2013 Key Fob
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThomasMore66, Mar 16, 2013.
  1. Aug 5, 2013 at 11:16 AM
    Mario340
    Mario340 New Member
    Virginia
    TRD Sport
    None
    How to program the FOB
    These are the 10 steps that worked for me.
    1. Unlock and open the driver's door; keep the rest of the doors closed
    2. Insert key in the ignition and pull it out twice within five seconds
    3. Close and open driver's door twice within ten seconds
    4. Insert key in the ignition and remove
    5. Close and open driver's door twice within ten seconds
    6. Insert key in ignition and close door
    NOTE: Some cars required to close the door first, and then insert the key in the ignition
    7. Turn ignition from lock to ON and back once (P.Mode)...
    8. Remove key from ignition
    NOTE: The door locks should lock and unlock automatically to indicate is in programming mode
    9. Press lock & Unlock buttons at the same time for two to three seconds
    10 Press the lock button
    You are done!
    Hope thais work for you, It worked for me. 2013 Taco
    NOW... Does anyone knows how to program a new key?
  2. Aug 5, 2013 at 11:35 AM
    Mario340
    Mario340 New Member
    Virginia
    TRD Sport
    None
    These instructions worked for me / 2013 Taco
    1. Unlock and open Driver’s door keep the rest of the doors closed
    3. Close and open driver’s door twice within ten seconds Insert the keys in the ignition and remove
    5. Close and open the driver’s door twice within ten seconds
    6. Insert the key in the ignition and close the door
    Note: Some cars required to close the door first and then insert the key in the ignition
    7. Turn the from lock to On and back to locked once for P.Mode
    8. Remove the key from the ignition
    Note: The door locks should lock and unlock automatically to indicate it is programming mode
    9. Press the Lock & Unlock buttons on the FOB for three to five seconds
    10. Press the lock button
    Hope this works for you; it did for my 2013 Taco
    Now; does anyone knows how to program a new key?
    Mario
    hoverlover likes this.
  3. Oct 27, 2016 at 7:50 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Got it on the first go, thank you so much for actually posting the instructions instead of a link!
