installed the bedrug did you have to unbolt anything?
  5. Jan 7, 2013 at 12:40 PM
    Brian AutoCustoms
    Brian
    Ocala, FL
    Yes. It installs under the tailgate cap and under the storage panels to give a very nice finished look. Those are held in with T30 Torx bolts so you'll want to have the right tools. You will not be unbolting the DeckRail System for this install.
    Video coming soon.
  6. Jan 7, 2013 at 12:54 PM
    FastEddie
    MD
    sweet, thanks. hopefully the video will be ready before i install it on weds.
  7. Jan 8, 2013 at 6:32 AM
    Brian AutoCustoms
    Brian
    Ocala, FL
    Watch the installation video here - '13 Bedrug Install on Tacoma.
    As I stated above this is the '13 Bedrug for the '06 Tacoma so that I'd have a better fit on the storage pockets. The video is longer than it should be but you'll be able to see all of the crucial parts - cutting, removing bolts, etc.
    If there is anything else out there you'd like to see...please let me know.
    (Note: Check out how dirty the storage pockets are when they come out)
  8. Jan 8, 2013 at 9:07 PM
    FastEddie
    MD
    Nice video. My bedrug actually came early today, so I installed it before I watched your video. My storage pockets were covered in dirt also. Nice method on the cutout for the bed cubbies. On the 2012, I have a tie down towards the front of the bed near the cab, so I removed those, but one of the torx bolts stripped and I cant get it out now. Any advice on how to remove a stripped torx bolt?
  9. Jan 9, 2013 at 6:46 AM
    Brian AutoCustoms
    Brian
    Ocala, FL
    You can get a bolt extractor tool from a hardware store but I usually just cut a + in the top with a Dremel and pull it out with a screwdriver.
  10. Jan 17, 2013 at 7:07 AM
    crabmanbc21
    crabmanbc21 Member
    Lake Mary, FL
    TRD Off Road
    Great video!!
    Do you sell the Bedrug for a 2013 Tacoma 5' bed? I want to get one.
  11. Jan 17, 2013 at 7:18 AM
    Brian AutoCustoms
    Brian
    Ocala, FL
    Of course - shoot me a PM and I can hook you up.
  12. Feb 23, 2013 at 6:59 AM
    willee51
    willee51 Well-Known Member
    Bill
    Forest, VA
    2015 TRD-Sport 6-cyl DCLB MGM
    Weathertech window vents, bed mat, Nerf Bars, Husky mats, sPOD, Marathon seat covers, Michelin LTX AT2's
    OK the Bedrug seems to use velcro to attach to the truck-bed!
    The 2013 Tacoma truck bed is "composit", so does this composit affect the ahhesive of the velcro strips adhering to the truck bed????
    Thanks, folks~!
  13. Feb 23, 2013 at 7:30 AM
    east
    east Well-Known Member
    S.E. N.C.
    Stock 4x4
    What was your total investment and are you satisfied with the product? I might be interested in this.
    Thanks,
    Eric
  14. Feb 23, 2013 at 7:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2005 and later all have the same bed material.
    Yes, the composite bed is tricky... it has to be clean, and you have to be careful that what you use to clean it leaves no residue. The bed itself is pretty much impervious to most common chemicals (at least those that you'd want to use at home).
  15. Feb 25, 2013 at 8:03 AM
    FastEddie
    MD
    My total investment was just the price of the bedrug itself. The bedrug itself is decent, but it is definitely expensive.
    The sample that bedrug sent me seemed a little thicker than the actual bedrug that I received (this may or may not be true, just my perception). I felt like the bedrug is a little flimsier than what I was expecting.
    Also, installing the bedrug on my 2012, reinstalling the bed cubbies above the wheel well was a pain in the ass because the cubbies were originally held in place with a few clips and adhesive tape (this complaint is about Toyota's design, but it's something to take into account when purchasing the bedrug).
    I got a bedrug for my truck because I sleep in the back of the truck sometimes and it is more comfortable than sleeping on the composite bed itself. Installation is relatively easy, visually the bedrug looks very nice, and the bedrug does keep a lot of things from sliding around or making a lot of noise in the bed. Overall I would say the bedrug is an okay investment, not the best, but definitely not the worst.
    Here is a picture of what mine looks like installed:
  16. Feb 26, 2014 at 6:12 AM
    DanPaul
    DanPaul New Member
    Delaware
    2012 DCLB 4x4 SRD Sport
    "...reinstalling the bed cubbies above the wheel well was a pain in the ass because the cubbies were originally held in place with a few clips and adhesive tape..."
    The BedRug looks great! What did you end up doing with the cubbies? They look like they fit nicely back into place on your's, but I watched an install video where they seemed to just rest in the hole with no real attachment to the truck bed.
    Thanks!
  17. Feb 26, 2014 at 6:42 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    It says that it is "battery acid and oil stain proof"
    but is it"fish guts, deer blood, and the smells associated with that proof?";)
  18. Feb 26, 2014 at 11:22 AM
    FastEddie
    MD
    The cubbies just rest there, I broke a clip taking them out, so sometimes they pop out during normal driving. If I were to redo it, I would just let the bedrug cover the cubbies.
  19. Feb 26, 2014 at 11:28 AM
    FastEddie
    MD
    My dogs have puked a couple times on the rug and there are no stains or smells after cleaning with alcohol, but I cant say anything about fish guts or deer blood.
  20. Feb 26, 2014 at 7:34 PM
    DanPaul
    DanPaul New Member
    Delaware
    I considered that actually, just hate to waste the space.
    Great advice, thanks.
