2013 DC: run a sub, speakers off a 4 channel amp?
Discussion in 'Audio & Video' started by sloken, Jul 21, 2014.
  1. Jul 21, 2014 at 11:10 AM
    sloken
    sloken [OP] Active Member
    AB, Canada
    2013 Spruce Mica DCLB TRD sport
    debadged, IMMrYo mirror bracket, bakflip F1, Husky X-act contour liners, rear glass aftermarket tint, blizzaks and steelies
    Hi all. I'm pretty ignorant (OK, very ignorant when it comes to car audio). I used to own a 2012 ram 3500 that had a pretty sweet OEM alpine system with sub, and 7 speakers. I loved how that sounded.
    Last week, I downsized for a 1year old 2013 DCLB TRD with touchscreen but no JBL. The previous owner had some aftermarket audio stuff put in...I took the truck to a shop b/c I didn't know how/want to tear off the doors, and he looked up the previous owner's history: he had aftermarket speakers installed (but they weren't sold to him by the shop), as well as a Kenwood XR-400-4 amp installed behind the back drivers side seat. When I take a flashlight and look up close at the tweeters, I can see they're Massive Audio brand. I can't see any writing on the other speakers.
    I scoured these forums yesterday as there's been a really annoying hiss whenever the key is at ACC or ON. Seems like it was the gains knobs which i turned way down, so the hiss is very minimal and barely noticeable now.
    As for my thread title/question: I miss the thump of my old truck's sub. I listen to a lot of hip-hop and the audio quality in my current truck can't keep up...it sounds tinny and the speakers rattle and sound horrible when I have my music moderately loud. Here's my ignorant question:
    Do I need to have a new amp installed if I want to have a sub added? Or can each front speaker be run off of one channel, the rears off of another, and the sub off the 4th?
    Right now, I want to keep the factory HU. Yes I know and have read how it's crap, but at this point I'm not ready to tear it out and potentially lose steering wheel controls.
  2. Jul 21, 2014 at 11:20 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What I would recommend, assuming you don't want to spend a bunch of $$$ is to run the fronts off the amp's front channels, run the rears off the HU (and turn them all the way down, unless you have passengers you want to keep happy), and bridge the rear channels to a sub (assuming the amp supports bridging the rear channels, if it doesn't, you can still get a DVC sub and run one VC to each rear amp channel).
    BTW, there are adapters that will allow the steering wheel controls to be used with a new HU.
  3. Jul 21, 2014 at 11:30 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    This is exactly what I have done in the past. Most 4-channel amps are basically 2 amps in a single unit with the expectation that this is how you plan to run it (hi-pass and low-pass cutoffs, etc.).
    You will need a sub box that fits somewhere convenient, like behind the rear seat. I built one out of MDF, but you can buy them. You will also need new front speakers, and you'll probably want front component speakers so you can mount the separate tweeters in a better spot.
    If you plan to keep the stock head unit, you'll need an amp with speaker-level inputs. Most amps have these, but I would recommend spending some money on a new head unit that has proper preamp outputs. You will be happier with the sound in the end.
  4. Jul 23, 2014 at 11:29 PM
    sloken
    AB, Canada
    OK thanks guys. I found out about the Kicker Hideaway yesterday and it seems like something I'd want to try. Problem is, it's tough to get shipped to Canada and not get ripped off on shipping. I also found this one from Hertz that a local shop carries.
    http://www.madmanmckay.ca/en/catalog/product/121781-Hertz-EBXF20,5
    but I don't know if it's powered or not.
    Ps a "powered sub" means it has a built-in amp, correct?
    If I went with a solution like this, could I conceivably get away with no modifications to the existing aftermarket speaker and amp setup, since the sub already has an amp built-in?
  5. Jul 24, 2014 at 4:32 AM
    TenBeers
    Rich
    Bentonville, AR
    That Hertz one does not appear to be powered, so you would have to provide your own amp. Powered does mean built-in amp.
    Even if you go with a powered sub, you are probably going to want to do something with the rest of the system. All a sub would do is add bass and bass volume, the rest of the system would sound the same.
  6. Jul 24, 2014 at 9:01 AM
    sloken
    AB, Canada
    Ok, thanks for the headsup re: the Hertz. The previous owner did upgrade with aftermarket speakers as well, I just don't know what brand. I'm happy with the resulting sound right now, I just want the lower frequencies filled out more
  7. Aug 7, 2014 at 9:06 PM
    sloken
    AB, Canada
    OK, so I found a low profile kicker compRT with box that should fit behind the back seat: http://www.crutchfield.com/S-4Nv7fGMfQtr/p_2064TWRT82/Kicker-40TCWRT82.html
    The Hideaway was a pain in the ass to find /ship to Canada and the one above was easily found here. As for setup and install: I don't have many/any rear passengers to keep happy, so I'm interested in what you guys suggested running the rear speakers off the HU.
    This is the amp that was in the truck: http://www.crutchfield.com/S-lFSX3jTubWM/p_113XR4004/Kenwood-Excelon-XR400-4.html
    Under the Details tab, there's a line that says " Bridged Power (Watts x Channels) 200x2". Does this mean that the rear channels can be bridged like you guys said?
    I appreciate the help...i know full and well I won't be getting as nice sound as with something like a Stealthbox, which is what every car audio store seems to be trying to cram down my throat. Your input is giving me a somewhat-informed view before walking in there. Assuming this setup (4 channel amp powering the sub plus 2 front speakers and the 2 rear speakers off the HU) is feasible, now I just have to convince the techs to actually do it this way...
  8. Aug 8, 2014 at 5:51 AM
    TenBeers
    Rich
    Bentonville, AR
    Yes, that amp has separate settings for front and rear, so you can bridge the rear and set the low pass filter to only send bass to the sub.
    This is a very typical way to setup a decent sounding system without spending a ton of money. What you are asking them is not out of the ordinary. They just want to sell you more stuff.
    When you can, post of pick of that sub box behind the rear seat. Interested in seeing how it fits.
  9. Aug 8, 2014 at 2:35 PM
    sloken
    AB, Canada
    will do, thanks!
