2013 Cruise Control install, need advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacifictimes, May 3, 2013.
  1. May 3, 2013 at 7:58 AM
    Pacifictimes
    Pacifictimes [OP] Member
    Dave
    Vancouver, Wa
    2013 Tacoma 4 X 4 standard
    This makes me feel a bit lame :O/ Its only 2 wires a ground and the other goes to the connector to (i think its the computer) I believe 12 volts. I have the wire pluged into the(I believe) the right pin spot on the connector, but nothing works on the cruise, so I unplugged the wire to the cruise and with the key on I have no voltage to the wire from the computer. Any suggestions?
  2. May 3, 2013 at 12:05 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Best bet is to get a schematic, and go from there. IIRC, there's one on TTORA.com
  3. May 10, 2013 at 12:57 PM
    cgsomoza
    cgsomoza Rocky Mountain Member
    Longmont, Colorado and Ontario, California
    2013 4x4 DCSB V6 Tacoma
  4. May 15, 2013 at 7:38 PM
    Netrader
    Netrader Member
    North West Indiana
    2013 Toyota Tacoma Regular Cab 4x4 2.7
    Hi was was also researching the install on the 2013. Please let me know if you tried to do the install from the link and if it worked on your 2013
  5. May 16, 2013 at 9:08 AM
    Pacifictimes
    Dave
    Vancouver, Wa
    yes it works fine
