2013 Bluetooth touchscreen install in my 06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Jan 26, 2014.
  1. Jan 26, 2014 at 8:46 AM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    After the much awaited arrival of my truck last friday i couldn't wait to start modding again. This is one of the easiest DIY mods imo, i couldn't be happier with the results! This head unit with the bluetooth music streaming made my aftermarket speakers 10x better.
    I couldn't have done it without the help of these good people:
    Danmcw45 - for giving me a good deal on the head unit to begin with
    adio - for providing part numbers and adapters i would need, extremely helpful (all the parts pictures came from him!
    chetweewax - for explaining and providing pictures for the bluebooth mic install in the overhead console
    I figured i would compile the information i got from everyone so it will make your life a little bit easier if you decide to do it!
    Parts needed:
    Head unit (obviously :rolleyes:)
    Antenna adapater: http://www.crutchfield.ca/Toyota_Lex.../12040lx21.htm (even if it says it won't work your tacoma, it will!
    28 pin harness - PT546-00120-CH
    Mic that plugs into that 28 pin conversion harness for bluetooth to work
    Tools needed:
    Beer (important one)
    Flathead screwdriver
    Ratchet with 10mm socket (mounting bolts) and 8mm socket (bracket bolts)
    Dremel (will be used later when i run my bluetooth mic to my overhead console, i just ran it under the ac controls temporarily until i can get my extension from radio shack online)
    I was gonna do a full DIY topic but i didn't have time to take many pictures, this was the end result!
    Biscuits, Tex-Tac and Tacojoe1378 like this.
  2. Jan 26, 2014 at 9:30 AM
    Blackpearl2007
    Blackpearl2007 Active Member
    Southeast
    2013 4x4 TRD Off Road
    Thank you. Is this also navigation? Can you also add navigation through a similar process?
  3. Jan 26, 2014 at 9:58 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Not too sure on the nav units, I didn't bother with one since I use my cell for GPS anyways, the directions still come through my speakers. The steering wheel controls work for volume and changing songs, didn't expect to be able to change songs on the steering wheel!
  4. Feb 2, 2014 at 10:11 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Don you know if this unit will fit a 2006 with jbl? Thanks
  5. Feb 3, 2014 at 3:55 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    What are the new features of this head unit over the previous one?
  6. Feb 3, 2014 at 7:15 AM
    T09COMA
    T09COMA Member
    justin
    nc
    09 Trd Sport SR5
    Did the radio hook right up to the factory pigtails I have a 09 wanting to do this
  7. Feb 3, 2014 at 10:08 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Bought, not built:-P
    Power and speaker plugs will hook right up to the HU. If you want to just keep it simple and don't want to deal with the whole fancy BT and stuff, then all you need is the antenna adapter. If any local radio is broadcasting in HD you'll catch it.
  8. Feb 3, 2014 at 10:28 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Kind of looks like its possible:
    http://www.youtube.com/watch?v=gx9AXGfXjLI
  9. Feb 3, 2014 at 1:55 PM
    chadwhitt
    chadwhitt Active Member
    Ontario, Canada
    07 DCSB SR5 Tacoma
    Custom Grill
    This has been something I have been looking for... does anyone know if there is any changes in the head unit wiring from 2006 to 2007? If not I am for sure doing this to my taco..
    Thanks for the great write up! :D
  10. Feb 3, 2014 at 3:36 PM
    steveo27
    steveo27 Ask me about my weiner
    Steveo
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Neat. I eventually want to do this with my '11.
    Does new the radio fit 100% in older bezel? Ive seen some pictures of them not fitting very well and this keeps deterring me from spending the money on this....
  11. Feb 4, 2014 at 6:02 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Its the same, you would only need the antenna adapter unless you want to use the bluetooth, then you need the harness and bluetooth mic as well.
    It fit in good, the only gap is under the head unit and you cant see it unless you are looking underneath it. Ill take a couple more pics in the light after work today
  12. Feb 4, 2014 at 6:32 AM
    Coloturfguy
    Coloturfguy Active Member
    Jeff
    Castle Rock Colorado
    06 TRD Sport DCSB Silver Streak
    Plastidip Wheels Leer Topper TBD Suspension upgrade BHLM Grillgraft mx series grill-black Plastidip some badges Remove some badges Ultraguage CIA
    what is the part number of your HU
  13. Feb 4, 2014 at 7:57 AM
    steveo27
    Steveo
    Pittsburgh
    Awesome. I'd love to see some detailed pictures.
    I wonder if you could swap the 12+ dash bezel over to make it fit 100%?
  14. Feb 4, 2014 at 8:04 AM
    ramonortiz55
    ramonortiz55 Official Bro
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I have a headunit for sale if anyone is interested!
    :D
  15. Feb 4, 2014 at 8:05 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    You can. There's many threads now on different radio swaps between the newer models and the older.
    I have a 14 entune plus with navi non jbl in my 08 ;)
  16. Feb 4, 2014 at 8:56 AM
    steveo27
    Steveo
    Pittsburgh
    ive been researching alot and reading your thread. working on collecting all the info I can.
    I want to do the same swap - non JBL w/ Entunes and nav in my '11 :thumbup:
  17. Feb 4, 2014 at 1:40 PM
    tonytsai0429
    tonytsai0429 Well-Known Member
    SoCal
    Racy Inferno
  18. Feb 4, 2014 at 2:53 PM
    Pat C
    Pat C Member
    Patrick
    CT
    2011 Tacoma TRD sport
    Where did u get the head unit?
  19. Feb 4, 2014 at 5:17 PM
    Sigi
    Sigi
    Sfv ca
    Anyone??
  20. Feb 4, 2014 at 5:32 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Jbls are a bit easier with the jbl entune unit but still need to rewire some things to make your amp work correctly with your radio
    Hit up dibble9012 he did the swap into his 09 jbl with a 2012-13 jbl touchscreen system
